First of all thanks for all the content you provide on YouTube and Github you have been an amazing help navigating through Zephyr for me!
I wanted to provide some feedback on your https://github.com/circuitdojo/pcf85063a.
I tried to follow your steps to add the module to Zephyr in a Nordic NCS context but with the steps provided in the readme file I was unsuccesful.
An NCS project seemingly has 2 .yml files. The regular Zephyr one and one in the /nrf sub directory. To the latter I had two add the remote for circuitdojo:
- name: circuitdojo
url-base: https://github.com/circuitdojo
and an entry underneath what Nordic describes as third-party repository information:
- name: pcf85063a
path: modules/lib/pcf85063a
revision: master
remote: circuitdojo
When I did added those 2 things to the correst west.yml file I was able to run west update correctly and use the module.
I’ll add the entire west.yml file as well.
Cheers,
Michiel
9 of 6,175
Adding pcf85063a to west.yml file
Inbox
Michiel S <michiel.scheys@gmail.com>
Thu, Jan 26, 11:17 AM (4 days ago)
to jared
I wanted to give you some feedback on adding the PCF85063A module to Zephyr, specifically for Nordic NCS. The information you provided in the readme did not do the trick for me in the NCS and when asking in the Nordic devzone they also weren't able to give me the correct information. What makes matters more complicated is that in an NCS project there are multiple west.yml files unfortunately. So anyway I'll add the west.yml file (the one supposed to be in the /home/developer/ncs/v2.1.0/nrf folder) that made it work for me.
If you prefer I could open an issue on Github, but I didn't really want to do that since this is kind of Nordic specific maybe.
Anyway, thanks again for all the content!
Best regards,
Michiel
One attachment
• Scanned by Gmail
Jared Wolff
Fri, Jan 27, 5:27 PM (3 days ago)
to me
Hey Michiel
Can you ask this on my community forum?
https://community.jaredwolff.com/
Jared
New live sessions every week on Youtube 📺.
west.yml
Will do!Sure thing!No, I can't.
# The west manifest file (west.yml) for the nRF Connect SDK (NCS).
# The per-workspace west configuration file, ncs/.west/config,
# specifies the location of this manifest file like this:
# [manifest]
# path = nrf
# See the west documentation for more information:
# https://developer.nordicsemi.com/nRF_Connect_SDK/doc/latest/zephyr/guides/west/index.html
manifest:
version: "0.12"
# "remotes" is a list of locations where git repositories are cloned
# and fetched from.
remotes:
# nRF Connect SDK GitHub organization.
# NCS repositories are hosted here.
- name: ncs
# Third-party repository sources:
- name: zephyrproject
url-base: https://github.com/zephyrproject-rtos
- name: throwtheswitch
url-base: https://github.com/ThrowTheSwitch
- name: armmbed
url-base: https://github.com/ARMmbed
- name: nordicsemi
url-base: https://github.com/NordicSemiconductor
- name: memfault
url-base: https://github.com/memfault
- name: circuitdojo
# If not otherwise specified, the projects below should be obtained
# from the ncs remote.
defaults:
remote: ncs
group-filter: [-homekit, -nrf-802154, -find-my]
# "projects" is a list of git repositories which make up the NCS
# source code.
projects:
# The Zephyr RTOS fork in the NCS, along with the subset of its
# modules which NCS imports directly.
# https://developer.nordicsemi.com/nRF_Connect_SDK/doc/latest/zephyr/introduction/index.html
# https://developer.nordicsemi.com/nRF_Connect_SDK/doc/latest/zephyr/guides/modules.html
- name: zephyr
repo-path: sdk-zephyr
revision: v3.1.99-ncs1
import:
# In addition to the zephyr repository itself, NCS also
# imports the contents of zephyr/west.yml at the above
# revision. Only the projects explicitly named in the
# following allowlist are imported.
# Note that the zephyr west extensions (like 'build', 'flash',
# 'debug', etc.) are automatically provided by this import, so
# there's no need to add a redundant west-commands: key for
# the zephyr project.
# Please keep this list sorted alphabetically.
name-allowlist:
- TraceRecorderSource
- canopennode
- chre
- cmsis
- edtt
- fatfs
- fff
- hal_nordic
- hal_st
- liblc3codec
- libmetal
- littlefs
- loramac-node
- lvgl
- lz4
- mbedtls
- mipi-sys-t
- nanopb
- net-tools
- nrf_hw_models
- open-amp
- picolibc
- psa-arch-tests
- segger
- tinycbor
- tinycrypt
- tf-m-tests
- zcbor
- zscilib
# NCS repositories.
# Some of these are also Zephyr modules which have NCS-specific
# changes.
- name: sdk-hostap
path: modules/lib/hostap
revision: 47399f055431513b5dfcd9d1fd1ec5dc5c96a252
- name: mcuboot
repo-path: sdk-mcuboot
revision: v1.9.99-ncs2
path: bootloader/mcuboot
- name: mbedtls-nrf
path: mbedtls
repo-path: sdk-mbedtls
revision: v3.1.0-ncs1
- name: nrfxlib
repo-path: sdk-nrfxlib
path: nrfxlib
revision: v2.1.0
- name: trusted-firmware-m
repo-path: sdk-trusted-firmware-m
path: modules/tee/tf-m/trusted-firmware-m
revision: v1.6.0-ncs1
- name: tfm-mcuboot # This is used by the trusted-firmware-m module.
path: modules/tee/tfm-mcuboot
revision: v1.7.2-ncs2
- name: matter
repo-path: sdk-connectedhomeip
path: modules/lib/matter
revision: v2.1.0
submodules:
- name: nlio
path: third_party/nlio/repo
- name: nlassert
path: third_party/nlassert/repo
- name: nlunit-test
path: third_party/nlunit-test/repo
- name: pigweed
path: third_party/pigweed/repo
- name: nrf-802154
repo-path: sdk-nrf-802154
path: nrf-802154
revision: v2.1.0
groups:
- nrf-802154
- name: cjson
repo-path: sdk-cjson
path: modules/lib/cjson
revision: c6af068b7f05207b28d68880740e4b9ec1e4b50a
- name: homekit
repo-path: sdk-homekit
revision: v2.1.0
groups:
- homekit
- name: find-my
repo-path: sdk-find-my
revision: v2.1.0
groups:
- find-my
- name: azure-sdk-for-c
repo-path: azure-sdk-for-c
path: modules/lib/azure-sdk-for-c
revision: 308c171cb4b5eed266649012a68406487ec81fb2
# Other third-party repositories.
- name: cmock
path: test/cmock
submodules: true
revision: f65066f15d8248e6dcb778efb8739904a4512087
remote: throwtheswitch
- name: memfault-firmware-sdk
path: modules/lib/memfault-firmware-sdk
revision: 0.33.2
remote: memfault
- name: cirrus
repo-path: sdk-mcu-drivers
path: modules/hal/cirrus-logic
revision: 9f6b3812237fbb0d4157ba3584c13f1644fcbe3a
- name: openthread
repo-path: sdk-openthread
path: modules/lib/openthread
revision: 0d19f9112101e87722ec80b3a247bc7a1c54b232
- name: pcf85063a
revision: master
remote: circuitdojo
# West-related configuration for the nrf repository.
self:
# This repository should be cloned to ncs/nrf.
path: nrf
# This line configures west extensions.
west-commands: scripts/west-commands.yml`
