Thanks for your replies.
I haven’t altered nfed/west.yml, but here it is:
# Import requirements for nRF9160 Feather Examples and Drivers
manifest:
remotes:
- name: nrfconnect
projects:
- name: nrf
repo-path: sdk-nrf
remote: nrfconnect
revision: v2.2.0
import:
name-blocklist:
- matter
- nrf-802154
- cjson
- openthread
- cmock
- unity
- cddl-gen
- homekit
- loramac-node
- lz4
- lvgl
- mipi-sys-t
# Golioth backend
- name: golioth
path: modules/lib/golioth
revision: 9e02125bffff0c0377595f3e05c30e40d1d2cb1b
url: https://github.com/golioth/golioth-zephyr-sdk
import: west-external.yml
# Pyrinas backend
- name: pyrinas
url: https://github.com/pyrinas-iot/pyrinas-zephyr
revision: v1.7.x
path: pyrinas
import: true
# RTC Driver
- name: pcf85063a
url: https://github.com/circuitdojo/pcf85063a
revision: 81c1c285970df5bbdae945ee0ca12ec56f1886e6
path: pcf85063a
self:
# This repository should be cloned to nrf9160-feather
path: nfed
Serial console output:
Tracking: 0 Using: 0 Unhealthy: 0
Seconds since last fix: 1516
Searching [|]
NMEA strings:
$GPGGA,002517.00,,,,,0,,99.99,,M,,M,,*67
$GPGLL,,,,,002517.00,V,N*4B
$GPGSA,A,1,,,,,,,,,,,,,99.99,99.99,99.99,1*2D
$GPGSV,1,1,0,,,,,,,,,,,,,,,,,1*54
$GPRMC,002517.00,V,,,,,,,060180,,,N,V*09
As for the board connections, I wired GPS antenna to 11 and LTE antenna to 10 as in the picture below. No other hardware connections except power from USB.
And nfed/samples/gps/build/zephyr/.config (first part of it, too large to post in a single message):
# GNSS sample
CONFIG_GNSS_SAMPLE_MODE_CONTINUOUS=y
# CONFIG_GNSS_SAMPLE_MODE_PERIODIC is not set
# CONFIG_GNSS_SAMPLE_MODE_TTFF_TEST is not set
# CONFIG_GNSS_SAMPLE_NMEA_ONLY is not set
# end of GNSS sample
CONFIG_GNSS_SAMPLE_ASSISTANCE_NONE=y
# CONFIG_GNSS_SAMPLE_ASSISTANCE_NRF_CLOUD is not set
# CONFIG_GNSS_SAMPLE_ASSISTANCE_SUPL is not set
# CONFIG_GNSS_SAMPLE_ASSISTANCE_MINIMAL is not set
CONFIG_GNSS_SAMPLE_POWER_SAVING_DISABLED=y
# CONFIG_GNSS_SAMPLE_POWER_SAVING_MODERATE is not set
# CONFIG_GNSS_SAMPLE_POWER_SAVING_HIGH is not set
CONFIG_GNSS_SAMPLE_REFERENCE_LATITUDE=""
CONFIG_GNSS_SAMPLE_REFERENCE_LONGITUDE=""
# CONFIG_GNSS_SAMPLE_LOW_ACCURACY is not set
# Zephyr Kernel
CONFIG_GPIO=y
# CONFIG_KSCAN is not set
# CONFIG_WIFI is not set
# CONFIG_NET_L2_ETHERNET is not set
# CONFIG_SPI is not set
CONFIG_GPIO_INIT_PRIORITY=40
# CONFIG_MODEM is not set
CONFIG_NET_IPV6=y
# CONFIG_NET_CONFIG_NEED_IPV6 is not set
# CONFIG_I2C is not set
# CONFIG_SENSOR is not set
CONFIG_BOARD="circuitdojo_feather_nrf9160"
CONFIG_BUILD_WITH_TFM=y
CONFIG_TFM_FLASH_MERGED_BINARY=y
CONFIG_FLASH_LOAD_SIZE=0x40000
CONFIG_FLASH_LOAD_OFFSET=0x40000
CONFIG_SOC="nRF9160_SICA"
CONFIG_SOC_SERIES="nrf91"
CONFIG_NUM_IRQS=65
CONFIG_SYS_CLOCK_HW_CYCLES_PER_SEC=32768
CONFIG_CLOCK_CONTROL_INIT_PRIORITY=30
CONFIG_FLASH_SIZE=1024
CONFIG_FLASH_BASE_ADDRESS=0x0
CONFIG_ICACHE_LINE_SIZE=32
CONFIG_DCACHE_LINE_SIZE=32
CONFIG_HEAP_MEM_POOL_SIZE=2048
CONFIG_ROM_START_OFFSET=0
CONFIG_PINCTRL=y
# CONFIG_WATCHDOG is not set
# CONFIG_RESET is not set
CONFIG_CLOCK_CONTROL=y
CONFIG_SOC_HAS_TIMING_FUNCTIONS=y
CONFIG_ARCH_HAS_CUSTOM_BUSY_WAIT=y
CONFIG_PM=y
# CONFIG_PM_DEVICE is not set
CONFIG_LOG_DOMAIN_NAME=""
CONFIG_NRF_RTC_TIMER=y
CONFIG_SYS_CLOCK_TICKS_PER_SEC=32768
CONFIG_BUILD_OUTPUT_HEX=y
CONFIG_SERIAL_INIT_PRIORITY=55
CONFIG_FPU=y
# CONFIG_MBEDTLS is not set
# CONFIG_CODE_DATA_RELOCATION is not set
# CONFIG_CPU_HAS_CUSTOM_FIXED_SOC_MPU_REGIONS is not set
# CONFIG_TINYCRYPT is not set
# CONFIG_NET_L2_IEEE802154 is not set
CONFIG_SERIAL=y
CONFIG_MAIN_STACK_SIZE=4096
# CONFIG_SRAM_VECTOR_TABLE is not set
CONFIG_MCUBOOT_EXTRA_IMGTOOL_ARGS=""
CONFIG_MP_MAX_NUM_CPUS=1
CONFIG_PLATFORM_SPECIFIC_INIT=y
CONFIG_HAS_DTS=y
# Devicetree Info
CONFIG_DT_HAS_ADAFRUIT_FEATHER_HEADER_ENABLED=y
CONFIG_DT_HAS_ARM_ARMV8M_MPU_ENABLED=y
CONFIG_DT_HAS_ARM_CORTEX_M33F_ENABLED=y
CONFIG_DT_HAS_ARM_V8M_NVIC_ENABLED=y
CONFIG_DT_HAS_FIXED_PARTITIONS_ENABLED=y
CONFIG_DT_HAS_GPIO_KEYS_ENABLED=y
CONFIG_DT_HAS_GPIO_LEDS_ENABLED=y
CONFIG_DT_HAS_JEDEC_SPI_NOR_ENABLED=y
CONFIG_DT_HAS_MMIO_SRAM_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_CC310_SW_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_CLOCK_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_DPPIC_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_EGU_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_GPIO_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_GPIOTE_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_IPC_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_KMU_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_PINCTRL_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_POWER_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_PWM_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_REGULATORS_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_RTC_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_SAADC_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_SPIM_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_TIMER_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_TWIM_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_UARTE_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_VMC_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_WDT_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF91_FLASH_CONTROLLER_ENABLED=y
CONFIG_DT_HAS_PWM_LEDS_ENABLED=y
CONFIG_DT_HAS_REGULATOR_FIXED_ENABLED=y
CONFIG_DT_HAS_SOC_NV_FLASH_ENABLED=y
CONFIG_DT_HAS_ST_LIS2DH_ENABLED=y
CONFIG_DT_HAS_VOLTAGE_DIVIDER_ENABLED=y
CONFIG_DT_HAS_ZEPHYR_BT_HCI_ENTROPY_ENABLED=y
# end of Devicetree Info
# Modules
# Available modules.
# nfed (C:/ncs/Repositories/Feather/nfed)
# nRF9160 Feather
# Device Drivers
# CONFIG_EXAMPLE_JSON_CODEC_ENABLE is not set
# end of nRF9160 Feather
CONFIG_ZEPHYR_NFED_MODULE=y
# end of nfed (C:/ncs/Repositories/Feather/nfed)
# nrf (C:/ncs/Repositories/Feather/nrf)
CONFIG_NEWLIB_LIBC_NANO=y
CONFIG_NUM_METAIRQ_PRIORITIES=0
CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=1536
# CONFIG_INIT_STACKS is not set
CONFIG_NET_IPV6_NBR_CACHE=y
CONFIG_NET_IPV6_MLD=y
CONFIG_NET_PKT_RX_COUNT=4
CONFIG_NET_PKT_TX_COUNT=4
# CONFIG_MBEDTLS_CIPHER_MODE_CBC is not set
# CONFIG_MBEDTLS_CIPHER_MODE_CTR is not set
CONFIG_MBEDTLS_CIPHER_MODE_CFB=y
CONFIG_MBEDTLS_CIPHER_MODE_OFB=y
# CONFIG_MBEDTLS_CHACHA20_C is not set
# CONFIG_MBEDTLS_POLY1305_C is not set
# CONFIG_MBEDTLS_DHM_C is not set
CONFIG_MBEDTLS_RSA_C=y
CONFIG_MBEDTLS_SHA512_C=y
# CONFIG_MBEDTLS_GCM_C is not set
# CONFIG_MBEDTLS_CIPHER_MODE_XTS is not set
CONFIG_MBEDTLS_PSA_CRYPTO_EXTERNAL_RNG=y
# CONFIG_NET_PKT_TXTIME is not set
# CONFIG_NET_PKT_TIMESTAMP is not set
# Nordic nRF Connect
CONFIG_MBEDTLS_LIBRARY_NRF_SECURITY=y
CONFIG_WARN_EXPERIMENTAL=y
CONFIG_PRIVILEGED_STACK_SIZE=1024
CONFIG_ENTROPY_GENERATOR=y
CONFIG_INIT_ARCH_HW_AT_BOOT=y
CONFIG_LINKER_LAST_SECTION_ID=y
CONFIG_NORDIC_QSPI_NOR_FLASH_LAYOUT_PAGE_SIZE=4096
# CONFIG_NCS_SAMPLES_DEFAULTS is not set
CONFIG_LOG_DEFAULT_LEVEL=3
# Image build variants
# CONFIG_NCS_MCUBOOT_IN_BUILD is not set
# end of Image build variants
# Bootloader
# CONFIG_BUILD_S1_VARIANT is not set
# CONFIG_SECURE_BOOT is not set
CONFIG_PM_PARTITION_SIZE_PROVISION=0x280
# CONFIG_B0_MIN_PARTITION_SIZE is not set
CONFIG_PM_PARTITION_SIZE_B0_IMAGE=0x8000
# CONFIG_SECURE_BOOT_CRYPTO is not set
# Secure Boot firmware validation
CONFIG_SB_VALIDATION_INFO_MAGIC=0x86518483
CONFIG_SB_VALIDATION_POINTER_MAGIC=0x6919b47e
CONFIG_SB_VALIDATION_INFO_CRYPTO_ID=1
CONFIG_SB_VALIDATION_INFO_VERSION=2
CONFIG_SB_VALIDATION_METADATA_OFFSET=0
CONFIG_SB_VALIDATE_FW_SIGNATURE=y
# end of Secure Boot firmware validation
# end of Bootloader
# Bluetooth Low Energy
# BLE over nRF RPC
# end of BLE over nRF RPC
# end of Bluetooth Low Energy
# DFU
# CONFIG_DFU_MULTI_IMAGE is not set
# CONFIG_DFU_TARGET is not set
# end of DFU
# CONFIG_ESB is not set
# Peripheral CPU DFU (PCD)
# CONFIG_PCD is not set
# CONFIG_PCD_APP is not set
# CONFIG_PCD_NET is not set
# end of Peripheral CPU DFU (PCD)
# Networking
# Application protocols
# nRF Cloud
# Client ID (nRF Cloud Device ID)
CONFIG_NRF_CLOUD_CLIENT_ID_SRC_IMEI=y
# CONFIG_NRF_CLOUD_CLIENT_ID_SRC_COMPILE_TIME is not set
CONFIG_NRF_CLOUD_CLIENT_ID_PREFIX="nrf-"
# end of Client ID (nRF Cloud Device ID)
# CONFIG_NRF_CLOUD_MQTT is not set
# CONFIG_NRF_CLOUD_FOTA is not set
# CONFIG_NRF_CLOUD_FOTA_FULL_MODEM_UPDATE is not set
# CONFIG_NRF_CLOUD_REST is not set
# CONFIG_NRF_CLOUD_GATEWAY is not set
# CONFIG_NRF_CLOUD_LOG_LEVEL_OFF is not set
# CONFIG_NRF_CLOUD_LOG_LEVEL_ERR is not set
# CONFIG_NRF_CLOUD_LOG_LEVEL_WRN is not set
CONFIG_NRF_CLOUD_LOG_LEVEL_INF=y
# CONFIG_NRF_CLOUD_LOG_LEVEL_DBG is not set
CONFIG_NRF_CLOUD_LOG_LEVEL=3
# end of nRF Cloud
# CONFIG_REST_CLIENT is not set
# CONFIG_DOWNLOAD_CLIENT is not set
# CONFIG_AWS_IOT is not set
# CONFIG_AWS_JOBS is not set
# CONFIG_AZURE_IOT_HUB is not set
# Self-Registration (Zi ZHu Ce)
# CONFIG_ZZHC is not set
# end of Self-Registration (Zi ZHu Ce)
# CONFIG_ICAL_PARSER is not set
# CONFIG_FTP_CLIENT is not set
# CONFIG_COAP_UTILS is not set
# CONFIG_LWM2M_CLIENT_UTILS is not set
# CONFIG_WIFI_CREDENTIALS is not set
# end of Application protocols
# end of Networking
# NFC
# CONFIG_NFC_NDEF is not set
# CONFIG_NFC_NDEF_PARSER is not set
# CONFIG_NFC_NDEF_PAYLOAD_TYPE_COMMON is not set
# CONFIG_NFC_T2T_PARSER is not set
# CONFIG_NFC_T4T_NDEF_FILE is not set
# CONFIG_NFC_T4T_ISODEP is not set
# CONFIG_NFC_T4T_APDU is not set
# CONFIG_NFC_T4T_CC_FILE is not set
# CONFIG_NFC_T4T_HL_PROCEDURE is not set
# CONFIG_NFC_PLATFORM is not set
# CONFIG_NFC_TNEP_TAG is not set
# CONFIG_NFC_TNEP_POLLER is not set
# CONFIG_NFC_TNEP_CH is not set
# end of NFC
# CONFIG_APP_EVENT_MANAGER is not set
# Trusted Execution Non-Secure
# TF-M UART pins
# CONFIG_TFM_SECURE_UART1 is not set
CONFIG_TFM_UART0_TXD_PIN=4294967295
CONFIG_TFM_UART0_RXD_PIN=4294967295
CONFIG_TFM_UART0_RTS_PIN=4294967295
CONFIG_TFM_UART0_CTS_PIN=4294967295
# end of TF-M UART pins
# Peripheral Secure mapping
# CONFIG_NRF_FPU_SECURE is not set
# CONFIG_NRF_REGULATORS_SECURE is not set
# CONFIG_NRF_CLOCK_SECURE is not set
# CONFIG_NRF_POWER_SECURE is not set
# CONFIG_NRF_SPIM0_SECURE is not set
# CONFIG_NRF_TWIM0_SECURE is not set
# CONFIG_NRF_UARTE0_SECURE is not set
# CONFIG_NRF_SPIM1_SECURE is not set
# CONFIG_NRF_TWIM1_SECURE is not set
# CONFIG_NRF_UARTE1_SECURE is not set
# CONFIG_NRF_SPIM2_SECURE is not set
# CONFIG_NRF_TWIM2_SECURE is not set
# CONFIG_NRF_UARTE2_SECURE is not set
# CONFIG_NRF_SPIM3_SECURE is not set
# CONFIG_NRF_TWIM3_SECURE is not set
# CONFIG_NRF_UARTE3_SECURE is not set
# CONFIG_NRF_SAADC_SECURE is not set
# CONFIG_NRF_TIMER0_SECURE is not set
# CONFIG_NRF_TIMER1_SECURE is not set
# CONFIG_NRF_TIMER2_SECURE is not set
# CONFIG_NRF_RTC0_SECURE is not set
# CONFIG_NRF_RTC1_SECURE is not set
# CONFIG_NRF_DPPI_SECURE is not set
# CONFIG_NRF_WDT0_SECURE is not set
# CONFIG_NRF_EGU0_SECURE is not set
# CONFIG_NRF_EGU1_SECURE is not set
# CONFIG_NRF_EGU2_SECURE is not set
# CONFIG_NRF_EGU3_SECURE is not set
# CONFIG_NRF_EGU4_SECURE is not set
# CONFIG_NRF_EGU5_SECURE is not set
# CONFIG_NRF_PWM0_SECURE is not set
# CONFIG_NRF_PWM1_SECURE is not set
# CONFIG_NRF_PWM2_SECURE is not set
# CONFIG_NRF_PWM3_SECURE is not set
# CONFIG_NRF_PDM_SECURE is not set
# CONFIG_NRF_I2S_SECURE is not set
# CONFIG_NRF_IPC_SECURE is not set
# CONFIG_NRF_NVMC_SECURE is not set
# CONFIG_NRF_GPIO0_SECURE is not set
# CONFIG_NRF_VMC_SECURE is not set
# CONFIG_NRF_GPIOTE0_SECURE is not set
CONFIG_NRF_GPIO0_PIN_MASK_SECURE=0x00000000
CONFIG_NRF_DPPI_CHANNEL_MASK_SECURE=0x00000000
# end of Peripheral Secure mapping
# end of Trusted Execution Non-Secure
# CONFIG_NRF_PROFILER is not set
# SPM
# CONFIG_IS_SPM is not set
# end of SPM
# CONFIG_FW_INFO is not set
# Debug
# CONFIG_PPI_TRACE is not set
# CONFIG_CPU_LOAD is not set
# end of Debug
# CONFIG_MPSL_FEM_DEVICE_CONFIG_254 is not set
# CONFIG_MPSL_FEM_LOG_LEVEL_OFF is not set
# CONFIG_MPSL_FEM_LOG_LEVEL_ERR is not set
# CONFIG_MPSL_FEM_LOG_LEVEL_WRN is not set
CONFIG_MPSL_FEM_LOG_LEVEL_INF=y
# CONFIG_MPSL_FEM_LOG_LEVEL_DBG is not set
CONFIG_MPSL_FEM_LOG_LEVEL=3
CONFIG_MPSL_THREAD_COOP_PRIO=8
CONFIG_MPSL_WORK_STACK_SIZE=1024
CONFIG_MPSL_TIMESLOT_SESSION_COUNT=0
# CONFIG_MPSL_ASSERT_HANDLER is not set
# CONFIG_MPSL_LOG_LEVEL_OFF is not set
# CONFIG_MPSL_LOG_LEVEL_ERR is not set
# CONFIG_MPSL_LOG_LEVEL_WRN is not set
CONFIG_MPSL_LOG_LEVEL_INF=y
# CONFIG_MPSL_LOG_LEVEL_DBG is not set
CONFIG_MPSL_LOG_LEVEL=3
# Partition Manager
CONFIG_PARTITION_MANAGER_ENABLED=y
CONFIG_FLASH_MAP_CUSTOM=y
CONFIG_SRAM_SIZE=128
CONFIG_SRAM_BASE_ADDRESS=0x20020000
# Zephyr subsystem configurations
# end of Zephyr subsystem configurations
# NCS subsystem configurations
CONFIG_PM_SINGLE_IMAGE=y
CONFIG_PM_EXTERNAL_FLASH_BASE=0
# CONFIG_PM_OVERRIDE_EXTERNAL_DRIVER_CHECK is not set
CONFIG_PM_SRAM_BASE=0x20000000
CONFIG_PM_SRAM_SIZE=0x40000
# end of Partition Manager
# nRF RPC (Remote Procedure Call) library
# end of nRF RPC (Remote Procedure Call) library
# Full Modem Firmware Update Management(FMFU)
# CONFIG_MGMT_FMFU_LOG_LEVEL_OFF is not set
# CONFIG_MGMT_FMFU_LOG_LEVEL_ERR is not set
# CONFIG_MGMT_FMFU_LOG_LEVEL_WRN is not set
CONFIG_MGMT_FMFU_LOG_LEVEL_INF=y
# CONFIG_MGMT_FMFU_LOG_LEVEL_DBG is not set
CONFIG_MGMT_FMFU_LOG_LEVEL=3
# end of Full Modem Firmware Update Management(FMFU)
# CONFIG_CAF is not set
# Nordic IEEE 802.15.4
# end of Nordic IEEE 802.15.4
# CONFIG_DM_MODULE is not set
CONFIG_TFM_BOARD="C:/ncs/Repositories/Feather/nrf/modules/tfm/tfm/boards/nrf9160"
# Libraries
# Binary libraries
# end of Binary libraries
CONFIG_NRF_MODEM_LIB=y
CONFIG_NRF_MODEM_LIB_SYS_INIT=y
# CONFIG_NRF_MODEM_LIB_TRACE is not set
# Interrupt priorities
# CONFIG_NRF_MODEM_LIB_IPC_IRQ_PRIO_OVERRIDE is not set
CONFIG_NRF_MODEM_LIB_IPC_IRQ_PRIO=1
# end of Interrupt priorities
CONFIG_NRF_MODEM_LIB_ON_FAULT_DO_NOTHING=y
# CONFIG_NRF_MODEM_LIB_ON_FAULT_RESET_MODEM is not set
# CONFIG_NRF_MODEM_LIB_ON_FAULT_APPLICATION_SPECIFIC is not set
# Heap and buffers
CONFIG_NRF_MODEM_LIB_HEAP_SIZE=1024
CONFIG_NRF_MODEM_LIB_SHMEM_CTRL_SIZE=0x4e8
CONFIG_NRF_MODEM_LIB_SHMEM_TX_SIZE=8192
CONFIG_NRF_MODEM_LIB_SHMEM_RX_SIZE=8192
CONFIG_NRF_MODEM_LIB_SHMEM_TRACE_SIZE=0
CONFIG_NRF_MODEM_LIB_SENDMSG_BUF_SIZE=128
# CONFIG_NRF_MODEM_LIB_MEM_DIAG is not set
# Logging
# CONFIG_NRF_MODEM_LIB_LOG_FW_VERSION_UUID is not set
# CONFIG_NRF_MODEM_LIB_LOG_LEVEL_OFF is not set
# CONFIG_NRF_MODEM_LIB_LOG_LEVEL_ERR is not set
# CONFIG_NRF_MODEM_LIB_LOG_LEVEL_WRN is not set
CONFIG_NRF_MODEM_LIB_LOG_LEVEL_INF=y
# CONFIG_NRF_MODEM_LIB_LOG_LEVEL_DBG is not set
CONFIG_NRF_MODEM_LIB_LOG_LEVEL=3
# Deprecated
# CONFIG_NRF_MODEM_LIB_TRACE_ENABLED is not set
# CONFIG_ADP536X is not set
CONFIG_AT_MONITOR=y
CONFIG_AT_MONITOR_HEAP_SIZE=256
# CONFIG_AT_MONITOR_LOG_LEVEL_OFF is not set
# CONFIG_AT_MONITOR_LOG_LEVEL_ERR is not set
# CONFIG_AT_MONITOR_LOG_LEVEL_WRN is not set
CONFIG_AT_MONITOR_LOG_LEVEL_INF=y
# CONFIG_AT_MONITOR_LOG_LEVEL_DBG is not set
CONFIG_AT_MONITOR_LOG_LEVEL=3
CONFIG_LTE_LINK_CONTROL=y
# CONFIG_LTE_AUTO_INIT_AND_CONNECT is not set
# CONFIG_LTE_LOCK_BANDS is not set
# CONFIG_LTE_LOCK_PLMN is not set
# CONFIG_LTE_UNLOCK_PLMN is not set
CONFIG_LTE_PSM_REQ_RPTAU="00101000"
CONFIG_LTE_PSM_REQ_RAT="00000011"
CONFIG_LTE_EDRX_REQ=y
CONFIG_LTE_EDRX_REQ_VALUE_LTE_M="1001"
CONFIG_LTE_EDRX_REQ_VALUE_NBIOT="1001"
CONFIG_LTE_PTW_VALUE_LTE_M=""
CONFIG_LTE_PTW_VALUE_NBIOT=""
# CONFIG_LTE_NETWORK_DEFAULT is not set
# CONFIG_LTE_NETWORK_MODE_LTE_M is not set
CONFIG_LTE_NETWORK_MODE_LTE_M_GPS=y
# CONFIG_LTE_NETWORK_MODE_NBIOT is not set
# CONFIG_LTE_NETWORK_MODE_NBIOT_GPS is not set
# CONFIG_LTE_NETWORK_MODE_LTE_M_NBIOT is not set
# CONFIG_LTE_NETWORK_MODE_LTE_M_NBIOT_GPS is not set
CONFIG_LTE_MODE_PREFERENCE_AUTO=y
# CONFIG_LTE_MODE_PREFERENCE_LTE_M is not set
# CONFIG_LTE_MODE_PREFERENCE_LTE_M_PLMN_PRIO is not set
CONFIG_LTE_MODE_PREFERENCE=0
CONFIG_LTE_RAI_REQ_VALUE="0"
CONFIG_LTE_NETWORK_USE_FALLBACK=y
CONFIG_LTE_NETWORK_TIMEOUT=600
# CONFIG_LTE_LC_TAU_PRE_WARNING_NOTIFICATIONS is not set
CONFIG_LTE_LC_TAU_PRE_WARNING_TIME_MS=5000
CONFIG_LTE_LC_TAU_PRE_WARNING_THRESHOLD_MS=1200000
CONFIG_LTE_NEIGHBOR_CELLS_MAX=10
# CONFIG_LTE_LC_MODEM_SLEEP_NOTIFICATIONS is not set
CONFIG_LTE_LC_MODEM_SLEEP_PRE_WARNING_TIME_MS=5000
CONFIG_LTE_LC_MODEM_SLEEP_NOTIFICATIONS_THRESHOLD_MS=1200000
# CONFIG_LTE_LC_TRACE is not set
# CONFIG_LTE_LINK_CONTROL_LOG_LEVEL_OFF is not set
# CONFIG_LTE_LINK_CONTROL_LOG_LEVEL_ERR is not set
# CONFIG_LTE_LINK_CONTROL_LOG_LEVEL_WRN is not set
CONFIG_LTE_LINK_CONTROL_LOG_LEVEL_INF=y
# CONFIG_LTE_LINK_CONTROL_LOG_LEVEL_DBG is not set
CONFIG_LTE_LINK_CONTROL_LOG_LEVEL=3
CONFIG_NRF_SPU_FLASH_REGION_SIZE=0x8000
CONFIG_FPROTECT_BLOCK_SIZE=0x8000
# CONFIG_FPROTECT is not set
# CONFIG_AT_CUSTOM_CMD is not set
CONFIG_AT_HOST_LIBRARY=y
CONFIG_AT_HOST_UART_INIT_TIMEOUT=500
# CONFIG_NULL_TERMINATION is not set
CONFIG_CR_TERMINATION=y
# CONFIG_LF_TERMINATION is not set
# CONFIG_CR_LF_TERMINATION is not set
CONFIG_AT_HOST_TERMINATION=1
CONFIG_AT_HOST_CMD_MAX_LEN=4096
CONFIG_AT_HOST_THREAD_PRIO=10
# CONFIG_AT_HOST_LOG_LEVEL_OFF is not set
# CONFIG_AT_HOST_LOG_LEVEL_ERR is not set
# CONFIG_AT_HOST_LOG_LEVEL_WRN is not set
CONFIG_AT_HOST_LOG_LEVEL_INF=y
# CONFIG_AT_HOST_LOG_LEVEL_DBG is not set
CONFIG_AT_HOST_LOG_LEVEL=3
# CONFIG_DK_LIBRARY is not set
CONFIG_AT_CMD_PARSER=y
# CONFIG_MODEM_INFO is not set
# CONFIG_PDN is not set
CONFIG_RESET_ON_FATAL_ERROR=y
# CONFIG_FATAL_ERROR_LOG_LEVEL_OFF is not set
# CONFIG_FATAL_ERROR_LOG_LEVEL_ERR is not set
# CONFIG_FATAL_ERROR_LOG_LEVEL_WRN is not set
CONFIG_FATAL_ERROR_LOG_LEVEL_INF=y
# CONFIG_FATAL_ERROR_LOG_LEVEL_DBG is not set
CONFIG_FATAL_ERROR_LOG_LEVEL=3
# CONFIG_SMS is not set
# CONFIG_GCF_SMS is not set
# CONFIG_MODEM_KEY_MGMT is not set
# CONFIG_SUPL_CLIENT_LIB is not set
# CONFIG_DATE_TIME is not set
# CONFIG_HW_ID_LIBRARY is not set
# CONFIG_WAVE_GEN_LIB is not set
CONFIG_HW_UNIQUE_KEY_PARTITION_SIZE=0
# CONFIG_MODEM_JWT is not set
# CONFIG_MODEM_ATTEST_TOKEN is not set
# CONFIG_MULTICELL_LOCATION is not set
# CONFIG_LOCATION is not set
CONFIG_MODEM_ANTENNA=y
CONFIG_MODEM_ANTENNA_GNSS_ONBOARD=y
# CONFIG_MODEM_ANTENNA_GNSS_EXTERNAL is not set
CONFIG_MODEM_ANTENNA_AT_MAGPIO=""
CONFIG_MODEM_ANTENNA_AT_COEX0="AT%XCOEX0=1,1,1565,1586"
# CONFIG_MODEM_ANTENNA_LOG_LEVEL_OFF is not set
# CONFIG_MODEM_ANTENNA_LOG_LEVEL_ERR is not set
# CONFIG_MODEM_ANTENNA_LOG_LEVEL_WRN is not set
CONFIG_MODEM_ANTENNA_LOG_LEVEL_INF=y
# CONFIG_MODEM_ANTENNA_LOG_LEVEL_DBG is not set
CONFIG_MODEM_ANTENNA_LOG_LEVEL=3
# CONFIG_QOS is not set
# CONFIG_SFLOAT is not set
# end of Libraries
