Also, just a thought - Not sure if it’s relevant for others, or if the cost is going to be higher, but a 16bit ADC instead of the 12bit one currently on would be great 🙂 I’m currently connecting adafruits ADS1115 to get that additional resolution 🙂
Get really more than 12 bits from a ADC isn’t easy in my experience.
And sometimes it requires an additional amplification. So I’m not sure, how many will then be happy with it.
Not sure if you guys have had this issue but modem traces don’t work well with non-Nordic devices since a while back. (The nRF9161 Feather will only have one USB-UART port)
Working on a PR for the Cellular Monitor so it can use any available port on your machine.
Great little tool especially to find out that these devices are no longer being pre-programmed with IMEIs! I will be pre-programming them here so no worries about that.
Nice thing is both the onboard LNA works for GPS. A single antenna is all that’s needed for the nRF9161 Feather!
Tracking:  5 Using:  5 Unhealthy: 0
Latitude:       41.XXX
Longitude:      -72.XXX
Altitude:       89.0 m
Accuracy:       10.0 m
Speed:          0.3 m/s
Speed accuracy: 1.2 m/s
Heading:        0.0 deg
Date:           2024-07-23
Time (UTC):     20:19:55.091
PDOP:           5.1
HDOP:           2.6
VDOP:           4.4
TDOP:           3.7
Another very cool thing that the nPM1300 includes is an extremely low power mode which replicates what I did in the early designs of the nRF9160 Feather: deep powerdown/hibernate.
Here’s the measurement of the nRF9161 Feather in hibernate. About 600nA!
On the Joulscope it’s actually a little less on avg (~300nA) :
Does this mean, the nRF9161 is power off?
If so, how does it power on again?
Great question @AchimKraus!
There’s an internal timer on the nPM1300 which allows to shut down all regulators and then powers them back on after a certain time interval. I was testing every 10 seconds but I’m sure it can go longer than that. 😃
Also if you insert USB or send a pulse on the EN pin it will also turn on.
6 days later
5 days later
Hey all
I’ll be assembling Proto 3 boards this week and I’d like you to give them a go. They should work nicely on the 2.7.x branch of nfed and the latest Zephyr Tools plugin. If you have time to try one in the immediate future, let me know and we can coordinate outside the thread.
    I guess, it’s easier to ship the new boards within the U.S. than to ship them to Europe ;-).
    Let’s see, which feedback your call gets.
    My own app is still on NCS 2.6.1 and starts supporting the nRF9161-DK. Not sure, if that would also be a setup for testing the new feather. Update my app to 2.7.0 is planed, but for now without timeline.
      AchimKraus I guess, it’s easier to ship the new boards within the U.S. than to ship them to Europe ;-).
      It is but not impossible. I can send it as a sample so it can result in lower/no VAT for you. 😃
      AchimKraus My own app is still on NCS 2.6.1 and starts supporting the nRF9161-DK. Not sure, if that would also be a setup for testing the new feather. Update my app to 2.7.0 is planed, but for now without timeline.
      I did build out the board definition for 2.6.1 as well. I may have to sync it with the 2.7.x branch.
      OK. To make it easier:
      I will order/buy 3 feathers as usual in your shop, you send me 2x feather v6 and 1x new feather nRF9161.
      No need to handle it special as sample or so from my side, the costs are not that high.
      Would that be OK for you?
      That’s OK with me!
      Use the code NRF9161 for some $ off as a thank you. 😃 Everyone else in the thread is also welcome to use the same. I’ll likely have them fully assembled and tested by tomorrow. I’ll also throw in the antenna I’ve been testing with that is specifically designed to work with GPS + LTE.
      Jared
      7 days later
      jaredwolff Hi Jared.
      I should be able to assist in testing the new nRF9161 Feather. I did install NCS 2.7.x a few weeks ago and have moved some of my CLI projects to Zephyr 3.7, although I did have to fix a couple of SSD1306 driver bugs. Also, ended up updating ST7789 displays because of the new MIPI Display Bus Interface (DBI) support in Zephyr 3.7. Anyway, it’s worth updating projects to Zephyr 3.7.x LTS.
      Btw - What debug probe firmware did you end up using on the RP2040 interface MCU?
      I’ll drop you an email later today. Thanks.
