One issue I found:
dfu seems to be broken, at least in my case ;-).
A call to boot_erase_img_bank ends up in an exception and reboot.
Is there already a tested sample? If not, that for short term no issue.
But in mid-term I consider dfu as mandatory.
    AchimKraus DFU shouldn’t be any different from the nRF9160. It’s possible that the partition management side is not configured correctly.
    You may need these guys set to make sure you’re not using external NOR flash:
    # Do not use external flash for secondary
    CONFIG_PM_EXTERNAL_FLASH_MCUBOOT_SECONDARY=n
    CONFIG_PM_PARTITION_REGION_LITTLEFS_EXTERNAL=y
    CONFIG_PM_PARTITION_SIZE_LITTLEFS=0x400000
    CONFIG_PM_OVERRIDE_EXTERNAL_DRIVER_CHECK=y
    For me, zephyr or NCS seems to be fragile for switching static and dynamic pm-partitions. I prefer to use the static pm defined ny Nordic for the Thingy:91. That works for nRF9160 (thingy:91, dk, feather, mikroe) and nRF9161 (so far only for the dk).
    I will try your configs, but “CONFIG_PM_PARTITION_SIZE_LITTLEFS” smeels for me to inhibit switching the pm-partitions.
      Great, using
      already does the trick.
      “nrf/subsys/partition_manager/Kconfig”:
      config PM_EXTERNAL_FLASH_ENABLED
      	bool
      	default $(dt_chosen_enabled,$(DT_CHOSEN_EXT_FLASH))
      	help
      	  Internal PM_EXTERNAL_FLASH kconfig for exporting devicetree to sysbuild.
      seems, that this trigger the usage of the external flash. (Even if for now, I don’t see, where that chose is defined).
      edited:
      get it
      6 days later
      AchimKraus I will try your configs, but “CONFIG_PM_PARTITION_SIZE_LITTLEFS” smeels for me to inhibit switching the pm-partitions.
      Yup that’s fine. I put them all in there. That’s actually the settings for the nRF9160 Feather not the new board.
      Glad you got it going!
      14 days later
      For the curious you’ll need a pm_static.yml entry
      littlefs_storage:
        address: 0x0
        region: external_flash
      New versions of NFED will include pre-defined pm_static.yml controlled by CONFIG_CIRCUITDOJO_FEATHER_NRF9160_STATIC_PARTITIONS_FACTORY which can be disabled. Since that was being sent, pm_static.yml inside the app wasn’t being applied. I’ll have to adjust this for the nRF91×1 as well.
      Adjusted for file size. These config entries
      # SPI Flash
      CONFIG_SPI=y
      CONFIG_SPI_NOR=y
      CONFIG_SPI_NOR_FLASH_LAYOUT_PAGE_SIZE=4096
      CONFIG_SPI_NOR_SFDP_RUNTIME=y
      # Enable flash operations.
      CONFIG_FLASH=y
      CONFIG_FLASH_MAP=y
      CONFIG_FLASH_PAGE_LAYOUT=y
      # Enable the LittleFS file system.
      CONFIG_FILE_SYSTEM=y
      CONFIG_FILE_SYSTEM_LITTLEFS=y
      # Partition manager settings
      Okkk!
      Sorry for the lack of updates. I’ve been waiting for boards plus orders have been keeping Circuit Dojo HQ busy.
      I digress. I mentioned this guy before but the first rev had some issues. A batch of the second version is built and ready to go.
      It works with all Circuit Dojo Feather boards. (nRF91xx, nRF52833 (unreleased), etc) and supports use of the Raspberry Pi Debug Probe and 10-pin Segger JLink interface. I even went the extra step to bring out the reset pin for the 10-pin 😉
      Here’s the bottom:
      I imagine this would be good for mass programming and also de-borking boards if you do something silly.
      The design will be open sourced at the launch of the nRF91×1 Feather. I’ll have more on that shortly. For those folks who are looking for early samples I should have some this week as long as assembly & testing works out OK.
      Great news. How can it be ordered?
      Just to mention:
      The nRF9161 feather (beta) board shipped in August works pretty well. Stable online now for more than 30days.
        14 days later
        Lots going on here! I’m working on updating my test fixtures as an all-in-one. The first step is to transition the 1-up fixture and then the 9 up fixture.
        I’m also just about ready to send boards over for RF testing. I will also have more boards for more beta/field testing. 😃 So for those who reached out to me, I haven’t forgotten about you.
        More very soon.
        24 days later
        Things are coming together with the all-in-one 1-up tester.
        It looks like what I designed which is a plus 😃. It will do all testing that I was previously doing across 3 test stations.
        I also have some other news regarding the new board. Since the nRF9151 is fresh off the production line I decided to modify the nRF9161 Design to accommodate the new SiP.
        It has the same features and functionality of the original design plus some room to grow as Nordic continues to develop on the platform. A few should be going out for FCC/CE next week if all goes well. The rest will be up for grabs once the tester is 100%.
          Fantastic! I was going to suggest the same, i.e. replace nRF9161 with a nRF9151. The latter now being Nordic Semi’s preferred recommendation for all new nRF91 designs. More real estate for you to add components , for example - accelerometers and microphone for Edge AI or a 10-pin mini-SWD connecter.
          The new test fixture looks impressive. A significant boost to your testing.
          btw - I’ve been field testing nRF9131-EK for DECT NR+ and LTE-M/NB-IoT with GNSS. A very neat board, slightly longer than a Sparkfun Thing+ board, with nPM1300, nPM600, 256Mb external flash memory, and a Segger J-link OB. There are a few more enhancements coming down the line to make it even better.
            Just to mention: the nRF9161 prototype does a pretty well job on my side. Works since August without issues.
            The pin VUSB is power input from USB? So it’s possible to power the device via that pin, if no USB is connected?
              zpm1066 btw - I’ve been field testing nRF9131-EK for DECT NR+ and LTE-M/NB-IoT with GNSS. A very neat board, slightly longer than a Sparkfun Thing+ board, with nPM1300, nPM600, 256Mb external flash memory, and a Segger J-link OB. There are a few more enhancements coming down the line to make it even better.
              I believe the 9131 does require more certification testing in order to legal deploy devices that use it. Versus the 9160, 9161 and 9151.
              AchimKraus Is there an update on the pyocd issue?
              I have not made progress. I’ve been focusing elsewhere. I have been playing with using probe-rs instead as it has been added as a target recently for Zephyr. I ported the pyocd code that updates the modem firmware also to use probe-rs (and using it in production). So I’m leaning to use that.
              That’s amazing to hear. Thank you for testing it @AchimKraus !
              AchimKraus The pin VUSB is power input from USB? So it’s possible to power the device via that pin, if no USB is connected?
              VUSB is connected direct to the headers so you could power the device through the pin:
              I have not tested if it plays well with USB. (it may work just fine) I typically recommend using VBAT pin for external power and turning the charger off. It depends on your application though.
                jaredwolff I believe the 9131 does require more certification testing in order to legal deploy devices that use it. Versus the 9160, 9161 and 9151.
                Agreed. The nRF9151 is the sanction proof nRF91 and what Nordic Semi recommends for all new cellular designs.
                The nRF9131-EK is a very goodcompact reference design for DECT NR+ and LTE with J-Link OB that can be used as a dev board if the additional expansion offered by nRF9151-DK is not required.
                  zpm1066 The nRF9131-EK is a very goodcompact reference design for DECT NR+ and LTE with J-Link OB that can be used as a dev board if the additional expansion offered by nRF9151-DK is not required.
                  Oh yea. Feather-ish formfactor. Didn’t realize they had something this small. Good on them.
                  Great! Do you currently have a schedule for the nRF9151 feather (beta-boards)?
