I have some successes and failures. I wanted to say the tracker sample you made is a tour de force, really good work.
My question is: what is a good sample to begin with for sockets? It can be any github. The reason I want to use sockets, is Hologram charges more for SMS, and https sends a lot more data I am charged for, but don’t need.
The https sample did work for me. I currently trying to modify it to use a socket. The changes look as simple as replacing one line:
this: ret = http_client_req(fd, &req, timeout, NULL);
with this: ssize_t plength = zsock_send(fd, msg, sizeof(msg), 0);
However, I haven’t got that far because I am now getting these connection errors - “connect() function”. Sometimes a timeout, bad argument, refused, etc. The cause could be Hologram.
Ona side note. The sms sample was failing with uninitiailized modem. I put in a manual call and that fixed it. I swapped in the the blocking call “nrf_modem_at_cmd()” and that fixed my other issue.
In the https sample, I changing the json for Hologram. The fw then rebooted at the connection call. I took out all the cJSON calls out and just formatting the json string, and no more resets. I might be using the cJSON API wrong though.
//my code
cJSON *obj = cJSON_CreateObject();
cJSON_AddStringToObject(obj, "devicekey", data->devicekey);
cJSON_AddStringToObject(obj, "data", data->payload);
cJSON_AddStringToObject(obj, "tags", data->topic0);
char *msg = cJSON_PrintUnformatted(obj);
cJSON_Delete(obj);
    bweiler @bweiler looks like you already found the sample that I was going to suggest since it sets up a socket before the HTTP “client” uses it. You can read and write raw bytes to your established socket if you’re looking to roll your own protocol.
    Some other protocol and data schemes to look into include CoAP and CBOR.
