Thank you for your prompt response.
I got the files from the Github link you supplied.
I unpacked and compiled the “at_client” project.
Compilation result is inserted as a code, I don’t know if I can attach a file, sorry about that.
.../c/ncs/ejercicios/at_client
$ west build -b circuitdojo_feather_nrf9160_ns -p
-- Application: C:/ncs/Ejercicios/at_client
-- CMake version: 3.20.5
-- Using NCS Toolchain 2.5.20231017.848171396279 for building. (C:/ncs/toolchains/c57af46cb7/cmake)
CMake Deprecation Warning at C:/ncs/v2.5.0/zephyr/cmake/modules/FindDeprecated.cmake:121 (message):
'PYTHON_PREFER' variable is deprecated. Please use Python3_EXECUTABLE
instead.
C:/ncs/v2.5.0/zephyr/cmake/modules/python.cmake:16 (find_package)
C:/ncs/v2.5.0/zephyr/cmake/modules/zephyr_default.cmake:129 (include)
C:/ncs/v2.5.0/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:66 (include)
C:/ncs/v2.5.0/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:92 (include_boilerplate)
CMakeLists.txt:11 (find_package)
-- Found Python3: C:/ncs/toolchains/c57af46cb7/opt/bin/python.exe (found suitable version "3.8.2", minimum required is "3.8") found components: Interpreter
-- Cache files will be written to: C:/ncs/v2.5.0/zephyr/.cache
-- Zephyr version: 3.4.99 (C:/ncs/v2.5.0/zephyr)
-- Found west (found suitable version "1.1.0", minimum required is "0.14.0")
-- Found host-tools: zephyr 0.16.1 (C:/ncs/toolchains/c57af46cb7/opt/zephyr-sdk)
-- Found toolchain: zephyr 0.16.1 (C:/ncs/toolchains/c57af46cb7/opt/zephyr-sdk)
-- Found Dtc: C:/ncs/toolchains/c57af46cb7/opt/bin/dtc.exe (found suitable version "1.4.7", minimum required is "1.4.6")
-- Found BOARD.dts: C:/ncs/v2.5.0/zephyr/boards/arm/circuitdojo_feather_nrf9160/circuitdojo_feather_nrf9160_ns.dts
-- Generated zephyr.dts: C:/ncs/Ejercicios/at_client/build/zephyr/zephyr.dts
-- Generated devicetree_generated.h: C:/ncs/Ejercicios/at_client/build/zephyr/include/generated/devicetree_generated.h
-- Including generated dts.cmake file: C:/ncs/Ejercicios/at_client/build/zephyr/dts.cmake
warning: Deprecated symbol NRF_MODEM_LIB_TRACE_BACKEND_UART_ASYNC is enabled.
Parsing C:/ncs/v2.5.0/zephyr/Kconfig
Loaded configuration 'C:/ncs/v2.5.0/zephyr/boards/arm/circuitdojo_feather_nrf9160/circuitdojo_feather_nrf9160_ns_defconfig'
Merged configuration 'C:/ncs/Ejercicios/at_client/prj.conf'
Configuration saved to 'C:/ncs/Ejercicios/at_client/build/zephyr/.config'
Kconfig header saved to 'C:/ncs/Ejercicios/at_client/build/zephyr/include/generated/autoconf.h'
-- Found GnuLd: c:/ncs/toolchains/c57af46cb7/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd.exe (found version "2.38")
-- Found assembler: C:/ncs/toolchains/c57af46cb7/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc.exe
-- Found Python3: C:/ncs/toolchains/c57af46cb7/opt/bin/python.exe (found version "3.8.2") found components: Interpreter
=== child image mcuboot - begin ===
loading initial cache file C:/ncs/Ejercicios/at_client/build/mcuboot/child_image_preload.cmake
-- Application: C:/ncs/v2.5.0/bootloader/mcuboot/boot/zephyr
instead.
CMakeLists.txt:31 (find_package)
-- Found BOARD.dts: C:/ncs/v2.5.0/zephyr/boards/arm/circuitdojo_feather_nrf9160/circuitdojo_feather_nrf9160.dts
-- Found devicetree overlay: C:/ncs/v2.5.0/bootloader/mcuboot/boot/zephyr/app.overlay
-- Generated zephyr.dts: C:/ncs/Ejercicios/at_client/build/mcuboot/zephyr/zephyr.dts
-- Generated devicetree_generated.h: C:/ncs/Ejercicios/at_client/build/mcuboot/zephyr/include/generated/devicetree_generated.h
-- Including generated dts.cmake file: C:/ncs/Ejercicios/at_client/build/mcuboot/zephyr/dts.cmake
warning: UART_CONSOLE (defined at drivers/console/Kconfig:43) was assigned the value 'y' but got the
Parsing C:/ncs/v2.5.0/bootloader/mcuboot/boot/zephyr/Kconfig
Loaded configuration 'C:/ncs/v2.5.0/zephyr/boards/arm/circuitdojo_feather_nrf9160/circuitdojo_feather_nrf9160_defconfig'
Merged configuration 'C:/ncs/v2.5.0/bootloader/mcuboot/boot/zephyr/prj.conf'
Merged configuration 'C:/ncs/v2.5.0/bootloader/mcuboot/boot/zephyr/boards/circuitdojo_feather_nrf9160.conf'
Merged configuration 'C:/ncs/v2.5.0/nrf/modules/mcuboot/tfm.conf'
Merged configuration 'C:/ncs/v2.5.0/nrf/modules/mcuboot/fih_low_enable.conf'
Merged configuration 'C:/ncs/v2.5.0/nrf/subsys/partition_manager/partition_manager_enabled.conf'
Merged configuration 'C:/ncs/Ejercicios/at_client/build/mcuboot/zephyr/misc/generated/extra_kconfig_options.conf'
Configuration saved to 'C:/ncs/Ejercicios/at_client/build/mcuboot/zephyr/.config'
Kconfig header saved to 'C:/ncs/Ejercicios/at_client/build/mcuboot/zephyr/include/generated/autoconf.h'
MCUBoot bootloader key file: C:/ncs/v2.5.0/bootloader/mcuboot/root-ec-p256.pem
-- Configuring done
-- Generating done
-- Build files have been written to: C:/ncs/Ejercicios/at_client/build/mcuboot
=== child image mcuboot - end ===
CMake Warning at C:/ncs/v2.5.0/nrf/modules/mcuboot/CMakeLists.txt:320 (message):
--- be used for production. ---
CMake Warning at C:/ncs/v2.5.0/zephyr/CMakeLists.txt:1958 (message):
__ASSERT() statements are globally ENABLED
CMake Warning at C:/ncs/v2.5.0/nrf/cmake/partition_manager.cmake:79 (message):
--- WARNING: Using a bootloader without pm_static.yml. ---
--- There are cases where a deployed product can consist of ---
--- multiple images, and only a subset of these images can be ---
--- upgraded through a firmware update mechanism. In such cases, ---
--- the upgradable images must have partitions that are static ---
--- and are matching the partition map used by the bootloader ---
--- programmed onto the device. ---
C:/ncs/v2.5.0/zephyr/cmake/modules/kernel.cmake:247 (include)
C:/ncs/v2.5.0/zephyr/cmake/modules/zephyr_default.cmake:138 (include)
Dropping partition 'nonsecure_storage' since it is empty.
-- Configuring done
CMake Error at C:/ncs/v2.5.0/zephyr/cmake/modules/extensions.cmake:424 (add_library):
Cannot find source file:
C:/ncs/v2.5.0/nrf/samples/nrf9160/at_client/src/main.c
Tried extensions .c .C .c++ .cc .cpp .cxx .cu .mpp .m .M .mm .h .hh .h++
.hm .hpp .hxx .in .txx .f .F .for .f77 .f90 .f95 .f03 .ispc
C:/ncs/v2.5.0/zephyr/cmake/modules/kernel.cmake:210 (zephyr_library_named)
No SOURCES given to target: app
CMake Generate step failed. Build files cannot be regenerated correctly.
?[91mFATAL ERROR: command exited with status 1: 'C:\ncs\toolchains\c57af46cb7\opt\bin\cmake.EXE' -DWEST_PYTHON=C:/ncs/toolchains/c57af46cb7/opt/bin/python.exe '-BC:\ncs\ejercicios\at_client\build' -GNinja -DBOARD=circuitdojo_feather_nrf9160_ns '-SC:\ncs\ejercicios\at_client'
?[0m
I have Windows 10 Pro and the following software:
*- “nRF Connect 4.3.0”
*- Toolchain 1.3.0
*- West version: v1.1.0.
Sorry, I don’t know what NFED stands for.
