  • The https app fails to deliver the message.
When you enable CONFIG_RESET_ON_FATAL_ERROR=n what do you get for the error message? I also suggest you enable
CONFIG_LOG=y
CONFIG_LOG_MODE_IMMEDIATE=y
So you can catch the error message/fault that is causing the reset
I made the changes to kconfig and build the https app, now I got an error.
CMake Error at C:/Compiladores/LTE/zephyr/cmake/modules/dts.cmake:276 (message):
message(FATAL_ERROR “gen_defines.py failed with return code: ${ret}”)
This happends all the time, not sure why, modify kconfig, and longer works, I had to copy the https folder from other original copy.
I couldn’t add an imagen I don’t know how to do it
    Repeats again and again…
    That usually indicates an program error. Maybe you also try:
    CONFIG_DEBUG=y
    and see, if it still “repeats again and again …”.
    5 days later
    I received an error when I tried to install these configurations, so I uninstalled everything: nRF connect, VSC extensions, and VSC.
    I restarted PC and installed VSC and Circuit Dojo with extensions, then launched “Zephyr Tools: Init Repo,” entered the URL, and created a new, empty folder to install samples.
    When using “Zephyr Tools: Build,” it prompts “You need to run Init Repo” first.🤬
    I then ran “Zehyr Tools: Build” on a new empty folder and received the same message.
    I installed VSC and Circuit Dojo with extensions, then launched “Zephyr Tools: Init Repo,” entered the URL, and created a new, empty folder.
    When using “Zephyr Tools: Build,” it prompts “You need to run Init Repo” first. I then ran “Zehyr Tools: Build” on a new empty folder and received the same message. “Run Zephyr Tools: Init Repo command first.” again and again…
    I uninstalled everything again, starting with “nRF Connect,” then “Toolchanin Manager,” and finally installing the Nordics VSC extensions. I then created a new folder and reinstalled them, instructed by
    I uninstalled everything again, beginning with “nRF Connect,” then “Toolchanin Manager,” before installing the Nordics and Circuit Dojo VSC extensions. I then made a new folder and reinstalled them with Circuit Dojo Documents.
    I ran “Zephyr Tools: Build” and received the error:
    kconfig:
    Dependecy Loop [Ln 8, Col 1 ]
    dts.make
    gen_defines.py failed with return code: 1 cMake[ln 276, Col 1]
    I built a VirtualBox PC with Debian 12 but could not discover a USB port no matter what.
    I installed VSC on the Raspberry Pi 5, but Circuit Dojo cannot run on ARM platforms.
    I wipe folders every time; I’m desperate; I bought the breakout board in December!
    Sorry I don’t know how to add an imagen from my PC
    I recommend some place like C:\nfed\ to make sure there aren’t any issues with whitespace. (Windows can be a pain sometimes!)
    Looks like there may be a bug in running the python3 dependency install. If you run Zephyr Tools: Init Repo and target the same folder it should complete installing your dependencies. Do not delete the folder nor its contents. It should look like this the second time around:
    Executing task: west update
    === updating nrf (nrf):
    HEAD is now at 75adfe890 manifest: NCS 2.4.2
    === updating zephyr (zephyr):
    HEAD is now at 28a3fca7da [nrf fromtree] libc/picolibc: Remove -T /dev/null linker arguments
    === updating bsim (tools/bsim):
    HEAD is now at 908ffde west.yaml: Namespace all projects
    === updating golioth (modules/lib/golioth):
    HEAD is now at 2392a46 Remove ZSOCK_MSG_TRUNC for offloaded TLS on nRF9160
    === updating pyrinas (pyrinas):
    --- pyrinas: fetching, need revision v1.9.x
    From https://github.com/pyrinas-iot/pyrinas-zephyr
     * branch            v1.9.x     -> FETCH_HEAD
    HEAD is now at a66f327 Small modifications to make OTA optional
    === updating pcf85063a (pcf85063a):
    HEAD is now at 81c1c28 APIs for Offset Register and CAP_SEL setting (#6)
    === updating hostap (modules/lib/hostap):
    HEAD is now at c54b1efd0 Remove verbose print
    === updating mcuboot (bootloader/mcuboot):
    HEAD is now at d5d451ec [nrf noup] boot: bootutil: Fix bl_secp256r1_validate call
    === updating qcbor (modules/tee/tf-m/qcbor):
    HEAD is now at b0e7033 Make option to compile with warnings on (#162)
    === updating mbedtls (modules/crypto/mbedtls):
    HEAD is now at 829e3edc7 [nrf fromlist] psa_crypto: Fix psa_key_derivation_output_key ECC without builtin keys
    === updating nrfxlib (nrfxlib):
    HEAD is now at 30841c2a nrf_modem: v2.4.1
    === updating trusted-firmware-m (modules/tee/tf-m/trusted-firmware-m):
    HEAD is now at f0bac9349 [nrf fromtree] platform: nordic_nrf: Add nrf9161 DK and nrf9120 SoC support
    === updating cjson (modules/lib/cjson):
    HEAD is now at c6af068 [nrf fromtree] fix: potential memory leak in merge_patch() (#611)
    === updating azure-sdk-for-c (modules/lib/azure-sdk-for-c):
    HEAD is now at 308c171c [nrf fromlist] Make repository a Zephyr module
    === updating cirrus (modules/hal/cirrus-logic):
    HEAD is now at 9f6b381 sdk-mcu-drivers: Added build system configs and generated files
    === updating memfault-firmware-sdk (modules/lib/memfault-firmware-sdk):
    HEAD is now at efd97b9 Memfault Firmware SDK 0.43.3 (Build 2200)
    === updating canopennode (modules/lib/canopennode):
    HEAD is now at dec12fa stack: map CANopenNode crc16_ccitt() to Zephyr crc16_itu_t()
    === updating chre (modules/lib/chre):
    HEAD is now at b7955c27 Merge pull request #7 from stephanosio/require_full_libcpp
    === updating cmsis (modules/hal/cmsis):
    HEAD is now at 74981bf Update DSP library for additional platforms
    === updating edtt (tools/edtt):
    HEAD is now at 64e5105 edttt_bsim: Avoid infinite exception loop
    === updating fatfs (modules/fs/fatfs):
    HEAD is now at 427159b zephyr: fix ffconf.h override use of STRINGIZE
    === updating hal_nordic (modules/hal/nordic):
    HEAD is now at 140140e nrfx: mdk: Fix handling of APPROTECT on nRF91
    === updating hal_st (modules/hal/st):
    HEAD is now at 5948f7b sensor/stmemsc: Align stmemsc i/f to v2.02
    === updating hal_wurthelektronik (modules/hal/wurthelektronik):
    HEAD is now at 24ca987 Initialized WE HAL module repository.
    === updating libmetal (modules/hal/libmetal):
    HEAD is now at efa2ace lib: update libmetal to SHA cd4fb67a4f50
    === updating liblc3 (modules/lib/liblc3):
    HEAD is now at 448f3de Merge pull request #8 from carlescufi/rename
    === updating littlefs (modules/fs/littlefs):
    HEAD is now at ca583fd Merge tag 'v2.5.0' of https://github.com/littlefs-project/littlefs into zephyr
    === updating nanopb (modules/lib/nanopb):
    HEAD is now at 42fa8b2 Merge pull request #2 from pdgendt/zephyr
    === updating net-tools (tools/net-tools):
    HEAD is now at e0828aa net-setup: Add instructions for NAT and routing
    === updating nrf_hw_models (modules/bsim_hw_models/nrf_hw_models):
    HEAD is now at bad9877 TEMP: Connect at the top level
    === updating open-amp (modules/lib/open-amp):
    HEAD is now at aedcc26 lib: update open-amp lib to release v2022.10.0
    === updating picolibc (modules/lib/picolibc):
    HEAD is now at 93b5d5f2a Version 1.8.1
    === updating segger (modules/debug/segger):
    HEAD is now at 4bfaf28 zephyr: use external Kconfig
    === updating tinycrypt (modules/crypto/tinycrypt):
    HEAD is now at 3e9a49d cmake: Fix conditional in root CMakeLists.txt
    === updating TraceRecorderSource (modules/debug/TraceRecorder):
    HEAD is now at bc839bf zephyr: update SYS_INIT calls
    === updating tf-m-tests (modules/tee/tf-m/tf-m-tests):
    HEAD is now at 0f80a65 Merge pull request #6 from microbuilder/tfm17_limit_attestation
    === updating psa-arch-tests (modules/tee/tf-m/psa-arch-tests):
    HEAD is now at 6a17330 dev-apis: platform: Increase timeout for nRF devs
    === updating uoscore-uedhoc (modules/lib/uoscore-uedhoc):
    HEAD is now at e892019 Merge pull request #11 from rlubos/zephyr-integration
    === updating zcbor (modules/lib/zcbor):
    HEAD is now at 0556eda Update version from 0.5.99 to 0.6.0
    === updating zscilib (modules/lib/zscilib):
    HEAD is now at 0035be5 Merge pull request #45 from uLipe/feature/qrd_no_recursion
     *  Terminal will be reused by tasks, press any key to close it.
     *  Executing task: pip install -r zephyr\scripts\requirements.txt
    Collecting pyelftools>=0.27
      Downloading pyelftools-0.30-py2.py3-none-any.whl (177 kB)
         |████████████████████████████████| 177 kB 2.2 MB/s
    Requirement already satisfied: PyYAML>=5.1 in c:\users\jared wolff\.zephyrtools\env\lib\site-packages (from -r zephyr\scripts\requirements-base.txt (line 11)) (6.0.1)
    Requirement already satisfied: pykwalify in c:\users\jared wolff\.zephyrtools\env\lib\site-packages (from -r zephyr\scripts\requirements-base.txt (line 14)) (1.8.0)
    Collecting canopen
      Downloading canopen-2.2.0-py3-none-any.whl (61 kB)
         |████████████████████████████████| 61 kB 4.0 MB/s
    Requirement already satisfied: packaging in c:\users\jared wolff\.zephyrtools\env\lib\site-packages (from -r zephyr\scripts\requirements-base.txt (line 18)) (23.2)
    Processing c:\users\jared wolff\appdata\local\pip\cache\wheels\4c\9b\0a\a78ff56725af3ef70792f9ed0f8dbbc4c0315edc62cbc4a6b8\progress-1.6-py3-none-any.whl
    Collecting psutil
      Downloading psutil-5.9.8-cp37-abi3-win_amd64.whl (255 kB)
         |████████████████████████████████| 255 kB 6.4 MB/s
    Collecting pylink-square
      Downloading pylink_square-1.2.0-py2.py3-none-any.whl (82 kB)
         |████████████████████████████████| 82 kB 294 kB/s
    Collecting pyserial
      Using cached pyserial-3.5-py2.py3-none-any.whl (90 kB)
    Collecting requests
      Downloading requests-2.31.0-py3-none-any.whl (62 kB)
         |████████████████████████████████| 62 kB 4.8 MB/s
    Collecting anytree
      Downloading anytree-2.12.1-py3-none-any.whl (44 kB)
         |████████████████████████████████| 44 kB ...
    Collecting intelhex
      Using cached intelhex-2.3.0-py2.py3-none-any.whl (50 kB)
    Requirement already satisfied: west>=0.10.1 in c:\users\jared wolff\.zephyrtools\env\lib\site-packages (from -r zephyr\scripts\requirements-base.txt (line 32)) (1.2.0)
    Collecting windows-curses
      Downloading windows_curses-2.3.2-cp39-cp39-win_amd64.whl (89 kB)
         |████████████████████████████████| 89 kB 5.8 MB/s
    Requirement already satisfied: colorama in c:\users\jared wolff\.zephyrtools\env\lib\site-packages (from -r zephyr\scripts\requirements-build-test.txt (line 7)) (0.4.6)
    Collecting ply>=3.10
      Using cached ply-3.11-py2.py3-none-any.whl (49 kB)
    Collecting gcovr>=4.2
      Downloading gcovr-7.2-py2.py3-none-any.whl (198 kB)
         |████████████████████████████████| 198 kB ...
    Collecting coverage
      Downloading coverage-7.4.3-cp39-cp39-win_amd64.whl (209 kB)
         |████████████████████████████████| 209 kB ...
    Collecting pytest
      Downloading pytest-8.0.2-py3-none-any.whl (333 kB)
         |████████████████████████████████| 333 kB 6.4 MB/s
    Collecting mypy
      Downloading mypy-1.8.0-cp39-cp39-win_amd64.whl (9.2 MB)
         |████████████████████████████████| 9.2 MB 6.4 MB/s
    Collecting mock>=4.0.1
      Downloading mock-5.1.0-py3-none-any.whl (30 kB)
    Collecting breathe>=4.34
      Downloading breathe-4.35.0-py3-none-any.whl (92 kB)
         |████████████████████████████████| 92 kB ...
    Collecting sphinx!=5.2.0.post0,~=5.0
      Downloading sphinx-5.3.0-py3-none-any.whl (3.2 MB)
         |████████████████████████████████| 3.2 MB ...
    Collecting sphinx_rtd_theme~=1.0
      Downloading sphinx_rtd_theme-1.3.0-py2.py3-none-any.whl (2.8 MB)
         |████████████████████████████████| 2.8 MB 6.4 MB/s
    Collecting sphinx-tabs
      Downloading sphinx_tabs-3.4.5-py3-none-any.whl (9.9 kB)
    Collecting sphinxcontrib-svg2pdfconverter
      Downloading sphinxcontrib_svg2pdfconverter-1.2.2-py3-none-any.whl (8.1 kB)
    Collecting pygments>=2.9
      Downloading pygments-2.17.2-py3-none-any.whl (1.2 MB)
         |████████████████████████████████| 1.2 MB ...
    Collecting sphinx-notfound-page
      Downloading sphinx_notfound_page-1.0.0-py3-none-any.whl (8.1 kB)
    Collecting sphinx-copybutton
      Downloading sphinx_copybutton-0.5.2-py3-none-any.whl (13 kB)
    Collecting pyocd>=0.29.0
      Downloading pyocd-0.36.0-py3-none-any.whl (14.0 MB)
         |████████████████████████████████| 14.0 MB 6.8 MB/s
    Collecting tabulate
      Using cached tabulate-0.9.0-py3-none-any.whl (35 kB)
    Processing c:\users\jared wolff\appdata\local\pip\cache\wheels\ec\10\03\a281e0682ddd4b310431fb25d1a4f53987105267cf46c417f3\cbor-1.0.0-py3-none-any.whl
    Collecting gitlint
      Downloading gitlint-0.19.1-py3-none-any.whl (2.6 kB)
    Collecting junit2html
      Downloading junit2html-30.1.6-py3-none-any.whl (15 kB)
    Collecting clang-format>=15.0.0
      Downloading clang_format-18.1.0-py2.py3-none-win_amd64.whl (1.4 MB)
         |████████████████████████████████| 1.4 MB 6.8 MB/s
    Collecting lpc_checksum
      Using cached lpc_checksum-3.0.0-py3-none-any.whl (5.1 kB)
    Collecting Pillow
      Downloading pillow-10.2.0-cp39-cp39-win_amd64.whl (2.6 MB)
         |████████████████████████████████| 2.6 MB 6.8 MB/s
    Collecting imgtool>=1.9
      Downloading imgtool-2.0.0-py3-none-any.whl (34 kB)
    Collecting grpcio-tools
      Downloading grpcio_tools-1.62.0-cp39-cp39-win_amd64.whl (1.1 MB)
         |████████████████████████████████| 1.1 MB ...
    Collecting PyGithub
      Downloading PyGithub-2.2.0-py3-none-any.whl (350 kB)
         |████████████████████████████████| 350 kB 6.8 MB/s
    Collecting graphviz
      Downloading graphviz-0.20.1-py3-none-any.whl (47 kB)
         |████████████████████████████████| 47 kB ...
    Collecting zcbor>=0.6.0
      Downloading zcbor-0.8.1-py3-none-any.whl (81 kB)
         |████████████████████████████████| 81 kB ...
    Collecting python-magic
      Using cached python_magic-0.4.27-py2.py3-none-any.whl (13 kB)
    Collecting python-magic-bin
      Downloading python_magic_bin-0.4.14-py2.py3-none-win_amd64.whl (409 kB)
         |████████████████████████████████| 409 kB 3.3 MB/s
    Collecting lxml
      Downloading lxml-5.1.0-cp39-cp39-win_amd64.whl (3.9 MB)
         |████████████████████████████████| 3.9 MB ...
    Collecting junitparser>=2
      Downloading junitparser-3.1.2-py2.py3-none-any.whl (13 kB)
    Collecting pylint
      Downloading pylint-3.1.0-py3-none-any.whl (515 kB)
         |████████████████████████████████| 515 kB 6.4 MB/s
    Collecting yamllint
      Downloading yamllint-1.35.1-py3-none-any.whl (66 kB)
         |████████████████████████████████| 66 kB 4.5 MB/s
    Requirement already satisfied: ruamel.yaml>=0.16.0 in c:\users\jared wolff\.zephyrtools\env\lib\site-packages (from pykwalify->-r zephyr\scripts\requirements-base.txt (line 14)) (0.18.6)
    Requirement already satisfied: docopt>=0.6.2 in c:\users\jared wolff\.zephyrtools\env\lib\site-packages (from pykwalify->-r zephyr\scripts\requirements-base.txt (line 14)) (0.6.2)
    Requirement already satisfied: python-dateutil>=2.8.0 in c:\users\jared wolff\.zephyrtools\env\lib\site-packages (from pykwalify->-r zephyr\scripts\requirements-base.txt (line 14)) (2.9.0.post0)
    Collecting python-can>=3.0.0
      Downloading python_can-4.3.1-py3-none-any.whl (262 kB)
         |████████████████████████████████| 262 kB ...
    Requirement already satisfied: six in c:\users\jared wolff\.zephyrtools\env\lib\site-packages (from pylink-square->-r zephyr\scripts\requirements-base.txt (line 21)) (1.16.0)
    Collecting certifi>=2017.4.17
      Downloading certifi-2024.2.2-py3-none-any.whl (163 kB)
         |████████████████████████████████| 163 kB ...
    Collecting urllib3<3,>=1.21.1
      Downloading urllib3-2.2.1-py3-none-any.whl (121 kB)
         |████████████████████████████████| 121 kB ...
    Collecting charset-normalizer<4,>=2
      Downloading charset_normalizer-3.3.2-cp39-cp39-win_amd64.whl (100 kB)
         |████████████████████████████████| 100 kB ...
    Collecting idna<4,>=2.5
      Downloading idna-3.6-py3-none-any.whl (61 kB)
         |████████████████████████████████| 61 kB ...
    Requirement already satisfied: setuptools in c:\users\jared wolff\.zephyrtools\env\lib\site-packages (from west>=0.10.1->-r zephyr\scripts\requirements-base.txt (line 32)) (49.2.1)
    Collecting tomli>=1.1.0; python_version < "3.11"
      Using cached tomli-2.0.1-py3-none-any.whl (12 kB)
    Collecting colorlog
      Downloading colorlog-6.8.2-py3-none-any.whl (11 kB)
    Collecting jinja2
      Downloading Jinja2-3.1.3-py3-none-any.whl (133 kB)
         |████████████████████████████████| 133 kB ...
    Collecting pluggy<2.0,>=1.3.0
      Downloading pluggy-1.4.0-py3-none-any.whl (20 kB)
    Collecting iniconfig
      Downloading iniconfig-2.0.0-py3-none-any.whl (5.9 kB)
    Collecting exceptiongroup>=1.0.0rc8; python_version < "3.11"
      Downloading exceptiongroup-1.2.0-py3-none-any.whl (16 kB)
    Collecting typing-extensions>=4.1.0
      Downloading typing_extensions-4.10.0-py3-none-any.whl (33 kB)
    Collecting mypy-extensions>=1.0.0
      Downloading mypy_extensions-1.0.0-py3-none-any.whl (4.7 kB)
    Collecting docutils>=0.12
      Downloading docutils-0.20.1-py3-none-any.whl (572 kB)
         |████████████████████████████████| 572 kB ...
    Collecting sphinxcontrib-htmlhelp>=2.0.0
      Downloading sphinxcontrib_htmlhelp-2.0.5-py3-none-any.whl (99 kB)
         |████████████████████████████████| 99 kB 6.8 MB/s
    Collecting sphinxcontrib-devhelp
      Downloading sphinxcontrib_devhelp-1.0.6-py3-none-any.whl (83 kB)
         |████████████████████████████████| 83 kB 3.0 MB/s
    Collecting alabaster<0.8,>=0.7
      Downloading alabaster-0.7.16-py3-none-any.whl (13 kB)
    Collecting babel>=2.9
      Downloading Babel-2.14.0-py3-none-any.whl (11.0 MB)
         |████████████████████████████████| 11.0 MB ...
    Collecting sphinxcontrib-serializinghtml>=1.1.5
      Downloading sphinxcontrib_serializinghtml-1.1.10-py3-none-any.whl (92 kB)
         |████████████████████████████████| 92 kB 353 kB/s
    Collecting snowballstemmer>=2.0
      Using cached snowballstemmer-2.2.0-py2.py3-none-any.whl (93 kB)
    Collecting sphinxcontrib-applehelp
      Downloading sphinxcontrib_applehelp-1.0.8-py3-none-any.whl (120 kB)
         |████████████████████████████████| 120 kB ...
    Collecting sphinxcontrib-jsmath
      Using cached sphinxcontrib_jsmath-1.0.1-py2.py3-none-any.whl (5.1 kB)
    Collecting sphinxcontrib-qthelp
      Downloading sphinxcontrib_qthelp-1.0.7-py3-none-any.whl (89 kB)
         |████████████████████████████████| 89 kB ...
    Collecting importlib-metadata>=4.8; python_version < "3.10"
      Downloading importlib_metadata-7.0.2-py3-none-any.whl (24 kB)
    Collecting imagesize>=1.3
      Using cached imagesize-1.4.1-py2.py3-none-any.whl (8.8 kB)
    Collecting sphinxcontrib-jquery<5,>=4
      Downloading sphinxcontrib_jquery-4.1-py2.py3-none-any.whl (121 kB)
    Collecting libusb-package<2.0,>=1.0
      Downloading libusb_package-1.0.26.2-cp39-cp39-win_amd64.whl (90 kB)
         |████████████████████████████████| 90 kB 4.8 MB/s
    Collecting hidapi<1.0,>=0.10.1; platform_system != "Linux"
      Downloading hidapi-0.14.0-cp39-cp39-win_amd64.whl (60 kB)
         |████████████████████████████████| 60 kB ...
    Collecting lark<2.0,>=1.1.5
      Downloading lark-1.1.9-py3-none-any.whl (111 kB)
         |████████████████████████████████| 111 kB ...
    Collecting pyusb<2.0,>=1.2.1
      Using cached pyusb-1.2.1-py3-none-any.whl (58 kB)
    Collecting importlib-resources
      Downloading importlib_resources-6.1.3-py3-none-any.whl (34 kB)
    Collecting natsort<9.0,>=8.0.0
      Downloading natsort-8.4.0-py3-none-any.whl (38 kB)
    Collecting prettytable<4.0,>=2.0
      Downloading prettytable-3.10.0-py3-none-any.whl (28 kB)
    Processing c:\users\jared wolff\appdata\local\pip\cache\wheels\ab\fa\1b\75d9a713279796785711bd0bad8334aaace560c0bd28830c8c\intervaltree-3.1.0-py2.py3-none-any.whl
    Collecting capstone<5.0,>=4.0
      Using cached capstone-4.0.2-py2.py3-none-win_amd64.whl (896 kB)
    Collecting cmsis-pack-manager<1.0,>=0.5.2
      Downloading cmsis_pack_manager-0.5.3-py3-none-win_amd64.whl (2.7 MB)
         |████████████████████████████████| 2.7 MB ...
    Collecting gitlint-core[trusted-deps]==0.19.1
      Downloading gitlint_core-0.19.1-py3-none-any.whl (44 kB)
    Collecting click
      Downloading click-8.1.7-py3-none-any.whl (97 kB)
         |████████████████████████████████| 97 kB 3.6 MB/s
    Collecting cbor2
      Downloading cbor2-5.6.2-cp39-cp39-win_amd64.whl (66 kB)
         |████████████████████████████████| 66 kB 2.1 MB/s
    Collecting cryptography>=2.4.2
      Downloading cryptography-42.0.5-cp39-abi3-win_amd64.whl (2.9 MB)
         |████████████████████████████████| 2.9 MB ...
    Collecting grpcio>=1.62.0
      Downloading grpcio-1.62.0-cp39-cp39-win_amd64.whl (3.8 MB)
         |████████████████████████████████| 3.8 MB 6.4 MB/s
    Collecting protobuf<5.0dev,>=4.21.6
      Downloading protobuf-4.25.3-cp39-cp39-win_amd64.whl (413 kB)
         |████████████████████████████████| 413 kB ...
    Collecting Deprecated
      Downloading Deprecated-1.2.14-py2.py3-none-any.whl (9.6 kB)
    Collecting pynacl>=1.4.0
      Using cached PyNaCl-1.5.0-cp36-abi3-win_amd64.whl (212 kB)
    Collecting pyjwt[crypto]>=2.4.0
      Downloading PyJWT-2.8.0-py3-none-any.whl (22 kB)
    Collecting regex>=2022.3.15
      Downloading regex-2023.12.25-cp39-cp39-win_amd64.whl (269 kB)
         |████████████████████████████████| 269 kB ...
    Collecting tomlkit>=0.10.1
      Downloading tomlkit-0.12.4-py3-none-any.whl (37 kB)
    Collecting platformdirs>=2.2.0
      Downloading platformdirs-4.2.0-py3-none-any.whl (17 kB)
    Collecting astroid<=3.2.0-dev0,>=3.1.0
      Downloading astroid-3.1.0-py3-none-any.whl (275 kB)
         |████████████████████████████████| 275 kB ...
    Collecting dill>=0.2; python_version < "3.11"
      Downloading dill-0.3.8-py3-none-any.whl (116 kB)
         |████████████████████████████████| 116 kB ...
    Collecting isort!=5.13.0,<6,>=4.2.5
      Downloading isort-5.13.2-py3-none-any.whl (92 kB)
         |████████████████████████████████| 92 kB 93 kB/s
    Collecting mccabe<0.8,>=0.6
      Using cached mccabe-0.7.0-py2.py3-none-any.whl (7.3 kB)
    Collecting pathspec>=0.5.3
      Downloading pathspec-0.12.1-py3-none-any.whl (31 kB)
    Requirement already satisfied: ruamel.yaml.clib>=0.2.7; platform_python_implementation == "CPython" and python_version < "3.13" in c:\users\jared wolff\.zephyrtools\env\lib\site-packages (from ruamel.yaml>=0.16.0->pykwalify->-r zephyr\scripts\requirements-base.txt (line 14)) (0.2.8)
    Collecting pywin32>=305; platform_system == "Windows" and platform_python_implementation == "CPython"
      Downloading pywin32-306-cp39-cp39-win_amd64.whl (9.3 MB)
         |████████████████████████████████| 9.3 MB 6.4 MB/s
    Collecting wrapt~=1.10
      Downloading wrapt-1.16.0-cp39-cp39-win_amd64.whl (37 kB)
    Collecting MarkupSafe>=2.0
      Downloading MarkupSafe-2.1.5-cp39-cp39-win_amd64.whl (17 kB)
    Collecting zipp>=0.5
      Downloading zipp-3.17.0-py3-none-any.whl (7.4 kB)
    Collecting wcwidth
      Downloading wcwidth-0.2.13-py2.py3-none-any.whl (34 kB)
    Collecting sortedcontainers<3.0,>=2.0
      Using cached sortedcontainers-2.4.0-py2.py3-none-any.whl (29 kB)
    Collecting cffi
      Downloading cffi-1.16.0-cp39-cp39-win_amd64.whl (181 kB)
         |████████████████████████████████| 181 kB ...
    Collecting appdirs<2.0,>=1.4
      Using cached appdirs-1.4.4-py2.py3-none-any.whl (9.6 kB)
    Collecting arrow>=1
      Downloading arrow-1.3.0-py3-none-any.whl (66 kB)
         |████████████████████████████████| 66 kB 2.2 MB/s
    Collecting pycparser
      Using cached pycparser-2.21-py2.py3-none-any.whl (118 kB)
    Collecting types-python-dateutil>=2.8.10
      Downloading types_python_dateutil-2.8.19.20240106-py3-none-any.whl (9.7 kB)
    Installing collected packages: pyelftools, typing-extensions, pywin32, wrapt, python-can, canopen, progress, psutil, pylink-square, pyserial, certifi, urllib3, charset-normalizer, idna, requests, anytree, intelhex, windows-curses, ply, tomli, colorlog, pygments, MarkupSafe, jinja2, lxml, gcovr, coverage, pluggy, iniconfig, exceptiongroup, pytest, mypy-extensions,
    mypy, mock, sphinxcontrib-htmlhelp, sphinxcontrib-devhelp, docutils, alabaster, babel, sphinxcontrib-serializinghtml, snowballstemmer, sphinxcontrib-applehelp, sphinxcontrib-jsmath, sphinxcontrib-qthelp, zipp, importlib-metadata, imagesize, sphinx, breathe, sphinxcontrib-jquery, sphinx-rtd-theme, sphinx-tabs, sphinxcontrib-svg2pdfconverter, sphinx-notfound-page, sphinx-copybutton, importlib-resources, libusb-package, hidapi, lark, pyusb, natsort, wcwidth, prettytable, sortedcontainers, intervaltree, capstone, pycparser, cffi, appdirs, cmsis-pack-manager, pyocd, tabulate, cbor, click, types-python-dateutil, arrow, gitlint-core, gitlint, junit2html, clang-format, lpc-checksum, Pillow, cbor2, cryptography, imgtool, grpcio, protobuf, grpcio-tools, Deprecated, pynacl, pyjwt, PyGithub, graphviz, regex, zcbor, python-magic, python-magic-bin, junitparser, tomlkit, platformdirs, astroid, dill, isort, mccabe, pylint, pathspec, yamllint
    ERROR: After October 2020 you may experience errors when installing or updating packages. This is because pip will change
    the way that it resolves dependency conflicts.
    We recommend you use --use-feature=2020-resolver to test your packages with the new resolver before it becomes the default.
    sphinx 5.3.0 requires docutils<0.20,>=0.14, but you'll have docutils 0.20.1 which is incompatible.
    sphinx-rtd-theme 1.3.0 requires docutils<0.19, but you'll have docutils 0.20.1 which is incompatible.
    Successfully installed Deprecated-1.2.14 MarkupSafe-2.1.5 Pillow-10.2.0 PyGithub-2.2.0 alabaster-0.7.16 anytree-2.12.1 appdirs-1.4.4 arrow-1.3.0 astroid-3.1.0 babel-2.14.0 breathe-4.35.0 canopen-2.2.0 capstone-4.0.2 cbor-1.0.0 cbor2-5.6.2 certifi-2024.2.2 cffi-1.16.0 charset-normalizer-3.3.2 clang-format-18.1.0 click-8.1.7 cmsis-pack-manager-0.5.3 colorlog-6.8.2 coverage-7.4.3 cryptography-42.0.5 dill-0.3.8 docutils-0.20.1 exceptiongroup-1.2.0 gcovr-7.2 gitlint-0.19.1 gitlint-core-0.19.1 graphviz-0.20.1 grpcio-1.62.0 grpcio-tools-1.62.0 hidapi-0.14.0 idna-3.6 imagesize-1.4.1 imgtool-2.0.0 importlib-metadata-7.0.2 importlib-resources-6.1.3 iniconfig-2.0.0 intelhex-2.3.0 intervaltree-3.1.0 isort-5.13.2 jinja2-3.1.3 junit2html-30.1.6 junitparser-3.1.2 lark-1.1.9 libusb-package-1.0.26.2 lpc-checksum-3.0.0 lxml-5.1.0 mccabe-0.7.0 mock-5.1.0 mypy-1.8.0 mypy-extensions-1.0.0 natsort-8.4.0 pathspec-0.12.1 platformdirs-4.2.0 pluggy-1.4.0 ply-3.11 prettytable-3.10.0 progress-1.6 protobuf-4.25.3 psutil-5.9.8 pycparser-2.21 pyelftools-0.30 pygments-2.17.2 pyjwt-2.8.0 pylink-square-1.2.0 pylint-3.1.0 pynacl-1.5.0 pyocd-0.36.0 pyserial-3.5 pytest-8.0.2 python-can-4.3.1 python-magic-0.4.27 python-magic-bin-0.4.14 pyusb-1.2.1 pywin32-306 regex-2023.12.25 requests-2.31.0 snowballstemmer-2.2.0 sortedcontainers-2.4.0 sphinx-5.3.0 sphinx-copybutton-0.5.2 sphinx-notfound-page-1.0.0 sphinx-rtd-theme-1.3.0 sphinx-tabs-3.4.5 sphinxcontrib-applehelp-1.0.8 sphinxcontrib-devhelp-1.0.6 sphinxcontrib-htmlhelp-2.0.5 sphinxcontrib-jquery-4.1 sphinxcontrib-jsmath-1.0.1 sphinxcontrib-qthelp-1.0.7 sphinxcontrib-serializinghtml-1.1.10 sphinxcontrib-svg2pdfconverter-1.2.2 tabulate-0.9.0 tomli-2.0.1 tomlkit-0.12.4 types-python-dateutil-2.8.19.20240106 typing-extensions-4.10.0 urllib3-2.2.1 wcwidth-0.2.13 windows-curses-2.3.2 wrapt-1.16.0 yamllint-1.35.1 zcbor-0.8.1 zipp-3.17.0
    WARNING: You are using pip version 20.2.3; however, version 24.0 is available.
    You should consider upgrading via the 'c:\users\jared wolff\.zephyrtools\env\scripts\python.exe -m pip install --upgrade pip' command.
    Not sure what happened since Linux and Mac are working ok but I’ll try to root cause it soon.
    Thanks Jared, the folder name I use is “C:\LTE”, not sure about the whitespace, I am aware that it’s often a pain.
    I ran Zephyr Tools: Init Repo in the same folder “C:\LTE”, now when I run “Zephyr Tools: Build”, “build” folder is no longer generated and there is a warning:
    CMakeLists.txt
    “CMake Warning at C:/LTE/zephyr/CMakeLists.txt:839 (message):”, cmake[Ln 839,Col 1]
    this is the fraction of CMakeLists.txt
    if(NOT “${allow_empty}”)
    message(WARNING
    “No SOURCES given to Zephyr library: ${zephyr_lib}\nExcluding target from build.”
    Also, i build “external_rtc_time_sync”, that it ran sucessfully like a month o so ago, but now, it doesn’t generate “build” folder, and no error nor warnings are generated.
    How old is enough? Say, what version do you now use or recommend? I am using v1.87.1
