Hi there, I feel like an absolute noob for asking this, but I wonder if you could help me out here. I am basically trying to use the feather to wake another device and put it to sleep through the use of one of the GPIO pins. Ideally I would like to put the LTE M1 modem into a low power state, wake it after 30s and then connect to my self hosted MQTT broker to check if any messages have been left (sent from another device and set to Retain). No certificates needed. Parse the message, if any, and then act on them.
The trouble is, I can’t seem to connect to LTE, let alone go any further. I tried to follow the instructions here and pulled the MQTT simple sample (last one I could pull was from v2.2 branch of the nrf SDK) and tried to patch the code into the samples folder and include MCU bootloader thingy to use vs code to flash through newtmgr. This all builds and flashes fine, but I just cannot connect to LTE.
When I load the at-client sample and use AT commands, I can set the PDP context and use AT+CFUN=1 and AT+CEREG=1 to get it to register to the home network so I was hoping that when I call lte_lc_init_and_connect it would connect.
Code is appended below and hidden to prevent clutter. Any help would be greatly appreciated. Thanks much!
#include <zephyr/kernel.h>
#include <stdio.h>
#include <zephyr/drivers/uart.h>
#include <string.h>
#include <zephyr/random/rand32.h>
#include <zephyr/net/mqtt.h>
#include <zephyr/net/socket.h>
#include <zephyr/shell/shell.h>
#include <hw_id.h>
#if defined(CONFIG_NRF_MODEM_LIB)
#include <nrf_modem_at.h>
#endif /* CONFIG_NRF_MODEM_LIB */
#include <modem/lte_lc.h>
#if defined(CONFIG_MODEM_KEY_MGMT)
#include <modem/modem_key_mgmt.h>
#endif
#include <dk_buttons_and_leds.h>
#include "certificates.h"
LOG_MODULE_REGISTER(mqtt_simple, CONFIG_MQTT_SIMPLE_LOG_LEVEL);
/* Buffers for MQTT client. */
static uint8_t rx_buffer[CONFIG_MQTT_MESSAGE_BUFFER_SIZE];
static uint8_t tx_buffer[CONFIG_MQTT_MESSAGE_BUFFER_SIZE];
static uint8_t payload_buf[CONFIG_MQTT_PAYLOAD_BUFFER_SIZE];
/* The mqtt client struct */
static struct mqtt_client client;
/* MQTT Broker details. */
static struct sockaddr_storage broker;
/* File descriptor */
static struct pollfd fds;
K_SEM_DEFINE(lte_connected, 0, 1);
static void lte_handler(const struct lte_lc_evt *const evt)
     switch (evt->type) {
     case LTE_LC_EVT_NW_REG_STATUS:
             if ((evt->nw_reg_status != LTE_LC_NW_REG_REGISTERED_HOME) &&
             (evt->nw_reg_status != LTE_LC_NW_REG_REGISTERED_ROAMING)) {
                     break;
             printk("Connected to: %s network\n",
             evt->nw_reg_status == LTE_LC_NW_REG_REGISTERED_HOME ? "home" : "roaming");
             k_sem_give(<e_connected);
             break;
     case LTE_LC_EVT_PSM_UPDATE:
     case LTE_LC_EVT_EDRX_UPDATE:
     case LTE_LC_EVT_RRC_UPDATE:
     case LTE_LC_EVT_CELL_UPDATE:
     case LTE_LC_EVT_LTE_MODE_UPDATE:
     case LTE_LC_EVT_TAU_PRE_WARNING:
     case LTE_LC_EVT_NEIGHBOR_CELL_MEAS:
     case LTE_LC_EVT_MODEM_SLEEP_EXIT_PRE_WARNING:
     case LTE_LC_EVT_MODEM_SLEEP_EXIT:
     case LTE_LC_EVT_MODEM_SLEEP_ENTER:
             /* Callback events carrying LTE link data */
             break;
     default:
             break;
#if defined(CONFIG_MQTT_LIB_TLS)
static int certificates_provision(void)
	int err = 0;
	LOG_INF("Provisioning certificates");
#if defined(CONFIG_NRF_MODEM_LIB) && defined(CONFIG_MODEM_KEY_MGMT)
	err = modem_key_mgmt_write(CONFIG_MQTT_TLS_SEC_TAG,
				   MODEM_KEY_MGMT_CRED_TYPE_CA_CHAIN,
				   CA_CERTIFICATE,
				   strlen(CA_CERTIFICATE));
	if (err) {
		LOG_ERR("Failed to provision CA certificate: %d", err);
		return err;
#elif defined(CONFIG_BOARD_QEMU_X86) && defined(CONFIG_NET_SOCKETS_SOCKOPT_TLS)
	err = tls_credential_add(CONFIG_MQTT_TLS_SEC_TAG,
				 TLS_CREDENTIAL_CA_CERTIFICATE,
				 CA_CERTIFICATE,
				 sizeof(CA_CERTIFICATE));
	if (err) {
		LOG_ERR("Failed to register CA certificate: %d", err);
		return err;
#endif
	return err;
#endif /* defined(CONFIG_MQTT_LIB_TLS) */
/**@brief Function to print strings without null-termination
static void data_print(uint8_t *prefix, uint8_t *data, size_t len)
	char buf[len + 1];
	memcpy(buf, data, len);
	buf[len] = 0;
	LOG_INF("%s%s", (char *)prefix, (char *)buf);
/**@brief Function to publish data on the configured topic
static int data_publish(struct mqtt_client *c, enum mqtt_qos qos,
	struct mqtt_publish_param param;
	param.message.topic.qos = qos;
	param.message.topic.topic.utf8 = CONFIG_MQTT_PUB_TOPIC;
	param.message.topic.topic.size = strlen(CONFIG_MQTT_PUB_TOPIC);
	param.message.payload.data = data;
	param.message.payload.len = len;
	param.message_id = sys_rand32_get();
	param.dup_flag = 0;
	param.retain_flag = 0;
	data_print("Publishing: ", data, len);
	LOG_INF("to topic: %s len: %u",
		CONFIG_MQTT_PUB_TOPIC,
		(unsigned int)strlen(CONFIG_MQTT_PUB_TOPIC));
	return mqtt_publish(c, ¶m);
/**@brief Function to subscribe to the configured topic
static int subscribe(void)
	struct mqtt_topic subscribe_topic = {
		.topic = {
			.utf8 = CONFIG_MQTT_SUB_TOPIC,
			.size = strlen(CONFIG_MQTT_SUB_TOPIC)
		.qos = MQTT_QOS_1_AT_LEAST_ONCE
	const struct mqtt_subscription_list subscription_list = {
		.list = &subscribe_topic,
		.list_count = 1,
		.message_id = 1234
	LOG_INF("Subscribing to: %s len %u", CONFIG_MQTT_SUB_TOPIC,
		(unsigned int)strlen(CONFIG_MQTT_SUB_TOPIC));
	return mqtt_subscribe(&client, &subscription_list);
/**@brief Function to read the published payload.
static int publish_get_payload(struct mqtt_client *c, size_t length)
	int ret;
	int err = 0;
	/* Return an error if the payload is larger than the payload buffer.
	 * Note: To allow new messages, we have to read the payload before returning.
	if (length > sizeof(payload_buf)) {
		err = -EMSGSIZE;
	/* Truncate payload until it fits in the payload buffer. */
	while (length > sizeof(payload_buf)) {
		ret = mqtt_read_publish_payload_blocking(
				c, payload_buf, (length - sizeof(payload_buf)));
		if (ret == 0) {
			return -EIO;
		} else if (ret < 0) {
			return ret;
		length -= ret;
	ret = mqtt_readall_publish_payload(c, payload_buf, length);
	if (ret) {
		return ret;
	return err;
/**@brief MQTT client event handler
void mqtt_evt_handler(struct mqtt_client *const c,
		      const struct mqtt_evt *evt)
	int err;
	case MQTT_EVT_CONNACK:
		if (evt->result != 0) {
			LOG_ERR("MQTT connect failed: %d", evt->result);
			break;
		LOG_INF("MQTT client connected");
		subscribe();
		break;
	case MQTT_EVT_DISCONNECT:
		LOG_INF("MQTT client disconnected: %d", evt->result);
		break;
	case MQTT_EVT_PUBLISH: {
		const struct mqtt_publish_param *p = &evt->param.publish;
		LOG_INF("MQTT PUBLISH result=%d len=%d",
			evt->result, p->message.payload.len);
		err = publish_get_payload(c, p->message.payload.len);
		if (p->message.topic.qos == MQTT_QOS_1_AT_LEAST_ONCE) {
			const struct mqtt_puback_param ack = {
				.message_id = p->message_id
			/* Send acknowledgment. */
			mqtt_publish_qos1_ack(&client, &ack);
		if (err >= 0) {
			data_print("Received: ", payload_buf,
			/* Echo back received data */
			data_publish(&client, MQTT_QOS_1_AT_LEAST_ONCE,
				payload_buf, p->message.payload.len);
		} else if (err == -EMSGSIZE) {
			LOG_ERR("Received payload (%d bytes) is larger than the payload buffer "
				"size (%d bytes).",
				p->message.payload.len, sizeof(payload_buf));
		} else {
			LOG_ERR("publish_get_payload failed: %d", err);
			LOG_INF("Disconnecting MQTT client...");
			err = mqtt_disconnect(c);
			if (err) {
				LOG_ERR("Could not disconnect: %d", err);
	} break;
	case MQTT_EVT_PUBACK:
			LOG_ERR("MQTT PUBACK error: %d", evt->result);
			break;
		LOG_INF("PUBACK packet id: %u", evt->param.puback.message_id);
		break;
	case MQTT_EVT_SUBACK:
			LOG_ERR("MQTT SUBACK error: %d", evt->result);
			break;
		LOG_INF("SUBACK packet id: %u", evt->param.suback.message_id);
		break;
	case MQTT_EVT_PINGRESP:
			LOG_ERR("MQTT PINGRESP error: %d", evt->result);
		break;
	default:
		LOG_INF("Unhandled MQTT event type: %d", evt->type);
		break;
/**@brief Resolves the configured hostname and
 * initializes the MQTT broker structure
static int broker_init(void)
	int err;
	struct addrinfo *result;
	struct addrinfo *addr;
	struct addrinfo hints = {
		.ai_family = AF_INET,
		.ai_socktype = SOCK_STREAM
	err = getaddrinfo(CONFIG_MQTT_BROKER_HOSTNAME, NULL, &hints, &result);
	if (err) {
		LOG_ERR("getaddrinfo failed: %d", err);
		return -ECHILD;
	addr = result;
	/* Look for address of the broker. */
	while (addr != NULL) {
		/* IPv4 Address. */
		if (addr->ai_addrlen == sizeof(struct sockaddr_in)) {
			struct sockaddr_in *broker4 =
				((struct sockaddr_in *)&broker);
			char ipv4_addr[NET_IPV4_ADDR_LEN];
			broker4->sin_addr.s_addr =
				((struct sockaddr_in *)addr->ai_addr)
				->sin_addr.s_addr;
			broker4->sin_family = AF_INET;
			broker4->sin_port = htons(CONFIG_MQTT_BROKER_PORT);
			inet_ntop(AF_INET, &broker4->sin_addr.s_addr,
				  ipv4_addr, sizeof(ipv4_addr));
			LOG_INF("IPv4 Address found %s", ipv4_addr);
			break;
		} else {
			LOG_ERR("ai_addrlen = %u should be %u or %u",
				(unsigned int)addr->ai_addrlen,
				(unsigned int)sizeof(struct sockaddr_in),
				(unsigned int)sizeof(struct sockaddr_in6));
		addr = addr->ai_next;
	/* Free the address. */
	freeaddrinfo(result);
	return err;
#define RANDOM_LEN 10
#define CLIENT_ID_LEN sizeof(CONFIG_BOARD) + 1 + RANDOM_LEN
/* Function to get the client id */
static const uint8_t* client_id_get(void)
	static uint8_t client_id[MAX(sizeof(CONFIG_MQTT_CLIENT_ID),
				     CLIENT_ID_LEN)];
	if (strlen(CONFIG_MQTT_CLIENT_ID) > 0) {
		snprintf(client_id, sizeof(client_id), "%s",
			 CONFIG_MQTT_CLIENT_ID);
		goto exit;
	char hw_id_buf[HW_ID_LEN] = {0};
	int err = hw_id_get(hw_id_buf, ARRAY_SIZE(hw_id_buf));
	if (!err) {
		snprintf(client_id, sizeof(client_id), "nrf-%s",
			 hw_id_buf);
		goto exit;
	LOG_ERR("failed to retrieve HW ID, err: %d", err);
	uint32_t id = sys_rand32_get();
	snprintf(client_id, sizeof(client_id), "%s-%010u", CONFIG_BOARD, id);
exit:
	LOG_DBG("client_id = %s", (char *)client_id);
	return client_id;
/**@brief Initialize the MQTT client structure
static int client_init(struct mqtt_client *client)
	int err;
	mqtt_client_init(client);
	err = broker_init();
	if (err) {
		LOG_ERR("Failed to initialize broker connection");
		return err;
	/* MQTT client configuration */
	client->broker = &broker;
	client->evt_cb = mqtt_evt_handler;
	client->client_id.utf8 = client_id_get();
	client->client_id.size = strlen(client->client_id.utf8);
	client->password = NULL;
	client->user_name = NULL;
	client->protocol_version = MQTT_VERSION_3_1_1;
	/* MQTT buffers configuration */
	client->rx_buf = rx_buffer;
	client->rx_buf_size = sizeof(rx_buffer);
	client->tx_buf = tx_buffer;
	client->tx_buf_size = sizeof(tx_buffer);
	/* MQTT transport configuration */
	struct mqtt_sec_config *tls_cfg = &(client->transport).tls.config;
	static sec_tag_t sec_tag_list[] = { CONFIG_MQTT_TLS_SEC_TAG };
	LOG_INF("TLS enabled");
	client->transport.type = MQTT_TRANSPORT_SECURE;
	tls_cfg->peer_verify = CONFIG_MQTT_TLS_PEER_VERIFY;
	tls_cfg->cipher_count = 0;
	tls_cfg->cipher_list = NULL;
	tls_cfg->sec_tag_count = ARRAY_SIZE(sec_tag_list);
	tls_cfg->sec_tag_list = sec_tag_list;
	tls_cfg->hostname = CONFIG_MQTT_BROKER_HOSTNAME;
	tls_cfg->session_cache = IS_ENABLED(CONFIG_MQTT_TLS_SESSION_CACHING) ?
					    TLS_SESSION_CACHE_ENABLED :
					    TLS_SESSION_CACHE_DISABLED;
#else
	/* TLS session caching is not supported by the Zephyr network stack */
	tls_cfg->session_cache = TLS_SESSION_CACHE_DISABLED;
#endif
#else
	client->transport.type = MQTT_TRANSPORT_NON_SECURE;
#endif
	return err;
/**@brief Initialize the file descriptor structure used by poll.
static int fds_init(struct mqtt_client *c)
	if (c->transport.type == MQTT_TRANSPORT_NON_SECURE) {
		fds.fd = c->transport.tcp.sock;
	} else {
		fds.fd = c->transport.tls.sock;
#else
		return -ENOTSUP;
#endif
	fds.events = POLLIN;
	return 0;
#if defined(CONFIG_DK_LIBRARY)
static void button_handler(uint32_t button_states, uint32_t has_changed)
	if (has_changed & button_states &
	    BIT(CONFIG_BUTTON_EVENT_BTN_NUM - 1)) {
		int ret;
		ret = data_publish(&client,
				   CONFIG_BUTTON_EVENT_PUBLISH_MSG,
				   sizeof(CONFIG_BUTTON_EVENT_PUBLISH_MSG)-1);
		if (ret) {
			LOG_ERR("Publish failed: %d", ret);
#endif
static int shell_mqtt_publish(const struct shell *shell, size_t argc, char **argv)
	ARG_UNUSED(argc);
	ARG_UNUSED(argv);
	int ret;
			   sizeof(CONFIG_BUTTON_EVENT_PUBLISH_MSG) - 1);
	if (ret) {
	return ret;
SHELL_STATIC_SUBCMD_SET_CREATE(mqtt_sub,
		SHELL_CMD(publish, NULL, "Publish data to configured publish topic",
			shell_mqtt_publish),
		SHELL_SUBCMD_SET_END /* Array terminated. */
SHELL_CMD_REGISTER(mqtt, &mqtt_sub, "MQTT operations", NULL);
/**@brief Configures modem to provide LTE link. Blocks until link is
 * successfully established.
static int modem_configure(void)
#if defined(CONFIG_LTE_LINK_CONTROL)
	/* Turn off LTE power saving features for a more responsive demo. Also,
	 * request power saving features before network registration. Some
	 * networks rejects timer updates after the device has registered to the
	 * LTE network.
	LOG_INF("Disabling PSM and eDRX");
	//lte_lc_psm_req(false);
	//lte_lc_edrx_req(false);
	int err;
	LOG_INF("LTE Link Connecting...");
	err = lte_lc_init_and_connect_async(lte_handler);
	if (err) {
		LOG_INF("Failed to establish LTE connection: %d", err);
		return err;
	LOG_INF("LTE Link Connected!");
#endif /* defined(CONFIG_LTE_LINK_CONTROL) */
	return 0;
void main(void)
	int err;
	uint32_t connect_attempt = 0;
	LOG_INF("The MQTT simple sample started");
	err = certificates_provision();
	if (err != 0) {
		LOG_ERR("Failed to provision certificates");
		return;
	do {
		err = modem_configure();
		if (err) {
			LOG_INF("Retrying in %d seconds",
				CONFIG_LTE_CONNECT_RETRY_DELAY_S);
			k_sleep(K_SECONDS(CONFIG_LTE_CONNECT_RETRY_DELAY_S));
	} while (err);
	err = client_init(&client);
	if (err != 0) {
		LOG_ERR("client_init: %d", err);
		return;
	dk_buttons_init(button_handler);
#endif
do_connect:
	if (connect_attempt++ > 0) {
		LOG_INF("Reconnecting in %d seconds...",
			CONFIG_MQTT_RECONNECT_DELAY_S);
		k_sleep(K_SECONDS(CONFIG_MQTT_RECONNECT_DELAY_S));
	err = mqtt_connect(&client);
	if (err != 0) {
		LOG_ERR("mqtt_connect %d", err);
		goto do_connect;
	err = fds_init(&client);
	if (err != 0) {
		LOG_ERR("fds_init: %d", err);
		return;
	while (1) {
		err = poll(&fds, 1, mqtt_keepalive_time_left(&client));
		if (err < 0) {
			LOG_ERR("poll: %d", errno);
			break;
		err = mqtt_live(&client);
		if ((err != 0) && (err != -EAGAIN)) {
			LOG_ERR("ERROR: mqtt_live: %d", err);
			break;
		if ((fds.revents & POLLIN) == POLLIN) {
			err = mqtt_input(&client);
			if (err != 0) {
				LOG_ERR("mqtt_input: %d", err);
				break;
		if ((fds.revents & POLLERR) == POLLERR) {
			LOG_ERR("POLLERR");
			break;
		if ((fds.revents & POLLNVAL) == POLLNVAL) {
			LOG_ERR("POLLNVAL");
			break;
	err = mqtt_disconnect(&client);
	if (err) {
		LOG_ERR("Could not disconnect MQTT client: %d", err);
	goto do_connect;
