Hi, I’m sure the SIM card is inserted, antenna is correctly installed, sim is activated and LTE-M service is in my area because the sample works out of the box. If I simply run the sample as is, the nrf9160 feather makes a number of POST requests to www.circuitdojo.com/some/path which succeed.
If I make the following changes, however, the app silently fails and resets trying to active the LTE network on line err = lte_lc_connect();
In Kconfig:
   config CLOUD_HOSTNAME
        string "Base URL"
-       default "www.circuitdojo.com"
+       default "okthatworks.com"
Also in Kconfig
 config CLOUD_PUBLISH_PATH
     string "Publish Path"
-    default "/some/path"
+    default "/api/test"
Those are the only changes. The root cert for okthatworks.com is identical to the www.circuitdojo.com root cert, because both domains use certs that are chained up to lets encrypt. Also, the following command shows that the issue isn’t the server:
curl https://okthatworks.com/api/test -X POST -H "Content-Type: application/json" -d '{"do_something":true}'
returns:
data: { do_something: true }%
That api/test route just echos whatever json data is POSTed into it.
@AchimKraus : I am actually using the nfed/samples/https/ sample! Sorry if that wasn’t clear.
I would modify the values in the Kconfig using an overlay (.conf) or add your values to the project’s prj.conf.
Nevertheless, seems like you have a connection issue:
[00:00:00.541,351] <inf> main: Connecting to LTE
[00:10:00.585,845] <inf> lte_lc: Network connection attempt timed out
[00:10:00.622,406] <inf> lte_lc: Using fallback network mode
This is indicative of not being able to connect to the cell towers. Though there is one caveat:
I have encountered a bug in the past where if you connect/disconnect frequently during testing the modem will time out trying to connect. It’s very difficult to reproduce for Nordic to look at.
What version of the SDK and toolchain are you using?
That sounds really strange. I haven’t observed, that changing the destination causes the modem to even not register in the cellular network. The only idea would be to use a “–pristine” build, if you didn’t already do so.
This bug is completely unexplainable to me…. Could one of you please try to repro it? I think the process would be change those two lines in kconfig to point the example at my server and see if you get the same error. If you get the same behavior, then I think that would mean there is something wrong with the DNS or certs on my server. Maybe? Otherwise, I don’t know what else to do. Maybe it’s a hardware issue?
One other clue is that if I run ngrock and point the nrf9160 to my local server (through the ngrock service) I get a slightly different error (I’ve turned on modem debug output):
Connecting..
Connected to /dev/cu.usbserial-110!
*** Booting Zephyr OS build v3.3.99-ncs1-2 ***
[00:00:00.252,838] <inf> main: HTTPS Sample. Board: circuitdojo_feather_nrf9160
[00:00:00.544,677] <inf> cloud: Certificate match
[00:00:00.554,107] <inf> main: lte init
[00:00:00.554,565] <inf> main: power saving on
+CEREG: 2,"8B3A","0A128E0F",7
+CSCON: 1
+CEREG: 5,"8B3A","0A128E0F",7,,,"00001000","00100110"
%XTIME: "2B","4221324054712B","00"
[00:00:09.058,166] <inf> main: lte connected
[00:00:09.058,319] <inf> cloud: Publish path: 8b47-157-131-113-156.ngrok-free.app/api/test
[00:00:09.058,349] <inf> cloud: Payload: {"do_something": "true"}
[00:00:09.058,380] <inf> cloud: Looking up 8b47-157-131-113-156.ngrok-free.app
It then resets. So, this gets a bit further, but still has issues at the basic level of setting up the socket.
Thanks so much for your help!
I miss the answer.
That would require the answer, which nfed version you use.
Here’s some output from the top of the build pristine command:
-- Application: /Users/oh/Desktop/dojo/nfed/samples/https
-- CMake version: 3.22.0
-- Using NCS Toolchain 2.6.20240304.378197178396 for building. (/opt/nordic/ncs/toolchains/580e4ef81c/cmake)
-- Found Python3: /opt/nordic/ncs/toolchains/580e4ef81c/bin/python3 (found suitable exact version "3.9.6") found components: Interpreter
-- Cache files will be written to: /Users/oh/Library/Caches/zephyr
-- Zephyr version: 3.3.99 (/Users/oh/Desktop/dojo/zephyr)
-- Found west (found suitable version "1.2.0", minimum required is "0.7.1")
-- Found host-tools: zephyr 0.16.4 (/Users/oh/.zephyrtools/toolchain/zephyr-sdk-0.16.4)
-- Found toolchain: zephyr 0.16.4 (/Users/oh/.zephyrtools/toolchain/zephyr-sdk-0.16.4)
-- Found Dtc: /opt/nordic/ncs/toolchains/580e4ef81c/bin/dtc (found suitable version "1.6.1", minimum required is "1.4.6")
-- Found BOARD.dts: /Users/oh/Desktop/dojo/zephyr/boards/arm/circuitdojo_feather_nrf9160/circuitdojo_feather_nrf9160_ns.dts
-- Generated zephyr.dts: /Users/oh/Desktop/dojo/nfed/samples/https/build/circuitdojo_feather_nrf9160_ns/zephyr/zephyr.dts
-- Generated devicetree_generated.h: /Users/oh/Desktop/dojo/nfed/samples/https/build/circuitdojo_feather_nrf9160_ns/zephyr/include/generated/devicetree_generated.h
-- Including generated dts.cmake file: /Users/oh/Desktop/dojo/nfed/samples/https/build/circuitdojo_feather_nrf9160_ns/zephyr/dts.cmake
warning: Experimental symbol HTTP_CLIENT is enabled.
That seems like the most authoritative way for me to answer your question. I hope I got that right.
Thank you so much for your help so far.
Jason
I’m realizing that perhaps I should have included more of the pristine output here.
-- west build: making build dir /Users/oh/Desktop/dojo/nfed/samples/https/build/circuitdojo_feather_nrf9160_ns pristine
Parsing /Users/oh/Desktop/dojo/nfed/samples/https/Kconfig
Loaded configuration '/Users/oh/Desktop/dojo/zephyr/boards/arm/circuitdojo_feather_nrf9160/circuitdojo_feather_nrf9160_ns_defconfig'
Merged configuration '/Users/oh/Desktop/dojo/nfed/samples/https/prj.conf'
Merged configuration '/Users/oh/Desktop/dojo/nfed/samples/https/boards/circuitdojo_feather_nrf9160_ns.conf'
Configuration saved to '/Users/oh/Desktop/dojo/nfed/samples/https/build/circuitdojo_feather_nrf9160_ns/zephyr/.config'
Kconfig header saved to '/Users/oh/Desktop/dojo/nfed/samples/https/build/circuitdojo_feather_nrf9160_ns/zephyr/include/generated/autoconf.h'
-- Found GnuLd: /Users/oh/.zephyrtools/toolchain/zephyr-sdk-0.16.4/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd (found version "2.38")
-- Found assembler: /Users/oh/.zephyrtools/toolchain/zephyr-sdk-0.16.4/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc
-- Found Python3: /opt/nordic/ncs/toolchains/580e4ef81c/bin/python3 (found version "3.9.6") found components: Interpreter
=== child image mcuboot -  begin ===
loading initial cache file /Users/oh/Desktop/dojo/nfed/samples/https/build/circuitdojo_feather_nrf9160_ns/mcuboot/child_image_preload.cmake
-- Application: /Users/oh/Desktop/dojo/bootloader/mcuboot/boot/zephyr
-- Found BOARD.dts: /Users/oh/Desktop/dojo/zephyr/boards/arm/circuitdojo_feather_nrf9160/circuitdojo_feather_nrf9160.dts
-- Found devicetree overlay: /Users/oh/Desktop/dojo/bootloader/mcuboot/boot/zephyr/app.overlay
-- Generated zephyr.dts: /Users/oh/Desktop/dojo/nfed/samples/https/build/circuitdojo_feather_nrf9160_ns/mcuboot/zephyr/zephyr.dts
-- Generated devicetree_generated.h: /Users/oh/Desktop/dojo/nfed/samples/https/build/circuitdojo_feather_nrf9160_ns/mcuboot/zephyr/include/generated/devicetree_generated.h
-- Including generated dts.cmake file: /Users/oh/Desktop/dojo/nfed/samples/https/build/circuitdojo_feather_nrf9160_ns/mcuboot/zephyr/dts.cmake
warning: UART_CONSOLE (defined at drivers/console/Kconfig:43) was assigned the value 'y' but got the
Parsing /Users/oh/Desktop/dojo/bootloader/mcuboot/boot/zephyr/Kconfig
Loaded configuration '/Users/oh/Desktop/dojo/zephyr/boards/arm/circuitdojo_feather_nrf9160/circuitdojo_feather_nrf9160_defconfig'
Merged configuration '/Users/oh/Desktop/dojo/bootloader/mcuboot/boot/zephyr/prj.conf'
Merged configuration '/Users/oh/Desktop/dojo/bootloader/mcuboot/boot/zephyr/boards/circuitdojo_feather_nrf9160.conf'
Merged configuration '/Users/oh/Desktop/dojo/nrf/modules/mcuboot/tfm.conf'
Merged configuration '/Users/oh/Desktop/dojo/nrf/modules/mcuboot/fih_low_enable.conf'
Merged configuration '/Users/oh/Desktop/dojo/nrf/subsys/partition_manager/partition_manager_enabled.conf'
Merged configuration '/Users/oh/Desktop/dojo/nfed/samples/https/build/circuitdojo_feather_nrf9160_ns/mcuboot/zephyr/misc/generated/extra_kconfig_options.conf'
Configuration saved to '/Users/oh/Desktop/dojo/nfed/samples/https/build/circuitdojo_feather_nrf9160_ns/mcuboot/zephyr/.config'
Kconfig header saved to '/Users/oh/Desktop/dojo/nfed/samples/https/build/circuitdojo_feather_nrf9160_ns/mcuboot/zephyr/include/generated/autoconf.h'
CMake Warning at /Users/oh/Desktop/dojo/zephyr/CMakeLists.txt:839 (message):
  No SOURCES given to Zephyr library: lib__libc__common
  Excluding target from build.
MCUBoot bootloader key file: /Users/oh/Desktop/dojo/bootloader/mcuboot/root-ec-p256.pem
-- Configuring done
-- Generating done
-- Build files have been written to: /Users/oh/Desktop/dojo/nfed/samples/https/build/circuitdojo_feather_nrf9160_ns/mcuboot
=== child image mcuboot -  end ===
CMake Warning at /Users/oh/Desktop/dojo/nrf/modules/mcuboot/CMakeLists.txt:310 (message):
          --- be used for production.                           ---
Using nrf9160-feather-examples-and-drivers - v2.6.x I get:
nfed/samples/https:
west build -b circuitdojo_feather_nrf9160_ns -p
[00:00:00.250,488] <inf> main: HTTPS Sample. Board: circuitdojo_feather_nrf9160
[00:00:00.547,973] <inf> cloud: Certificate match
[00:00:05.344,146] <inf> cloud: Publish path: www.circuitdojo.com/some/path
[00:00:05.344,299] <inf> cloud: Payload: {“do_something”:true}
[00:00:05.344,329] <inf> cloud: Looking up www.circuitdojo.com
[00:00:07.824,737] <inf> cloud: Connected!
[00:00:07.824,768] <inf> cloud: Socket setup complete
[00:00:08.175,689] <inf> cloud: HTTP Status 200
[00:00:08.175,811] <inf> cloud: HTTP Status 200
[00:00:08.175,933] <inf> cloud: HTTP Status 200
[00:00:08.176,055] <inf> cloud: HTTP Status 200
[00:00:08.289,276] <inf> cloud: HTTP Status 200
[00:00:08.289,367] <inf> cloud: HTTP Status 200
[00:00:08.289,489] <inf> cloud: HTTP Status 200
[00:00:08.289,611] <inf> cloud: HTTP Status 200
[00:00:08.289,825] <inf> cloud: HTTP Status 200
[00:00:08.289,947] <inf> cloud: HTTP Status 200
[00:00:08.290,039] <inf> cloud: HTTP Status 200
[00:00:08.290,161] <inf> cloud: HTTP Status 200
[00:00:08.290,313] <inf> cloud: HTTP Status 200
[00:00:08.319,396] <inf> cloud: HTTP Status 200
[00:00:08.319,519] <inf> cloud: HTTP Status 200
[00:00:08.319,671] <inf> cloud: HTTP Status 200
[00:00:08.360,382] <inf> cloud: Data sent to cloud
and with
west build -b circuitdojo_feather_nrf9160_ns -p -- -DCONFIG_CLOUD_HOSTNAME="\"okthatworks.com\"" -DCONFIG_CLOUD_PUBLISH_PATH="\"/api/test\""
*** Booting nRF Connect SDK v3.5.99-ncs1-1 ***
[00:00:00.547,760] <inf> cloud: Certificate match
[00:00:05.650,573] <inf> cloud: Publish path: okthatworks.com/api/test
[00:00:05.650,726] <inf> cloud: Payload: {“do_something”:true}
[00:00:05.650,756] <inf> cloud: Looking up okthatworks.com
[00:00:06.118,774] <err> cloud: Unable to connect. Err: -111 - Connection refused
[00:00:06.122,406] <err> os: ***** BUS FAULT *****
[00:00:06.122,406] <err> os: Precise data bus error
[00:00:06.122,436] <err> os: BFAR Address: 0×0
[00:00:06.122,436] <err> os: r0/a1: 0xfffffffc r1/a2: 0×20013c2c r2/a3: 0×2000d394
[00:00:06.122,467] <err> os: r3/a4: 0×00000020 r12/ip: 0×00000000 r14/lr: 0×0002e381
[00:00:06.122,467] <err> os: xpsr: 0×21000000
[00:00:06.122,497] <err> os: Faulting instruction address (r15/pc): 0×0002ad04
[00:00:06.122,528] <err> os: >>> ZEPHYR FATAL ERROR 25: Unknown error on CPU 0
[00:00:06.122,558] <err> os: Current thread: 0×2000d240 (unknown)
[00:00:06.211,975] <err> fatal_error: Resetting system
A look at the certificates shows:
“www.circuitdojo.com” => ECDSA 256, “E5” => ECDSA 384, “ISRG Root X1” => RSA 4096
“okthatworks.com” => RSA 2048, “R10” => RSA 20248, “ISRG Root X1” => RSA 4096
My guess, the RSA chain is over the size limit of the nRF9160 for certificates.
Not sure, what you want to do in the end, but this smells like something, which will fail in both, energy consumption and reliability. In my experience, RSA is not “ok” for embedded ;-).
Edited:
    /* Cipher suite */
    // Cipher Suite: TLS_ECDHE_ECDSA_WITH_AES_128_GCM_SHA256 (0xc02b)
    nrf_sec_cipher_t cipher_list[] = {0xc02b};
may also prevent to be able to connect …
It may require a modem trace. Maybe “okthatworks.com” offers ECDSA as well and only my browser got the RSA stuff.
[00:00:00.547,698] <inf> cloud: Certificate match
[00:00:05.196,502] <inf> cloud: Publish path: okthatworks.com/api/test
[00:00:05.196,655] <inf> cloud: Payload: {“do_something”:true}
[00:00:05.196,685] <inf> cloud: Looking up okthatworks.com
[00:00:06.577,056] <inf> cloud: Connected!
[00:00:06.577,117] <inf> cloud: Socket setup complete
[00:00:08.178,375] <inf> cloud: HTTP Status 200
[00:00:08.186,950] <inf> cloud: HTTP Status 200
[00:00:08.187,011] <inf> cloud: Response data
66 65 74 63 68 0d 0a 58 2d 4d 61 74 63 68 65 64 |fetch..X -Matched
2d 50 61 74 68 3a 20 2f 61 70 69 2f 74 65 73 74 |-Path: / api/test
0d 0a 58 2d 56 65 72 63 65 6c 2d 43 61 63 68 65 |..X-Verc el-Cache
3a 20 4d 49 53 53 0d 0a 58 2d 56 65 72 63 65 6c |: MISS.. X-Vercel
2d 49 64 3a 20 6c 68 72 31 3a 3a 69 61 64 31 3a |-Id: lhr 1::iad1:
3a 32 36 67 6d 66 2d 31 37 33 35 33 37 32 38 36 |:26gmf-1 73537286
38 33 38 36 2d 38 34 36 62 30 65 64 31 39 63 39 |8386-846 b0ed19c9
35 0d 0a 43 6f 6e 6e 65 63 74 69 6f 6e 3a 20 63 |5..Conne ction: c
6c 6f 73 65 0d 0a 54 72 61 6e 73 66 65 72 2d 45 |lose..Tr ansfer-E
6e 63 6f 64 69 6e 67 3a 20 63 68 75 6e 6b 65 64 |ncoding: chunked
0d 0a 0d 0a 31 63 0d 0a 64 61 74 61 3a 20 7b 20 |….1c.. data: {
64 6f 5f 73 6f 6d 65 74 68 69 6e 67 3a 20 74 72 |do_somet hing: tr
75 65 20 7d 0d 0a 30 0d 0a 0d 0a 30 0d 0a 56 61 |ue }..0. …0..Va
72 79 3a 20 52 53 43 2c 20 4e 65 78 74 2d 52 6f |ry: RSC, Next-Ro
75 74 65 72 2d 53 74 61 74 65 2d 54 72 65 65 2c |uter-Sta te-Tree,
20 4e 65 78 74 2d 52 6f 75 74 65 72 2d 50 72 65 | Next-Ro uter-Pre
[00:00:08.187,011] <inf> main: Cloud callback
[00:00:08.188,232] <inf> cloud: Data sent to cloud
After removing
err = setsockopt(fd, SOL_TLS, TLS_CIPHERSUITE_LIST, cipher_list, sizeof(cipher_list));
it works on my “feather” :.
On a nRF9160-DK with modem-trace I get from “okthatworks.com” :-)
Cipher Suite: TLS_ECDHE_RSA_WITH_AES_128_GCM_SHA256 (0xc02f)
Certificates (2561 bytes)
    Certificate Length: 1266
    Certificate: 308204ee308203d6a003020102021204fdf5078dd54f131032441184ac19bb8e4f300d06… (id-at-commonName=okthatworks.com)
        signedCertificate
        algorithmIdentifier (sha256WithRSAEncryption)
        Padding: 0
        encrypted: 28c188af4c8567c71c6a7f49e9dd4f45b4209a3b0bc53578ba52d90716d389e2ab38c565…
    Certificate Length: 1289
    Certificate: 30820505308202eda00302010202104ba85293f79a2fa273064ba8048d75d0300d06092a… (id-at-commonName=R10,id-at-organizationName=Let's Encrypt,id-at-countryName=US)
        signedCertificate
        Padding: 0
        encrypted: 92b1e74137eb799d81e6cde225e13a20e9904495a3815ccfc35dfdbda070d5b19628220b…
So, it’s really about 2K RSA certificates.
Wow, amazing work. Thank you so much for this. I’ll see if I can just purchase an RSA cert and install it on that domain.
Thank you so much!
Jason
    theIntuitionist
    ECDSA works for embedded devices and cellular communication much better than RSA.
    I personally even don’t use x509, I use RFC7250 (Raw Public Key). I also don’t use HTTP/TCP, I use CoAP/UDP and a proxy to forward that to a HTTP API.
    Not sure, maybe let’s encrypt helps.
    Thank you so much!
    you’re welcome.
    I have mqtt up and running for message passing, but was working on https to post large files- somewhere around a few megabytes in size more or less (prob a bit less, frequently)- for storage on a server. What do you think the best communications mode is for this task?
    Sounds like a camera-trap. That’s not my domain.
    I mainly use it for low-power monitoring/metering. That’s more or less “200-600” bytes every hour.
    From other tickets (mainly in the Nordic Forum), you will need to be careful, because the nRF9160 is no Raspberry PI and some approaches may fail, just because RAM isn’t available in MBytes ;-).
