Hi
We’ve got a couple of nRF9151 Feathers. We are trying to simulate a target board where power consumption is critical.
We’ve connected a Nordic PPK2 to the battery input and are using it as a source meter - this works well.
We’d like to disable the RP2040 since this is not present on our target. I see there is a VDDIO_EN input on U11, the regulator for the RP2040 power domain, but I can’t see the origin of this signal. Is it user accessible?
Kind regards
Tim
Hi Tim
Thanks for your purchase!
You can definitely disable the RP2040. It’s done half in hardware and half in software.
Hardware:
There is a load switch that controls VDDIO. This can be activated either by plugging in VBUS or bringing the VDDIO_EN signal high. This is connected to the GPIO0 pin on the PMIC.
Software
In the 2.7.x branch of NFED, the active_sleep outlines how to turn of the VCC (BUCK2 on the nPM1300)
The big thing is to enable regulator control in your boards/circuitdojo_feather_nrf9151_ns.conf:
# Regulator control
CONFIG_REGULATOR=y
CONFIG_REGULATOR_NPM1300=y
Then in your code:
#include <zephyr/drivers/mfd/npm1300.h>
#include <zephyr/drivers/regulator.h>
/* Addresses */
#define NPM1300_BUCK_BASE 0x04U
#define NPM1300_BUCK_OFFSET_EN_CLR 0x01U
#define NPM1300_BUCK_BUCKCTRL0 0x15U
#define NPM1300_BUCK_STATUS 0x34U
/* Bits */
#define NPM1300_BUCK2_MODE_BIT BIT(0)
#define NPM1300_BUCK2_PULLDOWN_EN BIT(3)
static const struct device *buck2 = DEVICE_DT_GET(DT_NODELABEL(npm1300_buck2))
static int setup_pmic()
#if defined(CONFIG_BOARD_CIRCUITDOJO_FEATHER_NRF9161) || defined(CONFIG_BOARD_CIRCUITDOJO_FEATHER_NRF9151)
  int err;
  /* Get pmic */
  static const struct device *pmic = DEVICE_DT_GET(DT_NODELABEL(npm1300_pmic));
  if (!pmic)
    LOG_ERR("Failed to get PMIC device\n");
    return -ENODEV;
  /* Disable if not already disabled */
  if (regulator_is_enabled(buck2))
    err = regulator_disable(buck2);
    if (err < 0)
      LOG_ERR("Failed to disable buck2: %d", err);
      return err;
  uint8_t reg = 0;
  /* See if pulldown is not already enabled */
  err = mfd_npm1300_reg_read(pmic, NPM1300_BUCK_BASE, NPM1300_BUCK_BUCKCTRL0,
                             &reg);
  if (err < 0)
    LOG_ERR("Failed to set VBUSINLIM. Err: %d", err);
  if ((reg & (NPM1300_BUCK2_PULLDOWN_EN)) == 0)
    /* Write to MFD to enable pulldown for BUCK2 */
    err = mfd_npm1300_reg_write(pmic, NPM1300_BUCK_BASE, NPM1300_BUCK_BUCKCTRL0,
                                NPM1300_BUCK2_PULLDOWN_EN);
    if (err < 0)
#endif
  return 0;
You can call the setup_pmic() function where ever it’s safe to do so for I2C transaction (I suggest keeping all I2C operations on one thread).
This will disable the BUCK and enable the pull-down to make sure VCC isn’t floating around causing issues.
I’m going to work on a reference that will dynamically power the RP2040 so you don’t have to invoke any of this yourself. Stay tuned on that.
@AchimKraus did test out the USB detect interrupt and it does work so half the work is already done. 😃
One final thing I would recommend you do in the firmware: add a 2 second delay in your app before you invoke the buck2 power down function. That way you can still halt/reset/program the board. If you do it too quickly, it can be a bit tricky to get it back to a happy state. As far as I remember if you hold reset while plugging in USB and then immediately program your code of choice should un-stick it. (Never-mind on this suggestion, I built it into the nfed/boards/circuitdojo/feather_nrf9151/startup.c file a while ago as I foresaw this being an issue. Therefore, adding an extra delay, while it doesn’t hurt, isn’t necessary.)
I hope that helps get you started.
P.S. if you load up the active_sleep sample you should get < 10uA sleep. Last time I measured a couple boards it was more like 5uA at room temp.
    jaredwolff This will disable the BUCK and enable the pull-down to make sure VCC isn’t floating around causing issues.
    Good to know that with the pull-down. That’s something I’ll need to add.
    That’s wonderful @jaredwolff, I will try the active_sleep sample as soon as I get a chance. Thanks very much for your detailed response 🙂
    Current in active_sleep since I’m looking at it 😄
    a month later
    Hello,
    I know this topic is rather old, but i have a question regarding this part of the circuit.
    VDDIO_EN pin is connected to GPIO0 of the npm1300, But I couldn’t find any configuration for this pin on the firmware. Could you explain its functionality?
    Thanks
    This allows for powering the RP2040 when unplugged from USB.
