managed to get a bit further, but not much. Here’s the log:
note: pip –version (response) and the pip new release error - which is incorrect.
pip 25.2 from /Library/Frameworks/Python.framework/Versions/3.13/lib/python3.13/site-packages/pip (python 3.13)
********** LOG START *************
FATAL ERROR: already initialized in /opt/nordic/ncs/zephyrproject, aborting.
Note:
In your environment, ZEPHYR_BASE is set to:
/opt/nordic/ncs/zephyrproject/zephyr
This forces west to search for a workspace there.
Try unsetting ZEPHYR_BASE and re-running this command.
=== updating acpica (modules/lib/acpica):
HEAD is now at 8d24867bc Merge pull request #5 from dcpleung/kernel/mm_z_phys_map_unmap_rename
=== updating cmsis (modules/hal/cmsis):
HEAD is now at d1b8b20 Backport CMSIS_6#102 to CMSIS 5.9.0
=== updating cmsis-dsp (modules/lib/cmsis-dsp):
HEAD is now at d80a49b2 do not generate warnings when scalar functions are used with MVE
=== updating cmsis-nn (modules/lib/cmsis-nn):
HEAD is now at e9328d6 manifest: zephyr module file
=== updating cmsis_6 (modules/hal/cmsis_6):
HEAD is now at 6dd50439 cmsis_6: Integrate with zephyr build system
=== updating edtt (tools/edtt):
HEAD is now at b9ca3c7 Fix for for python >= 3.11
=== updating fatfs (modules/fs/fatfs):
HEAD is now at 16245c7 fs: Update driver to version 0.15a
=== updating hal_adi (modules/hal/adi):
HEAD is now at f8f6547 chore(PeriphDrivers): Replace pow() with left shift in UART drivers
=== updating hal_ambiq (modules/hal/ambiq):
HEAD is now at 080be37 hal: cmakelist: add uart hal support for apollo510
=== updating hal_atmel (modules/hal/atmel):
HEAD is now at ca7e4c6 sam3x: spi: missing adc macro
=== updating hal_bouffalolab (modules/hal/bouffalolab):
HEAD is now at 5811738 bflb: add register files for bl60x
=== updating hal_espressif (modules/hal/espressif):
HEAD is now at 19deab4177 esp32c2: rom: use puts from system libc
=== updating hal_ethos_u (modules/hal/ethos_u):
HEAD is now at 50ddffc Cache optimizations
=== updating hal_gigadevice (modules/hal/gigadevice):
HEAD is now at 2994b7d README.md: add pllmf and pack exception for gd32a50x
=== updating hal_infineon (modules/hal/infineon):
HEAD is now at e0a50ce hal: infineon: Update bt_stack-integration for 20829
=== updating hal_intel (modules/hal/intel):
HEAD is now at 0447cd2 Update pm_regs.h
=== updating hal_microchip (modules/hal/microchip):
HEAD is now at 15ca197 hal: microchip: mec5: Fix bugs in EC subsystem debug enable
=== updating hal_nordic (modules/hal/nordic):
HEAD is now at a5a2277 nrfx: drivers: rramc: Declare functions as unused
=== updating hal_nuvoton (modules/hal/nuvoton):
HEAD is now at be1042d hal:nuvoton:m55m1: support emac
=== updating hal_nxp (modules/hal/nxp):
HEAD is now at a961ce3b drivers: usdhc: change the driver to be aarch64 compatible
=== updating hal_openisa (modules/hal/openisa):
HEAD is now at eabd530 fix-double-promotion in fsl_xcvr_trim
=== updating hal_quicklogic (modules/hal/quicklogic):
HEAD is now at bad8944 HAL: eoss3_dev: add missing __cplusplus
handling
=== updating hal_renesas (modules/hal/renesas):
HEAD is now at 9d68ee7 portable: rp_crc: add runtime reconfigure for CRC
=== updating hal_rpi_pico (modules/hal/rpi_pico):
HEAD is now at 7b57b24 Merge pull request #8 from ajf58/merge-2.1.0
=== updating hal_silabs (modules/hal/silabs):
HEAD is now at 389726f wiseconnect: Avoid symbols conflicts in PSRAM driver
=== updating hal_st (modules/hal/st):
HEAD is now at 9f81b44 sensor/stmemsc: Align stmemsc i/f to v2.9.1
=== updating hal_stm32 (modules/hal/stm32):
HEAD is now at 6e4716f8 dts: st: update pinctrls related to dcmipp pins
=== updating hal_tdk (modules/hal/tdk):
HEAD is now at 6727477 Merge pull request #8 from tdk-invn-oss/main
=== updating hal_telink (modules/hal/telink):
HEAD is now at 4226c7f drivers: Disable BLE support
=== updating hal_ti (modules/hal/ti):
HEAD is now at 258652a simplelink_lpf3: Add README.md
=== updating hal_wch (modules/hal/wch):
HEAD is now at 1de9d3e Add hal_wch based on the ‘ch32v003fun’ project
=== updating hal_wurthelektronik (modules/hal/wurthelektronik):
HEAD is now at e3e2797 Remove preprocessor warnings for not enabling float
=== updating hal_xtensa (modules/hal/xtensa):
HEAD is now at b38620c zephyr: Add SoC overlay for i.MXRT700 HiFi1 DSP
=== updating hostap (modules/lib/hostap):
HEAD is now at 8412f4b23 [noup] zephyr: remove zephyr wpas monitor socket pair
=== updating liblc3 (modules/lib/liblc3):
HEAD is now at 48bbd3e Rename lc3 python package to lc3py, and bump version to 1.1.2
=== updating libmctp (modules/lib/libmctp):
HEAD is now at b97860e build MCTP zephyr library only when CONFIG_MCTP is enabled
=== updating libmetal (modules/hal/libmetal):
HEAD is now at 14f5195 lib: update libmetal to SHA 9a21915a5f8f
=== updating littlefs (modules/fs/littlefs):
HEAD is now at ed0531d Merge pull request #15 from Jappie3/zephyr
=== updating loramac-node (modules/lib/loramac-node):
HEAD is now at fb00b383 zephyr: configure FragDecoder using Kconfig
=== updating lvgl (modules/lib/gui/lvgl):
HEAD is now at 1ed1ddd88 docs(Alif): add docs for Alif chip vendor (#7622)
=== updating mbedtls (modules/crypto/mbedtls):
HEAD is now at 5f8899343 Merge pull request #70 from tomi-font/bump_to_3.6.3
=== updating mcuboot (bootloader/mcuboot):
HEAD is now at 990b1fcb docs: release-notes: Add additional fixes
=== updating mipi-sys-t (modules/debug/mipi-sys-t):
HEAD is now at 33e5c23 Fix for warning of potential error using = instead of ==
=== updating net-tools (tools/net-tools):
HEAD is now at 986bfeb Replace native_posix with native_sim
=== updating nrf_hw_models (modules/bsim_hw_models/nrf_hw_models):
HEAD is now at d5b95fd grtc hal replacement: Fix bug in nrf_grtc_int_group_enable/disable()
=== updating nrf_wifi (modules/lib/nrf_wifi):
HEAD is now at e0adc31 nrf_wifi : Update Wi-Fi FW blobs and shared header file
=== updating open-amp (modules/lib/open-amp):
HEAD is now at f7f4d08 lib: update open-amp lib to SHA 9a21915a5f8f
=== updating openthread (modules/lib/openthread):
HEAD is now at 3ae741f95 [instance] fix index computation in multi-instances context (#11099)
=== updating percepio (modules/debug/percepio):
HEAD is now at 49e6dc2 Merge branch ‘main’ into zephyr
=== updating picolibc (modules/lib/picolibc):
HEAD is now at 82d62ed1a zephyr: Disable LTO when building the library
=== updating segger (modules/debug/segger):
HEAD is now at cf56b1d readme: Add readme
=== updating tinycrypt (modules/crypto/tinycrypt):
HEAD is now at 1012a3e Fix warnings reported by UBSAN
=== updating trusted-firmware-a (modules/tee/tf-a/trusted-firmware-a):
HEAD is now at 713ffbf96 Merge pull request #4 from ceolin/v2.10.4
=== updating trusted-firmware-m (modules/tee/tf-m/trusted-firmware-m):
HEAD is now at 64738996d Revert “platform: ext: add local copy of CMSIS v6 files”
=== updating uoscore-uedhoc (modules/lib/uoscore-uedhoc):
HEAD is now at 54abc10 Merge pull request #5 from rlubos/upmerge-02-2025
=== updating zcbor (modules/lib/zcbor):
HEAD is now at 9b07780 Update version to 0.9.1
Terminal will be reused by tasks, press any key to close it.
Executing task: “/Users/summer/.zephyrtools/env/bin/python” -m pip install -r zephyr/scripts/requirements.txt
[notice] A new release of pip is available: 25.0.1 -> 25.2
[notice] To update, run: python -m pip install –upgrade pip
ERROR: Could not open requirements file: [Errno 2] No such file or directory: ‘zephyr/scripts/requirements.txt’
- The terminal process “/bin/zsh ‘-l’, ‘-c’, ‘”/Users/summer/.zephyrtools/env/bin/python" -m pip install -r zephyr/scripts/requirements.txt’" terminated with exit code: 1.
- Terminal will be reused by tasks, press any key to close it.
