jaredwolff Yes. I have been able to connect and publish data. I’ve loaded x509 certs on, configured DPS, etc. I’m pasting more info from the session log below.
2021-02-09T22:23:54.316Z DEBUG modem << *** Booting Zephyr OS version 2.4.99 ***
2021-02-09T22:23:54.324Z DEBUG modem << Azure FOTA v0.1.2 started
2021-02-09T22:23:54.326Z DEBUG modem << Initializing modem library
2021-02-09T22:23:54.328Z DEBUG modem << This may take a while if a modem firmware update is pending
2021-02-09T22:23:54.330Z DEBUG modem << Modem library initialized
2021-02-09T22:23:54.344Z DEBUG modem << [00:00:00.224,090] [0m<inf> azure_iot_hub_dps: Setting DPS registration ID: mycordevice261[0m
2021-02-09T22:23:54.362Z DEBUG modem << [00:00:00.232,482] [0m<dbg> azure_iot_hub_dps.dps_reg_id_set: Saved DPS registration ID: mycordevice261[0m
2021-02-09T22:23:54.370Z DEBUG modem << [00:00:00.243,072] [0m<dbg> azure_iot_hub_dps.dps_settings_handler: Azure IoT Hub hostname found, DPS not needed: lab651hub.azure-devices.net[0m
2021-02-09T22:23:54.379Z DEBUG modem << [00:00:00.256,042] [0m<dbg> azure_iot_hub_dps.dps_on_settings_loaded: Settings fully loaded[0m
2021-02-09T22:23:54.388Z DEBUG modem << [00:00:00.264,556] [0m<dbg> azure_iot_hub.azure_iot_hub_init: DPS initialized[0m
2021-02-09T22:23:54.390Z DEBUG modem << [00:00:00.271,911] [0m<inf> azure_fota: Current firmware version: v0.1.2[0m
2021-02-09T22:23:54.405Z DEBUG modem << [00:00:00.278,778] [0m<dbg> azure_iot_hub.azure_iot_hub_init: Azure FOTA initialized[0m
2021-02-09T22:23:54.407Z DEBUG modem << [00:00:00.286,712] [0m<dbg> azure_iot_hub.connection_state_set: New connection state: STATE_INIT[0m
2021-02-09T22:23:54.409Z DEBUG modem << Connecting to LTE network
2021-02-09T22:24:58.945Z DEBUG modem << LTE cell changed: Cell ID: 5774613, Tracking area: 43524
2021-02-09T22:24:59.007Z DEBUG modem << RRC mode: Connected
2021-02-09T22:25:02.079Z DEBUG modem << Network registration status: Connected - roaming
2021-02-09T22:25:02.128Z DEBUG modem << [00:01:07.972,106] [0m<dbg> azure_iot_hub.connection_state_set: New connection state: STATE_CONNECTING[0m
2021-02-09T22:25:02.131Z DEBUG modem << PSM parameter update: TAU: -1, Active time: -1
2021-02-09T22:25:02.405Z DEBUG modem << [00:01:08.286,895] [0m<dbg> azure_iot_hub.broker_init: IPv4 Address found 20.49.109.129[0m
2021-02-09T22:25:02.407Z DEBUG modem << AZURE_IOT_HUB_EVT_CONNECTING
2021-02-09T22:25:12.105Z DEBUG modem << RRC mode: Idle
2021-02-09T22:25:12.184Z DEBUG modem << RRC mode: Connected
2021-02-09T22:25:13.092Z DEBUG modem << [00:01:18.975,646] [0m<dbg> azure_iot_hub.connection_state_set: New connection state: STATE_CONNECTED[0m
2021-02-09T22:25:13.103Z DEBUG modem << [00:01:18.984,985] [0m<dbg> azure_iot_hub.mqtt_evt_handler: MQTT client connected[0m
2021-02-09T22:25:13.117Z DEBUG modem << [00:01:18.992,706] [0m<dbg> azure_iot_hub.topic_subscribe: Subscribing to: devices/mycordevice261/messages/devicebound/#[0m
2021-02-09T22:25:13.120Z DEBUG modem << [00:01:19.003,692] [0m<dbg> azure_iot_hub.topic_subscribe: Subscribing to: $iothub/twin/PATCH/properties/desired/#[0m
2021-02-09T22:25:13.134Z DEBUG modem << [00:01:19.014,221] [0m<dbg> azure_iot_hub.topic_subscribe: Subscribing to: $iothub/twin/res/#[0m
2021-02-09T22:25:13.143Z DEBUG modem << [00:01:19.022,949] [0m<dbg> azure_iot_hub.topic_subscribe: Subscribing to: $iothub/methods/POST/#[0m
2021-02-09T22:25:13.151Z DEBUG modem << [00:01:19.033,142] [0m<dbg> azure_iot_hub.topic_subscribe: Successfully subscribed to default topics[0m
2021-02-09T22:25:13.152Z DEBUG modem << AZURE_IOT_HUB_EVT_CONNECTED
2021-02-09T22:25:13.471Z DEBUG modem << [00:01:19.354,461] [0m<dbg> azure_iot_hub.mqtt_evt_handler: MQTT_EVT_SUBACK: id = 13456 result = 0[0m
2021-02-09T22:25:13.482Z DEBUG modem << [00:01:19.363,586] [0m<dbg> azure_iot_hub.azure_iot_hub_send: Publishing to topic: $iothub/twin/GET/?$rid=79363[0m
2021-02-09T22:25:13.488Z DEBUG modem << [00:01:19.374,542] [0m<dbg> azure_iot_hub.device_twin_request: Device twin requested[0m
2021-02-09T22:25:13.492Z DEBUG modem << AZURE_IOT_HUB_EVT_READY
2021-02-09T22:25:13.814Z DEBUG modem << [00:01:19.698,028] [0m<dbg> azure_iot_hub.on_publish: MQTT_EVT_PUBLISH: id = 6, len = 297 [0m
2021-02-09T22:25:13.826Z DEBUG modem << [00:01:19.706,542] [0m<dbg> azure_iot_hub_topic.azure_iot_hub_topic_parse: Dynamic value: 200[0m
2021-02-09T22:25:13.834Z DEBUG modem << [00:01:19.715,179] [0m<dbg> azure_iot_hub_topic.get_next_prop_bag: Key: $rid[0m
2021-02-09T22:25:13.837Z DEBUG modem << [00:01:19.722,412] [0m<dbg> azure_iot_hub_topic.get_next_prop_bag: Value: 79363[0m
2021-02-09T22:25:13.851Z DEBUG modem << [00:01:19.729,888] [0m<dbg> azure_iot_hub.on_publish: Device twin data received[0m
2021-02-09T22:25:13.860Z DEBUG modem << [00:01:19.738,250] [0m<dbg> azure_fota.parse_reported_status: Currently reported ‘fwUpdateStatus’ in device twin: current[0m
2021-02-09T22:25:13.871Z DEBUG modem << [00:01:19.749,359] [0m<dbg> azure_fota.parse_reported_status: Currently reported ‘currentFwVersion’ in device twin: v0.1.2[0m
2021-02-09T22:25:13.883Z DEBUG modem << [00:01:19.760,589] [0m<dbg> azure_fota.parse_reported_status: Currently reported ‘pendingFwVersion’ in device twin: (none)[0m
2021-02-09T22:25:13.889Z DEBUG modem << [00:01:19.771,820] [0m<dbg> azure_fota.parse_reported_status: Currently reported version is correct[0m
2021-02-09T22:25:13.902Z DEBUG modem << [00:01:19.782,287] [0m<dbg> azure_fota.extract_fw_details: Incoming firmware version: v0.1.3[0m
2021-02-09T22:25:13.918Z DEBUG modem << [00:01:19.791,229] [0m<inf> azure_fota: Attempting to download firmware (version ‘v0.1.3’) from lab651storageaccount.blob.core.windows.net//mycor/app_update.bin[0m
2021-02-09T22:25:14.292Z DEBUG modem << [00:01:20.175,842] [0m<inf> download_client: Setting up TLS credentials, tag 261[0m
2021-02-09T22:25:14.300Z DEBUG modem << [00:01:20.183,410] [0m<inf> download_client: Configuring socket timeout (30 s)[0m
2021-02-09T22:25:14.307Z DEBUG modem << [00:01:20.190,765] [0m<inf> download_client: Connecting to lab651storageaccount.blob.core.windows.net[0m
2021-02-09T22:25:17.930Z DEBUG modem << [00:01:23.813,842] [0m<inf> download_client: Downloading: /mycor/app_update.bin [0][0m
2021-02-09T22:25:17.946Z DEBUG modem << [00:01:23.821,746] [0m<dbg> azure_fota.create_report: Created FOTA report: {“firmware”:{“fwUpdateStatus”:“downloading”,“currentFwVersion”:“v0.1.2”,“pendingFwVersion”:“v0.1.3”}}[0m
2021-02-09T22:25:17.952Z DEBUG modem << [00:01:23.837,585] [0m<dbg> azure_iot_hub.fota_evt_handler: AZURE_FOTA_EVT_START[0m
2021-02-09T22:25:17.967Z DEBUG modem << [00:01:23.845,245] [0m<dbg> azure_iot_hub.azure_iot_hub_send: Publishing to topic: $iothub/twin/PATCH/properties/reported/?$rid=83845[0m
2021-02-09T22:25:17.976Z DEBUG modem << [00:01:23.859,130] [0m<dbg> azure_iot_hub.fota_report_send: FOTA report sent[0m
2021-02-09T22:25:17.977Z DEBUG modem << AZURE_IOT_HUB_EVT_FOTA_START
2021-02-09T22:25:17.987Z DEBUG modem << [00:01:23.868,927] [0m<dbg> azure_iot_hub.device_twin_result_process: FOTA message handled[0m
2021-02-09T22:25:17.988Z DEBUG modem << AZURE_IOT_HUB_EVT_TWIN_RECEIVED
2021-02-09T22:25:18.762Z DEBUG modem << [00:01:24.648,345] [0m<inf> download_client: Downloaded 1800/194658 bytes (0%)[0m
2021-02-09T22:25:19.711Z DEBUG modem << [00:01:25.597,229] [0m<inf> download_client: Downloaded 3600/194658 bytes (1%)[0m
2021-02-09T22:25:19.767Z DEBUG modem << [00:01:25.651,733] [0m<dbg> azure_iot_hub.on_publish: MQTT_EVT_PUBLISH: id = 6, len = 0 [0m
2021-02-09T22:25:19.783Z DEBUG modem << [00:01:25.659,973] [0m<dbg> azure_iot_hub_topic.azure_iot_hub_topic_parse: Dynamic value: 204[0m
2021-02-09T22:25:19.785Z DEBUG modem << [00:01:25.668,670] [0m<dbg> azure_iot_hub_topic.get_next_prop_bag: Key: $rid[0m
2021-02-09T22:25:19.790Z DEBUG modem << [00:01:25.675,872] [0m<dbg> azure_iot_hub_topic.get_next_prop_bag: Value: 83845[0m
2021-02-09T22:25:19.801Z DEBUG modem << [00:01:25.683,349] [0m<dbg> azure_iot_hub_topic.get_next_prop_bag: Key: $version[0m
2021-02-09T22:25:19.807Z DEBUG modem << [00:01:25.690,917] [0m<dbg> azure_iot_hub_topic.get_next_prop_bag: Value: 19[0m
2021-02-09T22:25:19.812Z DEBUG modem << [00:01:25.698,150] [0m<dbg> azure_iot_hub.on_publish: Device twin data received[0m
2021-02-09T22:25:19.824Z DEBUG modem << AZURE_IOT_HUB_EVT_TWIN_RESULT_SUCCESS, ID: 83845
2021-02-09T22:25:20.512Z DEBUG modem << [00:01:26.397,583] [0m<inf> download_client: Downloaded 5400/194658 bytes (2%)[0m
2021-02-09T22:25:21.288Z DEBUG modem << [00:01:27.174,377] [0m<inf> download_client: Downloaded 7200/194658 bytes (3%)[0m
2021-02-09T22:25:22.214Z DEBUG modem << [00:01:28.100,402] [0m<inf> download_client: Downloaded 9000/194658 bytes (4%)[0m
2021-02-09T22:25:23.157Z DEBUG modem << [00:01:29.043,365] [0m<inf> download_client: Downloaded 10800/194658 bytes (5%)[0m
2021-02-09T22:25:23.795Z DEBUG modem << [00:01:29.681,427] [0m<inf> download_client: Downloaded 12600/194658 bytes (6%)[0m
2021-02-09T22:25:24.318Z DEBUG modem << [00:01:30.203,857] [0m<inf> download_client: Downloaded 14400/194658 bytes (7%)[0m
2021-02-09T22:25:25.472Z DEBUG modem << [00:01:31.357,666] [0m<inf> download_client: Downloaded 16200/194658 bytes (8%)[0m
2021-02-09T22:25:26.203Z DEBUG modem << [00:01:32.088,684] [0m<inf> download_client: Downloaded 18000/194658 bytes (9%)[0m
2021-02-09T22:25:27.157Z DEBUG modem << [00:01:33.043,579] [0m<inf> download_client: Downloaded 19800/194658 bytes (10%)[0m
2021-02-09T22:25:27.722Z DEBUG modem << [00:01:33.608,551] [0m<inf> download_client: Downloaded 21600/194658 bytes (11%)[0m
2021-02-09T22:25:28.602Z DEBUG modem << [00:01:34.488,586] [0m<inf> download_client: Downloaded 23400/194658 bytes (12%)[0m
2021-02-09T22:25:29.379Z DEBUG modem << [00:01:35.265,441] [0m<inf> download_client: Downloaded 25200/194658 bytes (12%)[0m
2021-02-09T22:25:30.259Z DEBUG modem << [00:01:36.145,446] [0m<inf> download_client: Downloaded 27000/194658 bytes (13%)[0m
2021-02-09T22:25:30.751Z DEBUG modem << [00:01:36.637,817] [0m<inf> download_client: Downloaded 28800/194658 bytes (14%)[0m
2021-02-09T22:25:31.311Z DEBUG modem << [00:01:37.197,631] [0m<inf> download_client: Downloaded 30600/194658 bytes (15%)[0m
2021-02-09T22:25:32.292Z DEBUG modem << [00:01:38.178,314] [0m<inf> download_client: Downloaded 32400/194658 bytes (16%)[0m
2021-02-09T22:25:33.139Z DEBUG modem << [00:01:39.025,665] [0m<inf> download_client: Downloaded 34200/194658 bytes (17%)[0m
2021-02-09T22:25:34.122Z DEBUG modem << [00:01:40.009,002] [0m<inf> download_client: Downloaded 36000/194658 bytes (18%)[0m
2021-02-09T22:25:34.968Z DEBUG modem << [00:01:40.854,187] [0m<inf> download_client: Downloaded 37800/194658 bytes (19%)[0m
2021-02-09T22:25:35.792Z DEBUG modem << [00:01:41.678,222] [0m<inf> download_client: Downloaded 39600/194658 bytes (20%)[0m
2021-02-09T22:25:36.671Z DEBUG modem << [00:01:42.558,105] [0m<inf> download_client: Downloaded 41400/194658 bytes (21%)[0m
2021-02-09T22:25:37.678Z DEBUG modem << [00:01:43.564,422] [0m<inf> download_client: Downloaded 43200/194658 bytes (22%)[0m
2021-02-09T22:25:38.648Z DEBUG modem << [00:01:44.535,125] [0m<inf> download_client: Downloaded 45000/194658 bytes (23%)[0m
2021-02-09T22:25:39.279Z DEBUG modem << [00:01:45.165,649] [0m<inf> download_client: Downloaded 46800/194658 bytes (24%)[0m
2021-02-09T22:25:40.099Z DEBUG modem << [00:01:45.985,992] [0m<inf> download_client: Downloaded 48600/194658 bytes (24%)[0m
2021-02-09T22:25:40.831Z DEBUG modem << [00:01:46.718,231] [0m<inf> download_client: Downloaded 50400/194658 bytes (25%)[0m
2021-02-09T22:25:41.722Z DEBUG modem << [00:01:47.608,917] [0m<inf> download_client: Downloaded 52200/194658 bytes (26%)[0m
2021-02-09T22:25:42.214Z DEBUG modem << [00:01:48.101,104] [0m<inf> download_client: Downloaded 54000/194658 bytes (27%)[0m
2021-02-09T22:25:42.854Z DEBUG modem << [00:01:48.741,149] [0m<inf> download_client: Downloaded 55800/194658 bytes (28%)[0m
2021-02-09T22:25:43.459Z DEBUG modem << [00:01:49.345,825] [0m<inf> download_client: Downloaded 57600/194658 bytes (29%)[0m
2021-02-09T22:25:44.122Z DEBUG modem << [00:01:50.009,033] [0m<inf> download_client: Downloaded 59400/194658 bytes (30%)[0m
2021-02-09T22:25:44.797Z DEBUG modem << [00:01:50.684,234] [0m<inf> download_client: Downloaded 61200/194658 bytes (31%)[0m
2021-02-09T22:25:45.368Z DEBUG modem << [00:01:51.255,035] [0m<inf> download_client: Downloaded 63000/194658 bytes (32%)[0m
2021-02-09T22:25:46.077Z DEBUG modem << [00:01:51.964,599] [0m<inf> download_client: Downloaded 64800/194658 bytes (33%)[0m
2021-02-09T22:25:46.808Z DEBUG modem << [00:01:52.695,098] [0m<inf> download_client: Downloaded 66600/194658 bytes (34%)[0m
2021-02-09T22:25:47.539Z DEBUG modem << [00:01:53.425,933] [0m<inf> download_client: Downloaded 68400/194658 bytes (35%)[0m
2021-02-09T22:25:48.054Z DEBUG modem << [00:01:53.941,284] [0m<inf> download_client: Downloaded 70200/194658 bytes (36%)[0m
2021-02-09T22:25:48.682Z DEBUG modem << [00:01:54.568,908] [0m<inf> download_client: Downloaded 72000/194658 bytes (36%)[0m
2021-02-09T22:25:49.334Z DEBUG modem << [00:01:55.221,313] [0m<inf> download_client: Downloaded 73800/194658 bytes (37%)[0m
2021-02-09T22:25:50.077Z DEBUG modem << [00:01:55.964,691] [0m<inf> download_client: Downloaded 75600/194658 bytes (38%)[0m
2021-02-09T22:25:50.934Z DEBUG modem << [00:01:56.821,166] [0m<inf> download_client: Downloaded 77400/194658 bytes (39%)[0m
2021-02-09T22:25:51.677Z DEBUG modem << [00:01:57.564,422] [0m<inf> download_client: Downloaded 79200/194658 bytes (40%)[0m
2021-02-09T22:25:52.511Z DEBUG modem << [00:01:58.398,376] [0m<inf> download_client: Downloaded 81000/194658 bytes (41%)[0m
2021-02-09T22:25:53.414Z DEBUG modem << [00:01:59.301,269] [0m<inf> download_client: Downloaded 82800/194658 bytes (42%)[0m
2021-02-09T22:25:54.431Z DEBUG modem << [00:02:00.318,572] [0m<inf> download_client: Downloaded 84600/194658 bytes (43%)[0m
2021-02-09T22:25:55.365Z DEBUG modem << [00:02:01.253,204] [0m<inf> download_client: Downloaded 86400/194658 bytes (44%)[0m
2021-02-09T22:25:56.271Z DEBUG modem << [00:02:02.158,508] [0m<inf> download_client: Downloaded 88200/194658 bytes (45%)[0m
2021-02-09T22:25:57.254Z DEBUG modem << [00:02:03.141,387] [0m<inf> download_client: Downloaded 90000/194658 bytes (46%)[0m
2021-02-09T22:25:58.238Z DEBUG modem << [00:02:04.125,823] [0m<inf> download_client: Downloaded 91800/194658 bytes (47%)[0m
2021-02-09T22:25:59.138Z DEBUG modem << [00:02:05.026,214] [0m<inf> download_client: Downloaded 93600/194658 bytes (48%)[0m
2021-02-09T22:25:59.917Z DEBUG modem << [00:02:05.804,870] [0m<inf> download_client: Downloaded 95400/194658 bytes (49%)[0m
2021-02-09T22:26:00.877Z DEBUG modem << [00:02:06.764,770] [0m<inf> download_client: Downloaded 97200/194658 bytes (49%)[0m
2021-02-09T22:26:01.698Z DEBUG modem << [00:02:07.586,456] [0m<inf> download_client: Downloaded 99000/194658 bytes (50%)[0m
2021-02-09T22:26:02.717Z DEBUG modem << [00:02:08.604,827] [0m<inf> download_client: Downloaded 100800/194658 bytes (51%)[0m
2021-02-09T22:26:03.517Z DEBUG modem << [00:02:09.404,876] [0m<inf> download_client: Downloaded 102600/194658 bytes (52%)[0m
2021-02-09T22:26:04.612Z DEBUG modem << [00:02:10.499,450] [0m<inf> download_client: Downloaded 104400/194658 bytes (53%)[0m
2021-02-09T22:26:06.055Z DEBUG modem << [00:02:11.942,382] [0m<inf> download_client: Downloaded 106200/194658 bytes (54%)[0m
2021-02-09T22:26:06.979Z DEBUG modem << [00:02:12.866,455] [0m<inf> download_client: Downloaded 108000/194658 bytes (55%)[0m
2021-02-09T22:26:07.698Z DEBUG modem << [00:02:13.586,486] [0m<inf> download_client: Downloaded 109800/194658 bytes (56%)[0m
2021-02-09T22:26:08.373Z DEBUG modem << [00:02:14.261,657] [0m<inf> download_client: Downloaded 111600/194658 bytes (57%)[0m
2021-02-09T22:26:09.047Z DEBUG modem << [00:02:14.935,668] [0m<inf> download_client: Downloaded 113400/194658 bytes (58%)[0m
2021-02-09T22:26:09.778Z DEBUG modem << [00:02:15.666,534] [0m<inf> download_client: Downloaded 115200/194658 bytes (59%)[0m
2021-02-09T22:26:10.677Z DEBUG modem << [00:02:16.564,910] [0m<inf> download_client: Downloaded 117000/194658 bytes (60%)[0m
2021-02-09T22:26:11.378Z DEBUG modem << [00:02:17.266,357] [0m<inf> download_client: Downloaded 118800/194658 bytes (61%)[0m
2021-02-09T22:26:12.201Z DEBUG modem << [00:02:18.089,538] [0m<inf> download_client: Downloaded 120600/194658 bytes (61%)[0m
2021-02-09T22:26:13.002Z DEBUG modem << [00:02:18.889,953] [0m<inf> download_client: Downloaded 122400/194658 bytes (62%)[0m
2021-02-09T22:26:13.757Z DEBUG modem << [00:02:19.645,141] [0m<inf> download_client: Downloaded 124200/194658 bytes (63%)[0m
2021-02-09T22:26:14.681Z DEBUG modem << [00:02:20.569,427] [0m<inf> download_client: Downloaded 126000/194658 bytes (64%)[0m
2021-02-09T22:26:15.551Z DEBUG modem << [00:02:21.439,025] [0m<inf> download_client: Downloaded 127800/194658 bytes (65%)[0m
2021-02-09T22:26:16.430Z DEBUG modem << [00:02:22.318,878] [0m<inf> download_client: Downloaded 129600/194658 bytes (66%)[0m
2021-02-09T22:26:17.253Z DEBUG modem << [00:02:23.141,906] [0m<inf> download_client: Downloaded 131400/194658 bytes (67%)[0m
2021-02-09T22:26:18.111Z DEBUG modem << [00:02:23.999,267] [0m<inf> download_client: Downloaded 133200/194658 bytes (68%)[0m
2021-02-09T22:26:18.898Z DEBUG modem << [00:02:24.786,804] [0m<inf> download_client: Downloaded 135000/194658 bytes (69%)[0m
2021-02-09T22:26:19.731Z DEBUG modem << [00:02:25.619,995] [0m<inf> download_client: Downloaded 136800/194658 bytes (70%)[0m
2021-02-09T22:26:20.670Z DEBUG modem << [00:02:26.559,143] [0m<inf> download_client: Downloaded 138600/194658 bytes (71%)[0m
2021-02-09T22:26:21.493Z DEBUG modem << [00:02:27.382,019] [0m<inf> download_client: Downloaded 140400/194658 bytes (72%)[0m
2021-02-09T22:26:22.454Z DEBUG modem << [00:02:28.342,041] [0m<inf> download_client: Downloaded 142200/194658 bytes (73%)[0m
2021-02-09T22:26:23.319Z DEBUG modem << [00:02:29.204,986] [0m<inf> download_client: Downloaded 144000/194658 bytes (73%)[0m
2021-02-09T22:26:24.252Z DEBUG modem << [00:02:30.136,077] [0m<inf> download_client: Downloaded 145800/194658 bytes (74%)[0m
2021-02-09T22:26:25.224Z DEBUG modem << [00:02:31.106,719] [0m<inf> download_client: Downloaded 147600/194658 bytes (75%)[0m
2021-02-09T22:26:26.186Z DEBUG modem << [00:02:32.067,108] [0m<inf> download_client: Downloaded 149400/194658 bytes (76%)[0m
2021-02-09T22:26:27.070Z DEBUG modem << [00:02:32.949,951] [0m<inf> download_client: Downloaded 151200/194658 bytes (77%)[0m
2021-02-09T22:26:27.847Z DEBUG modem << [00:02:33.726,196] [0m<inf> download_client: Downloaded 153000/194658 bytes (78%)[0m
2021-02-09T22:26:28.767Z DEBUG modem << [00:02:34.645,141] [0m<inf> download_client: Downloaded 154800/194658 bytes (79%)[0m
2021-02-09T22:26:29.529Z DEBUG modem << [00:02:35.405,517] [0m<inf> download_client: Downloaded 156600/194658 bytes (80%)[0m
2021-02-09T22:26:30.431Z DEBUG modem << [00:02:36.307,098] [0m<inf> download_client: Downloaded 158400/194658 bytes (81%)[0m
2021-02-09T22:26:31.382Z DEBUG modem << [00:02:37.256,286] [0m<inf> download_client: Downloaded 160200/194658 bytes (82%)[0m
2021-02-09T22:26:32.197Z DEBUG modem << [00:02:38.070,281] [0m<inf> download_client: Downloaded 162000/194658 bytes (83%)[0m
2021-02-09T22:26:33.090Z DEBUG modem << [00:02:38.962,951] [0m<inf> download_client: Downloaded 163800/194658 bytes (84%)[0m
2021-02-09T22:26:34.068Z DEBUG modem << [00:02:39.939,971] [0m<inf> download_client: Downloaded 165600/194658 bytes (85%)[0m
2021-02-09T22:26:35.082Z DEBUG modem << [00:02:40.952,911] [0m<inf> download_client: Downloaded 167400/194658 bytes (85%)[0m
2021-02-09T22:26:35.830Z DEBUG modem << [00:02:41.700,195] [0m<inf> download_client: Downloaded 169200/194658 bytes (86%)[0m
2021-02-09T22:26:36.843Z DEBUG modem << [00:02:42.712,402] [0m<inf> download_client: Downloaded 171000/194658 bytes (87%)[0m
2021-02-09T22:26:37.816Z DEBUG modem << [00:02:43.685,302] [0m<inf> download_client: Downloaded 172800/194658 bytes (88%)[0m
2021-02-09T22:26:38.898Z DEBUG modem << [00:02:44.766,754] [0m<inf> download_client: Downloaded 174600/194658 bytes (89%)[0m
2021-02-09T22:26:39.788Z DEBUG modem << [00:02:45.655,670] [0m<inf> download_client: Downloaded 176400/194658 bytes (90%)[0m
2021-02-09T22:26:40.499Z DEBUG modem << [00:02:46.366,546] [0m<inf> download_client: Downloaded 178200/194658 bytes (91%)[0m
2021-02-09T22:26:41.573Z DEBUG modem << [00:02:47.439,575] [0m<inf> download_client: Downloaded 180000/194658 bytes (92%)[0m
2021-02-09T22:26:42.384Z DEBUG modem << [00:02:48.250,579] [0m<inf> download_client: Downloaded 181800/194658 bytes (93%)[0m
2021-02-09T22:26:43.300Z DEBUG modem << [00:02:49.165,618] [0m<inf> download_client: Downloaded 183600/194658 bytes (94%)[0m
2021-02-09T22:26:44.031Z DEBUG modem << [00:02:49.896,636] [0m<inf> download_client: Downloaded 185400/194658 bytes (95%)[0m
2021-02-09T22:26:45.002Z DEBUG modem << [00:02:50.867,462] [0m<inf> download_client: Downloaded 187200/194658 bytes (96%)[0m
2021-02-09T22:26:45.819Z DEBUG modem << [00:02:51.683,471] [0m<inf> download_client: Downloaded 189000/194658 bytes (97%)[0m
2021-02-09T22:26:46.798Z DEBUG modem << [00:02:52.662,872] [0m<inf> download_client: Downloaded 190800/194658 bytes (98%)[0m
2021-02-09T22:26:47.587Z DEBUG modem << [00:02:53.450,775] [0m<inf> download_client: Downloaded 192600/194658 bytes (98%)[0m
2021-02-09T22:26:48.559Z DEBUG modem << [00:02:54.422,790] [0m<inf> download_client: Downloaded 194400/194658 bytes (99%)[0m
2021-02-09T22:26:49.276Z DEBUG modem << [00:02:55.139,160] [0m<inf> download_client: Downloaded 194658/194658 bytes (100%)[0m
2021-02-09T22:26:49.287Z DEBUG modem << [00:02:55.152,465] [0m<inf> download_client: Download complete[0m
2021-02-09T22:26:49.385Z DEBUG modem << [00:02:55.246,398] [0m<inf> dfu_target_mcuboot: MCUBoot image upgrade scheduled. Reset device to apply[0m
2021-02-09T22:26:49.396Z DEBUG modem << [00:02:55.257,812] [0m<dbg> azure_fota.fota_dl_handler: FOTA download completed evt received[0m
2021-02-09T22:26:49.413Z DEBUG modem << [00:02:55.266,479] [0m<dbg> azure_fota.create_report: Created FOTA report: {“firmware”:{“fwUpdateStatus”:“applying”,“currentFwVersion”:“v0.1.2”,“pendingFwVersion”:“v0.1.3”}}[0m
2021-02-09T22:26:49.418Z DEBUG modem << [00:02:55.282,104] [0m<dbg> azure_iot_hub.fota_evt_handler: AZURE_FOTA_EVT_DONE[0m
2021-02-09T22:26:49.431Z DEBUG modem << [00:02:55.289,642] [0m<dbg> azure_iot_hub.azure_iot_hub_send: Publishing to topic: $iothub/twin/PATCH/properties/reported/?$rid=175289[0m
2021-02-09T22:26:49.445Z DEBUG modem << [00:02:55.303,680] [0m<dbg> azure_iot_hub.fota_report_send: FOTA report sent[0m
2021-02-09T22:26:49.446Z DEBUG modem << AZURE_IOT_HUB_EVT_FOTA_DONE
2021-02-09T22:26:49.447Z DEBUG modem << The device will reboot in 5 seconds to apply update
2021-02-09T22:26:50.204Z DEBUG modem << [00:02:56.065,399] [0m<dbg> azure_iot_hub.on_publish: MQTT_EVT_PUBLISH: id = 6, len = 0 [0m
2021-02-09T22:26:50.215Z DEBUG modem << [00:02:56.073,638] [0m<dbg> azure_iot_hub_topic.azure_iot_hub_topic_parse: Dynamic value: 204[0m
2021-02-09T22:26:50.229Z DEBUG modem << [00:02:56.082,305] [0m<dbg> azure_iot_hub_topic.get_next_prop_bag: Key: $rid[0m
2021-02-09T22:26:50.230Z DEBUG modem << [00:02:56.089,538] [0m<dbg> azure_iot_hub_topic.get_next_prop_bag: Value: 175289[0m
2021-02-09T22:26:50.246Z DEBUG modem << [00:02:56.097,106] [0m<dbg> azure_iot_hub_topic.get_next_prop_bag: Key: $version[0m
2021-02-09T22:26:50.248Z DEBUG modem << [00:02:56.104,675] [0m<dbg> azure_iot_hub_topic.get_next_prop_bag: Value: 20[0m
2021-02-09T22:26:50.249Z DEBUG modem << [00:02:56.111,907] [0m<dbg> azure_iot_hub.on_publish: Device twin data received[0m
2021-02-09T22:26:50.253Z DEBUG modem << AZURE_IOT_HUB_EVT_TWIN_RESULT_SUCCESS, ID: 175289
2021-02-09T22:26:54.397Z DEBUG modem << RRC mode: Idle
2021-02-09T22:26:54.749Z DEBUG modem << *** Booting Zephyr OS version 2.4.99 ***
2021-02-09T22:26:54.759Z DEBUG modem << Flash regionsDomainPermissions
2021-02-09T22:26:54.760Z DEBUG modem << 00 02 0×00000 0×18000 Securerwxl
2021-02-09T22:26:54.761Z DEBUG modem << 03 31 0×18000 0×100000 Non-Securerwxl
2021-02-09T22:26:54.766Z DEBUG modem << Non-secure callable region 0 placed in flash region 2 with size 32.
2021-02-09T22:26:54.938Z DEBUG modem << SRAM regionDomainPermissions
2021-02-09T22:26:54.950Z DEBUG modem << 00 07 0×00000 0×10000 Securerwxl
2021-02-09T22:26:54.951Z DEBUG modem << 08 31 0×10000 0×40000 Non-Securerwxl
2021-02-09T22:26:54.952Z DEBUG modem << PeripheralDomainStatus
2021-02-09T22:26:54.953Z DEBUG modem << 00 NRF_P0 Non-SecureOK
2021-02-09T22:26:54.954Z DEBUG modem << 01 NRF_CLOCK Non-SecureOK
2021-02-09T22:26:54.969Z DEBUG modem << 02 NRF_RTC0 Non-SecureOK
2021-02-09T22:26:54.970Z DEBUG modem << 03 NRF_RTC1 Non-SecureOK
2021-02-09T22:26:54.971Z DEBUG modem << 04 NRF_NVMC Non-SecureOK
2021-02-09T22:26:54.972Z DEBUG modem << 05 NRF_UARTE1 Non-SecureOK
2021-02-09T22:26:54.973Z DEBUG modem << 06 NRF_UARTE2 SecureSKIP
2021-02-09T22:26:54.985Z DEBUG modem << 07 NRF_TWIM2 Non-SecureOK
2021-02-09T22:26:54.986Z DEBUG modem << 08 NRF_SPIM3 Non-SecureOK
2021-02-09T22:26:54.987Z DEBUG modem << 09 NRF_TIMER0 Non-SecureOK
2021-02-09T22:26:54.988Z DEBUG modem << 10 NRF_TIMER1 Non-SecureOK
2021-02-09T22:26:54.989Z DEBUG modem << 11 NRF_TIMER2 Non-SecureOK
2021-02-09T22:26:55.003Z DEBUG modem << 12 NRF_SAADC Non-SecureOK
2021-02-09T22:26:55.004Z DEBUG modem << 13 NRF_PWM0 Non-SecureOK
2021-02-09T22:26:55.005Z DEBUG modem << 14 NRF_PWM1 Non-SecureOK
2021-02-09T22:26:55.005Z DEBUG modem << 15 NRF_PWM2 Non-SecureOK
2021-02-09T22:26:55.006Z DEBUG modem << 16 NRF_PWM3 Non-SecureOK
2021-02-09T22:26:55.019Z DEBUG modem << 17 NRF_WDT Non-SecureOK
2021-02-09T22:26:55.020Z DEBUG modem << 18 NRF_IPC Non-SecureOK
2021-02-09T22:26:55.021Z DEBUG modem << 19 NRF_VMC Non-SecureOK
2021-02-09T22:26:55.021Z DEBUG modem << 20 NRF_FPU Non-SecureOK
2021-02-09T22:26:55.022Z DEBUG modem << 21 NRF_EGU1 Non-SecureOK
2021-02-09T22:26:55.036Z DEBUG modem << 22 NRF_EGU2 Non-SecureOK
2021-02-09T22:26:55.037Z DEBUG modem << 23 NRF_DPPIC Non-SecureOK
2021-02-09T22:26:55.038Z DEBUG modem << 24 NRF_GPIOTE1 Non-SecureOK
2021-02-09T22:26:55.039Z DEBUG modem << 25 NRF_REGULATORS Non-SecureOK
2021-02-09T22:26:55.040Z DEBUG modem << SPM: NS image at 0×1c200
2021-02-09T22:26:55.040Z DEBUG modem << SPM: NS MSP at 0×20028c30
2021-02-09T22:26:55.053Z DEBUG modem << SPM: NS reset vector at 0×22439
2021-02-09T22:26:55.054Z DEBUG modem << SPM: prepare to jump to Non-Secure image.
2021-02-09T22:26:55.254Z DEBUG modem << *** Booting Zephyr OS version 2.4.99 ***
2021-02-09T22:26:55.265Z DEBUG modem << Azure FOTA v0.1.2 started
2021-02-09T22:26:55.266Z DEBUG modem << Initializing modem library
2021-02-09T22:26:55.268Z DEBUG modem << This may take a while if a modem firmware update is pending
2021-02-09T22:26:55.269Z DEBUG modem << Modem library initialized
2021-02-09T22:26:55.286Z DEBUG modem << [00:00:00.224,090] [0m<inf> azure_iot_hub_dps: Setting DPS registration ID: mycordevice261[0m
2021-02-09T22:26:55.302Z DEBUG modem << [00:00:00.232,452] [0m<dbg> azure_iot_hub_dps.dps_reg_id_set: Saved DPS registration ID: mycordevice261[0m
2021-02-09T22:26:55.306Z DEBUG modem << [00:00:00.243,041] [0m<dbg> azure_iot_hub_dps.dps_settings_handler: Azure IoT Hub hostname found, DPS not needed: lab651hub.azure-devices.net[0m
