otherguy A visual inspection of the AQW shows nothing out of the ordinary, apart from the resistor R1 being absent. Is that correct? According to your schematics, there should be a 100k resistor.
That part should not matter.
otherguy I noticed that the SI7021 also isn’t soldered on straight. At this point I’m assuming the AQW is defective.
I’ve personally built and tested all AQWs that have left here. I doubt very much, as long as you stored it correctly, that it would be defective after a year.
One thing I will add is I only support the original code that shipped with it. A few requests to debug this further:
  • If you’d like to load the original code up and show the output that would be useful.
  • Also please send pictures of the top & bottom of the AQW. There should be a small cut in a trace going to the CCS811 on the bottom side. This could affect the CCS811 I2C operations but it shouldn’t affect the Si7021.
  • Do you have/are you using an HPMA115?
    jaredwolff thank you for the support
    jaredwolff I’ve personally built and tested all AQWs that have left here. I doubt very much, as long as you stored it correctly, that it would be defective after a year.
    I understand! It arrived last year but I didn’t make it back home until recently due to COVID, so it was just sitting on the counter in the box it was shipped in.
    That makes perfect sense. I only switched to Circuitpython because I had some troubles with the Particle cloud.
    This is the output from the Argon. I loaded the code up on a Xenon and it’s identical:
    Serial monitor opened successfully:
    0000020541 [app] WARN: Error tvoc - no data
    0000030541 [app] ERROR: hpma timeout
    0000030541 [app] ERROR: Error hpma115
    0000030542 [app] ERROR: Error sgp30
    0000040541 [app] WARN: Error tvoc - no data
    0000050541 [app] ERROR: hpma timeout
    0000050541 [app] ERROR: Error hpma115
    0000050542 [app] ERROR: Error sgp30
    0000060541 [app] WARN: Error tvoc - no data
    Yes, the HPMA115 is plugged in.
    Incidentally, shouldn’t the CCS811 have a plastic cover/case?
      otherguy looks like this board was damaged. Unfortunately I’m not sure if anything can be doe here. I’m not sure why the HPMA is not working though. You can isolate/remove the CSS811 by modifying this guy:
        AirQualityWingSettings_t defaultSettings =
                MEASUREMENT_DELAY_MS, //Measurement Interval
                true,                 //Has HPMA115
                false,                 //Has CCS811
                false,                 //Has Si7021
                false,                //Has SGP30
                CCS811_ADDRESS,       //CCS811 address
                CCS811_INT_PIN,       //CCS811 intpin
                CCS811_RST_PIN,       //CCS811 rst pin
                CCS811_WAKE_PIN,      //CCS811 wake pin
                HPMA1150_EN_PIN       //HPMA int pin
      Did you get the HPMA from me or elsewhere? The connector has a very specific pinout and the HPMA will not work if it’s not correct.
      I got the HPMA from Honeywell directly (well, Digikey). It’s working with a breakout board if I connect it directly to the Argon via a breadboard (with custom code)
      I tried the code with just the Si7021 enabled and with just the HPMA115 enabled, but the result is the same (minus the error messages for these devices of course).
      I understand that you cannot debug any other code but I don’t think it’s a software issue. Remember the long list of I2C devices that Circuitpython sees when the AQW is plugged in? So it turns out I can communicate with I2C devices when it’s just the Argon on a breadboard, but as soon as the Argon is plugged into the AQW, communication with any I2C device fails – not just the 2 on the AQW board, but also external I2C devices. It seems there is a short or a wrong connection somewhere. Possibly it’s related to the damaged CCS811?
      I got the board from GroupGets (ORDER #GG-4596) on November 25th 2020 (so less than a year actually). I’m in Europe and just getting another AQW board is prohibitively expensive (I paid $60 with shipping and another $40 in import tax and customs fees).
      Anything I can measure to isolate what is damaged?
      Just to be 100% certain I tried it with a second Argon and another Xenon:
      Air Quality Wing for Particle & Feather
      0000035248 [app] WARN: Error tvoc - no data
      0000045247 [app] ERROR: hpma timeout
      0000045248 [app] ERROR: Error hpma115
      0000045249 [app] ERROR: Error sgp30
      0000055246 [app] WARN: Error tvoc - no data
        otherguy one thing I noticed from your pictures is that the trace to the reset pin of the CCS811 is not cut like should be. (It’s hard to tell in that lighting) If you cut it where I recommend below that also may help. Ultimately, since the package of the CCS811 is completely gone, it’s hard to guarantee things are working properly.
        As for the HPMA you’ll have to change your cable to match the intended pinout. That means popping out the wire connections and likely reversing them.
        Here’s a picture of what the cable looks like with only the needed connections. It’s fairly easy to remove the unused ones using a needle or a very small flat head screwdriver.
        (Originally from here)
        Ultimately the CCS811 likely needs to be removed all together. If you’re feeling adventurous you could always remove it with a hot air gun aimed from the bottom of your board. That process is not for the faint of heart though!
        Also if you have the ability to capture the I2C signals on a scope that would be interesting. My guess is that it’s all mucked up from the damaged CCS811.
        Give me some time. I’m traveling at the moment but I will try to do all that on the weekend. My scope is quite basic but it’s good enough for I2C traffic.
        I do want to stress that this is the exact condition the board arrived in! The CCS811 never had its original casing. I only noticed that it should have one when I looked at the datasheet and photos of other CCS811.
          7 days later
          jaredwolff alright, I just got around to looking at this.
          The trace was indeed not cut but there was a thin scratch between the D2 and D3 pads. I cut the trace right at this point. Your pictures of the HPMA115 wiring were also very helpful because I noticed my wiring was flipped. Oops. I corrected that.
          This got me a little farther. The HPMA now turns on but the values reported (changed log level to INFO) are completely off:
          0000140421 [app] INFO: {"pm25":1000,"pm10":1013,"temperature":128.87,"humidity":119.00}
          Digging a little deeper and adding some debug statements, I noticed that all the values read from the HPMA and the Si7021 seem to be messed up (I’m not measuring next to that volcano in Iceland):
          temp_code: 65535
          rh_code: 65535
          hum: 119.00% temp: 128.87°C
          0000059013 [app] WARN: Error tvoc - no data
          data+checksum: fc fc
          data+checksum: 2df 2df
          rx_buf: 2003e4f0
          0000063039 [app] INFO: {"pm25":1000,"pm10":1013,"temperature":128.87,"humidity":119.00}
          Next, I will try to remove the CCS811 altogether. Merely disabling it in the code doesn’t change anything.
            otherguy I would disable the Si7021 and CCS811 if you can. The HPMA is on UART which shouldn’t be affected by any of the I2C issues. Start there and go backwards. 😀
              jaredwolff I did that actually before posting but it didn’t change anything.
              rx_buf: 2003e4f0
              0000045035 [app] INFO: {"pm25":1000,"pm10":1013}
              It’s encouraging that at least the fan is spinning and data is being read.
              So, just my luck, but the HPMA was brand new but defective. I RMA’d it with Honeywell.
              However, I had a PMS5003 lying around which is very similar in design but has a slightly different pinout. Other than that, it also communicates over UART and needs 5V input for the fan. I changed the wiring to match the PMS5003, didn’t touch the code, and it works. The values match the ones reported by a Temtop M2000 station as well as the ones by the local AQI measurement station.
              rx_buf: 66 77 0 28 0 7 0 9 0 9 0 7 0 9 0 9 0 0 0 0 0 0 0 0 0 0 0 0 151 8 1
              0000082554 [app] INFO: {"pm25":9,"pm10":9}
              rx_buf: 66 77 0 28 0 109 0 219 0 250 0 72 0 145 0 166 0 0 0 0 0 0 0 0 0 0 0 0 151 8 5
              0000102570 [app] INFO: {"pm25":219,"pm10":250}
              The second measurement is from directly next to my soldering station. Eww.
              One down.
              Next was the CCS811 which came off easily with the hot air soldering gun. I have a spare CCS811 here which I could desolder from its breakout board, but first I want to make sure the rest of the board is working.
              The Si7021 is consistently reporting relative humidity of 119.00% and a temperature of 128.87°C. Which seemed odd until I looked at the code that is used for reading the data. The raw values reported by the sensor are just 65535 (0xFFFF) for both temperature and humidity.
              And that was also the case for CCS811 before.
              So I hooked up my crappy Aliexpress scope and while I’m no electrical engineer and I’m not great at reading the output, it looks to me as if SDA is just permanently stuck on HIGH.
              So there is definitely more broken on that board than just the CCS811.
              I would recommend if you do remove it, the CCS811 is very fragile when heated. Best to warm it from the bottom if possible.
              Hmm interesting. Without anything connected, can you measure the pull up resistors? If they’re shorted to 3.3V that would explain the issues a bit more. (Though would be a problem if they were 0 ohms!)
                Thanks! I will try that once I have the Si7021 working.
                Without anything connected, I measure 20kΩ between both SDA/3.3V and SCL/3.3V. I measure 40kΩ between SDA and SCL (which makes sense).
                To test the I2C bus, with nothing connected to the AQW and the CCS811 desoldered, I ran the following program:
                #include <Wire.h> //include Wire.h library
                void setup()
                  Wire.begin(); // Wire communication begin
                  Serial.begin(9600); // The baudrate of Serial monitor is set in 9600
                  while (!Serial); // Waiting for Serial Monitor
                  Serial.println("\nI2C Scanner");
                void loop()
                  byte error, address; //variable for error and I2C address
                  int nDevices;
                  Serial.println("Scanning...");
                  nDevices = 0;
                  for (address = 1; address < 127; address++ )
                    // The i2c_scanner uses the return value of
                    // the Write.endTransmisstion to see if
                    // a device did acknowledge to the address.
                    Wire.beginTransmission(address);
                    error = Wire.endTransmission();
                    if (error == 0)
                      Serial.print("I2C device found at address 0x");
                      if (address < 16)
                        Serial.print("0");
                      Serial.print(address, HEX);
                      Serial.println("  !");
                      nDevices++;
                    else if (error == 4)
                      Serial.print("Unknown error at address 0x");
                      if (address < 16)
                        Serial.print("0");
                      Serial.println(address, HEX);
                  if (nDevices == 0)
                    Serial.println("No I2C devices found\n");
                  else
                    Serial.println("done\n");
                  delay(5000); // wait 5 seconds for the next I2C scan
                And the output is:
                I2C Scanner
                Scanning...
                I2C device found at address 0x01  !
                I2C device found at address 0x02  !
                I2C device found at address 0x03  !
                I2C device found at address 0x04  !
                I2C device found at address 0x05  !
                I2C device found at address 0x06  !
                I2C device found at address 0x08  !
                I2C device found at address 0x09  !
                I2C device found at address 0x0A  !
                I2C device found at address 0x0B  !
                I2C device found at address 0x0C  !
                I2C device found at address 0x0D  !
                I2C device found at address 0x0E  !
                I2C device found at address 0x10  !
                I2C device found at address 0x11  !
                I2C device found at address 0x12  !
                I2C device found at address 0x13  !
                I2C device found at address 0x14  !
                I2C device found at address 0x15  !
                I2C device found at address 0x16  !
                I2C device found at address 0x24  !
                I2C device found at address 0x25  !
                I2C device found at address 0x26  !
                I2C device found at address 0x28  !
                I2C device found at address 0x29  !
                I2C device found at address 0x2A  !
                I2C device found at address 0x39  !
                I2C device found at address 0x3A  !
                I2C device found at address 0x49  !
                I2C device found at address 0x4A  !
                I2C device found at address 0x59  !
                I2C device found at address 0x5A  !
                I2C device found at address 0x68  !
                I2C device found at address 0x69  !
                I2C device found at address 0x6A  !
                I2C device found at address 0x6C  !
                I2C device found at address 0x7A  !
                I2C device found at address 0x7C  !
                done
                This is the same issue I saw on CircuitPython with a huge list of I2C addresses.
                Hmm definitely not expected behavior!
                jaredwolff it looks to me as if SDA is just permanently stuck on HIGH.
                Back to this, the SCL line is toggling though? If you put the particle board on a breadboard, do both (SDA & SCL pins) toggle?
                What version of Device OS are you using?
                  I recall seeing that, yes (edit: though now I’m questioning myself after you asked).
                  Yes. I am now testing this with 3 different Argons and 2 different Xenons. I also dug out a breakout board for the HPMA and another I2C temp/humidity sensor (though not an Si7021) and together with the CCS811 breakout board I mentioned above I recreated the AQW on a breadboard. This works, including the code for listing I2C devices from above.
                  There is definitely something wrong with the AQW board.
                  On a sidenote, I use 2.2k or 4.7k resistors as pullups for the I2C lines, usually. Isn’t 20k a little high, especially if someone were to power the Argon off a battery?
                  9 days later
                  Hey Jared,
                  i had some time over the weekend so I checked again. Neither SCL nor SDA are triggering when the Argon is plugged into the AQW. Is it possible that the Si7021 is also defective and is causing this?
                  23 days later
                  Hi again Jared. I’m at my wits’ end here.
                  Would you be able to replace the AQW?
