jojo looks like a different error this time. You’re getting some type of file system error. Can you explain how you cloned NFED? It’s hard to tell from your build output.
blinky sample question
For nfed, I believe that I just followed the documentation. For the second error, It was my bad because I didn’t remove the build folder in the blinky sample folder.
But even after removing the build folder, I still get recurring codes. I went through the documentation but I couldn’t find the point I missed.
$ cd nfed/samples/blinky/
$ west build -b circuitdojo_feather_nrf9160ns -p
-- Adding .overlay for mcuboot.
Including boilerplate (Zephyr base): C:/Users/jeil_oh/ncs/v1.5.0/zephyr/cmake/app/boilerplate.cmake
-- Application: C:/Users/jeil_oh/ncs/v1.5.0/nfed/samples/blinky
-- Using NCS Toolchain 1.5.0 for building. (C:/Users/jeil_oh/ncs/v1.5.0/toolchain/cmake)
-- Zephyr version: 2.4.99 (C:/Users/jeil_oh/ncs/v1.5.0/zephyr)
-- Found Python3: C:/Users/jeil_oh/ncs/v1.5.0/toolchain/opt/bin/python.exe (found suitable exact version "3.8.2") found components: Interpreter
-- Found west (found suitable version "0.9.0", minimum required is "0.7.1")
-- Board: circuitdojo_feather_nrf9160ns
-- Cache files will be written to: C:/Users/jeil_oh/ncs/v1.5.0/zephyr/.cache
-- Found dtc: C:/Users/jeil_oh/ncs/v1.5.0/toolchain/opt/bin/dtc.exe (found suitable version "1.4.7", minimum required is "1.4.6")
-- Found toolchain: gnuarmemb (C:/Users/jeil_oh/ncs/v1.5.0/toolchain/opt)
-- Found BOARD.dts: C:/Users/jeil_oh/ncs/v1.5.0/zephyr/boards/arm/circuitdojo_feather_nrf9160/circuitdojo_feather_nrf9160ns.dts
-- Generated zephyr.dts: C:/Users/jeil_oh/ncs/v1.5.0/nfed/samples/blinky/build/zephyr/zephyr.dts
-- Generated devicetree_unfixed.h: C:/Users/jeil_oh/ncs/v1.5.0/nfed/samples/blinky/build/zephyr/include/generated/devicetree_unfixed.h
-- Generated device_extern.h: C:/Users/jeil_oh/ncs/v1.5.0/nfed/samples/blinky/build/zephyr/include/generated/device_extern.h
Parsing C:/Users/jeil_oh/ncs/v1.5.0/zephyr/Kconfig
Loaded configuration 'C:/Users/jeil_oh/ncs/v1.5.0/zephyr/boards/arm/circuitdojo_feather_nrf9160/circuitdojo_feather_nrf9160ns_defconfig'
Merged configuration 'C:/Users/jeil_oh/ncs/v1.5.0/nfed/samples/blinky/prj.conf'
Configuration saved to 'C:/Users/jeil_oh/ncs/v1.5.0/nfed/samples/blinky/build/zephyr/.config'
Kconfig header saved to 'C:/Users/jeil_oh/ncs/v1.5.0/nfed/samples/blinky/build/zephyr/include/generated/autoconf.h'
-- The C compiler identification is GNU 9.2.1
-- The CXX compiler identification is GNU 9.2.1
-- Found assembler: C:/Users/jeil_oh/ncs/v1.5.0/toolchain/opt/bin/arm-none-eabi-gcc.exe
=== child image spm - begin ===
-- Application: C:/Users/jeil_oh/ncs/v1.5.0/nrf/samples/spm
-- Found BOARD.dts: C:/Users/jeil_oh/ncs/v1.5.0/zephyr/boards/arm/circuitdojo_feather_nrf9160/circuitdojo_feather_nrf9160.dts
-- Generated zephyr.dts: C:/Users/jeil_oh/ncs/v1.5.0/nfed/samples/blinky/build/spm/zephyr/zephyr.dts
-- Generated devicetree_unfixed.h: C:/Users/jeil_oh/ncs/v1.5.0/nfed/samples/blinky/build/spm/zephyr/include/generated/devicetree_unfixed.h
-- Generated device_extern.h: C:/Users/jeil_oh/ncs/v1.5.0/nfed/samples/blinky/build/spm/zephyr/include/generated/device_extern.h
Loaded configuration 'C:/Users/jeil_oh/ncs/v1.5.0/zephyr/boards/arm/circuitdojo_feather_nrf9160/circuitdojo_feather_nrf9160_defconfig'
Merged configuration 'C:/Users/jeil_oh/ncs/v1.5.0/nrf/samples/spm/prj.conf'
Merged configuration 'C:/Users/jeil_oh/ncs/v1.5.0/nrf/subsys/partition_manager/partition_manager_enabled.conf'
Merged configuration 'C:/Users/jeil_oh/ncs/v1.5.0/nfed/samples/blinky/build/spm/zephyr/misc/generated/extra_kconfig_options.conf'
Configuration saved to 'C:/Users/jeil_oh/ncs/v1.5.0/nfed/samples/blinky/build/spm/zephyr/.config'
Kconfig header saved to 'C:/Users/jeil_oh/ncs/v1.5.0/nfed/samples/blinky/build/spm/zephyr/include/generated/autoconf.h'
-- Configuring done
-- Generating done
-- Build files have been written to: C:/Users/jeil_oh/ncs/v1.5.0/nfed/samples/blinky/build/spm
=== child image spm - end ===
=== child image mcuboot - begin ===
-- Application: C:/Users/jeil_oh/ncs/v1.5.0/bootloader/mcuboot/boot/zephyr
-- Found devicetree overlay: C:/Users/jeil_oh/ncs/v1.5.0/nfed/samples/blinky/../../shared/conf/mcuboot/circuitdojo_feather_nrf9160ns.overlay
-- Found devicetree overlay: C:/Users/jeil_oh/ncs/v1.5.0/bootloader/mcuboot/boot/zephyr/dts.overlay
-- Generated zephyr.dts: C:/Users/jeil_oh/ncs/v1.5.0/nfed/samples/blinky/build/mcuboot/zephyr/zephyr.dts
-- Generated devicetree_unfixed.h: C:/Users/jeil_oh/ncs/v1.5.0/nfed/samples/blinky/build/mcuboot/zephyr/include/generated/devicetree_unfixed.h
-- Generated device_extern.h: C:/Users/jeil_oh/ncs/v1.5.0/nfed/samples/blinky/build/mcuboot/zephyr/include/generated/device_extern.h
Parsing C:/Users/jeil_oh/ncs/v1.5.0/bootloader/mcuboot/boot/zephyr/Kconfig
Merged configuration 'C:/Users/jeil_oh/ncs/v1.5.0/bootloader/mcuboot/boot/zephyr/prj.conf'
Merged configuration 'C:/Users/jeil_oh/ncs/v1.5.0/bootloader/mcuboot/boot/zephyr/boards/circuitdojo_feather_nrf9160.conf'
Configuration saved to 'C:/Users/jeil_oh/ncs/v1.5.0/nfed/samples/blinky/build/mcuboot/zephyr/.config'
Kconfig header saved to 'C:/Users/jeil_oh/ncs/v1.5.0/nfed/samples/blinky/build/mcuboot/zephyr/include/generated/autoconf.h'
MCUBoot bootloader key file: C:/Users/jeil_oh/ncs/v1.5.0/bootloader/mcuboot/root-ec-p256.pem
-- Configuring done
-- Generating done
-- Build files have been written to: C:/Users/jeil_oh/ncs/v1.5.0/nfed/samples/blinky/build/mcuboot
=== child image mcuboot - end ===
CMake Warning at C:/Users/jeil_oh/ncs/v1.5.0/nrf/modules/mcuboot/CMakeLists.txt:151 (message):
--- be used for production. ---
-- Configuring done
-- Generating done
[1/165] Creating directories for 'spm_subimage'
[2/165] Creating directories for 'mcuboot_subimage'
[3/165] No download step for 'spm_subimage'
[4/165] No download step for 'mcuboot_subimage'
[5/165] No update step for 'spm_subimage'
[6/165] No patch step for 'spm_subimage'
[7/165] No patch step for 'mcuboot_subimage'
[8/165] No update step for 'mcuboot_subimage'
[9/165] No configure step for 'spm_subimage'
[9/165] Performing build step for 'spm_subimage'
[1/200] Building C object modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedtls_external.dir/C_/Users/jeil_oh/ncs/v1.5.0/zephyr/misc/empty_file.c.obj
[2/200] Building C object modules/nrfxlib/nrf_security/src/mbedtls/cc310/CMakeFiles/mbedcrypto_cc3xx_noglue.dir/C_/Users/jeil_oh/ncs/v1.5.0/zephyr/misc/empty_file.c.obj
[3/200] Building C object modules/nrfxlib/nrf_security/src/mbedtls/shared/CMakeFiles/mbedcrypto_shared.dir/C_/Users/jeil_oh/ncs/v1.5.0/zephyr/misc/empty_file.c.obj
[4/200] Linking C static library modules\nrfxlib\nrf_security\src\mbedtls\libmbedtls_external.a
[5/200] Linking C static library modules\nrfxlib\nrf_security\src\mbedtls\cc310\libmbedcrypto_cc3xx_noglue.a
[6/200] Building C object modules/nrfxlib/nrf_security/src/mbedtls/shared/CMakeFiles/mbedcrypto_shared.dir/C_/Users/jeil_oh/ncs/v1.5.0/mbedtls/library/sha512.c.obj
[7/200] Linking C static library modules\nrfxlib\nrf_security\src\mbedtls\shared\libmbedcrypto_shared.a
[8/200] Generating libmbedcrypto_cc3xx.a
[9/200] Generating misc/generated/syscalls.json, misc/generated/struct_tags.json
[10/200] Generating include/generated/kobj-types-enum.h, include/generated/otype-to-str.h
[11/200] Generating include/generated/driver-validation.h
[12/200] Generating include/generated/syscall_dispatch.c, include/generated/syscall_list.h
[13/200] Building C object zephyr/CMakeFiles/offsets.dir/arch/arm/core/offsets/offsets.c.obj
[14/200] Generating include/generated/offsets.h
[15/200] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/cpu_idle.S.obj
[16/200] Building C object zephyr/arch/common/CMakeFiles/isr_tables.dir/isr_tables.c.obj
[17/200] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/nmi_on_reset.S.obj
[18/200] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/swap_helper.S.obj
[19/200] Building C object zephyr/arch/common/CMakeFiles/arch__common.dir/sw_isr_common.c.obj
[20/200] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/swap.c.obj
[21/200] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/irq_manage.c.obj
[22/200] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/thread.c.obj
[23/200] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/nmi.c.obj
[24/200] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/fatal.c.obj
[25/200] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/isr_wrapper.S.obj
[26/200] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/reset.S.obj
[27/200] Linking C static library zephyr\arch\common\libisr_tables.a
[28/200] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/fault_s.S.obj
[29/200] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/prep_c.c.obj
[30/200] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/exc_exit.S.obj
[31/200] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/vector_table.S.obj
[32/200] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/tz/CMakeFiles/arch__arm__core__aarch32__cortex_m__tz.dir/arm_core_tz.c.obj
[33/200] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/irq_init.c.obj
[34/200] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/scb.c.obj
[35/200] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/fault.c.obj
[36/200] Linking C static library zephyr\arch\common\libarch__common.a
[37/200] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/thread_abort.c.obj
[38/200] Linking C static library zephyr\arch\arch\arm\core\aarch32\cortex_m\tz\libarch__arm__core__aarch32__cortex_m__tz.a
[39/200] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/mpu/CMakeFiles/arch__arm__core__aarch32__cortex_m__mpu.dir/arm_core_mpu.c.obj
[40/200] Linking C static library zephyr\arch\arch\arm\core\aarch32\libarch__arm__core__aarch32.a
[41/200] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/cmse/CMakeFiles/arch__arm__core__aarch32__cortex_m__cmse.dir/arm_core_cmse.c.obj
[42/200] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdout/fprintf.c.obj
[43/200] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/mpu/CMakeFiles/arch__arm__core__aarch32__cortex_m__mpu.dir/arm_mpu.c.obj
[44/200] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/atoi.c.obj
[45/200] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/time/gmtime.c.obj
[46/200] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/bsearch.c.obj
[47/200] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/strtol.c.obj
[48/200] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/abort.c.obj
[49/200] Linking C static library zephyr\arch\arch\arm\core\aarch32\cortex_m\libarch__arm__core__aarch32__cortex_m.a
[50/200] Linking C static library zephyr\arch\arch\arm\core\aarch32\cortex_m\cmse\libarch__arm__core__aarch32__cortex_m__cmse.a
[51/200] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/strstr.c.obj
[52/200] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/malloc.c.obj
[53/200] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/strtoul.c.obj
[54/200] Linking C static library zephyr\arch\arch\arm\core\aarch32\cortex_m\mpu\libarch__arm__core__aarch32__cortex_m__mpu.a
[55/200] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/strspn.c.obj
[56/200] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/strncasecmp.c.obj
[57/200] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdout/stdout_console.c.obj
[58/200] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdout/sprintf.c.obj
[59/200] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/exit.c.obj
[60/200] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/string.c.obj
[61/200] Building C object zephyr/soc/arm/common/cortex_m/CMakeFiles/soc__arm__common__cortex_m.dir/arm_mpu_regions.c.obj
[62/200] Building C object zephyr/lib/posix/CMakeFiles/lib__posix.dir/pthread_common.c.obj
[63/200] Building C object zephyr/boards/boards/arm/circuitdojo_feather_nrf9160/CMakeFiles/boards__arm__circuitdojo_feather_nrf9160.dir/board.c.obj
[64/200] Building C object zephyr/lib/posix/CMakeFiles/lib__posix.dir/nanosleep.c.obj
[65/200] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc32_sw.c.obj
[66/200] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf.c.obj
[67/200] Building C object CMakeFiles/app.dir/src/main.c.obj
[68/200] Building C object modules/nrf/lib/fatal_error/CMakeFiles/..__nrf__lib__fatal_error.dir/fatal_error.c.obj
[69/200] Building C object zephyr/drivers/serial/CMakeFiles/drivers__serial.dir/uart_nrfx_uarte.c.obj
[70/200] Linking C static library zephyr\lib\libc\minimal\liblib__libc__minimal.a
[71/200] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc16_sw.c.obj
[72/200] Linking C static library zephyr\soc\arm\common\cortex_m\libsoc__arm__common__cortex_m.a
[73/200] Linking C static library zephyr\boards\boards\arm\circuitdojo_feather_nrf9160\libboards__arm__circuitdojo_feather_nrf9160.a
[74/200] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc8_sw.c.obj
[75/200] Linking C static library app\libapp.a
[76/200] Linking C static library zephyr\lib\posix\liblib__posix.a
[77/200] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc7_sw.c.obj
[78/200] Linking C static library modules\nrf\lib\fatal_error\lib..__nrf__lib__fatal_error.a
[79/200] Linking C static library zephyr\drivers\serial\libdrivers__serial.a
[80/200] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/hex.c.obj
[81/200] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/dec.c.obj
[82/200] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/notify.c.obj
[83/200] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/fdtable.c.obj
[84/200] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/timeutil.c.obj
[85/200] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/printk.c.obj
[86/200] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/onoff.c.obj
[87/200] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/sem.c.obj
[88/200] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/rb.c.obj
[89/200] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/thread_entry.c.obj
[90/200] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/work_q.c.obj
[91/200] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/heap.c.obj
[92/200] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/nrf91/power.c.obj
[93/200] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/nrf91/soc.c.obj
[94/200] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/validate_base_addresses.c.obj
[95/200] Building C object zephyr/CMakeFiles/zephyr.dir/misc/generated/configs.c.obj
[96/200] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf_complete.c.obj
[97/200] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/logging/log_minimal.c.obj
[98/200] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/power/power.c.obj
[99/200] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/power/reboot.c.obj
[100/200] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/heap-validate.c.obj
[101/200] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/validate_enabled_instances.c.obj
[102/200] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/power/policy/policy_residency.c.obj
[103/200] Building C object zephyr/CMakeFiles/zephyr.dir/drivers/console/uart_console.c.obj
[104/200] Building C object zephyr/CMakeFiles/zephyr.dir/C_/Users/jeil_oh/ncs/v1.5.0/nrf/subsys/spm/secure_services.c.obj
[105/200] Building C object zephyr/CMakeFiles/zephyr.dir/C_/Users/jeil_oh/ncs/v1.5.0/nrf/subsys/spm/spm.c.obj
[106/200] Building C object zephyr/CMakeFiles/zephyr.dir/C_/Users/jeil_oh/ncs/v1.5.0/nrfxlib/crypto/nrf_cc310_platform/src/nrf_cc3xx_platform_abort_zephyr.c.obj
[107/200] Building C object zephyr/CMakeFiles/zephyr.dir/drivers/timer/sys_clock_init.c.obj
[108/200] Building C object zephyr/CMakeFiles/zephyr.dir/C_/Users/jeil_oh/ncs/v1.5.0/nrfxlib/crypto/nrf_cc310_platform/src/nrf_cc3xx_platform_mutex_zephyr.c.obj
[109/200] Building C object zephyr/CMakeFiles/zephyr.dir/drivers/timer/nrf_rtc_timer.c.obj
[110/200] Building C object modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedtls_base_vanilla.dir/C_/Users/jeil_oh/ncs/v1.5.0/mbedtls/library/arc4.c.obj
[111/200] Building C object zephyr/CMakeFiles/zephyr.dir/drivers/clock_control/clock_control_nrf.c.obj
[112/200] Generating linker.cmd
[113/200] Building C object modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedtls_base_vanilla.dir/C_/Users/jeil_oh/ncs/v1.5.0/mbedtls/library/aria.c.obj
[114/200] Building C object modules/nrf/drivers/hw_cc310/CMakeFiles/..__nrf__drivers__hw_cc310.dir/hw_cc310.c.obj
[115/200] Building C object modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedtls_base_vanilla.dir/C_/Users/jeil_oh/ncs/v1.5.0/mbedtls/library/aesni.c.obj
[116/200] Building C object modules/nrf/subsys/fw_info/CMakeFiles/..__nrf__subsys__fw_info.dir/fw_info.c.obj
[117/200] Building C object zephyr/CMakeFiles/zephyr_prebuilt.dir/misc/empty_file.c.obj
[118/200] Building C object modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedtls_base_vanilla.dir/C_/Users/jeil_oh/ncs/v1.5.0/mbedtls/library/asn1parse.c.obj
[119/200] Linking C static library modules\nrf\drivers\hw_cc310\lib..__nrf__drivers__hw_cc310.a
[120/200] Building C object modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedtls_base_vanilla.dir/C_/Users/jeil_oh/ncs/v1.5.0/mbedtls/library/blowfish.c.obj
[121/200] Building C object modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedtls_base_vanilla.dir/C_/Users/jeil_oh/ncs/v1.5.0/mbedtls/library/base64.c.obj
[122/200] Building C object modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedtls_base_vanilla.dir/C_/Users/jeil_oh/ncs/v1.5.0/mbedtls/library/camellia.c.obj
[123/200] Linking C static library zephyr\libzephyr.a
[124/200] Linking C static library modules\nrf\subsys\fw_info\lib..__nrf__subsys__fw_info.a
[125/200] Building C object modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedtls_base_vanilla.dir/C_/Users/jeil_oh/ncs/v1.5.0/mbedtls/library/asn1write.c.obj
[126/200] Building C object modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedtls_base_vanilla.dir/C_/Users/jeil_oh/ncs/v1.5.0/mbedtls/library/ctr_drbg.c.obj
[127/200] Building C object modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedtls_base_vanilla.dir/C_/Users/jeil_oh/ncs/v1.5.0/mbedtls/library/gcm.c.obj
[128/200] Building C object modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedtls_base_vanilla.dir/C_/Users/jeil_oh/ncs/v1.5.0/mbedtls/library/cipher_wrap.c.obj
[129/200] Building C object modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedtls_base_vanilla.dir/C_/Users/jeil_oh/ncs/v1.5.0/mbedtls/library/des.c.obj
[130/200] Building C object modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedtls_base_vanilla.dir/C_/Users/jeil_oh/ncs/v1.5.0/mbedtls/library/entropy.c.obj
[131/200] Building C object modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedtls_base_vanilla.dir/C_/Users/jeil_oh/ncs/v1.5.0/mbedtls/library/error.c.obj
[132/200] Building C object modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedtls_base_vanilla.dir/C_/Users/jeil_oh/ncs/v1.5.0/mbedtls/library/entropy_poll.c.obj
[133/200] Building C object modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedtls_base_vanilla.dir/C_/Users/jeil_oh/ncs/v1.5.0/mbedtls/library/havege.c.obj
[134/200] Building C object modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedtls_base_vanilla.dir/C_/Users/jeil_oh/ncs/v1.5.0/mbedtls/library/hkdf.c.obj
[135/200] Building C object modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedtls_base_vanilla.dir/C_/Users/jeil_oh/ncs/v1.5.0/mbedtls/library/hmac_drbg.c.obj
[136/200] Building C object modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedtls_base_vanilla.dir/C_/Users/jeil_oh/ncs/v1.5.0/mbedtls/library/cipher.c.obj
[137/200] Building C object modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedtls_base_vanilla.dir/C_/Users/jeil_oh/ncs/v1.5.0/mbedtls/library/md2.c.obj
[138/200] Building C object modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedtls_base_vanilla.dir/C_/Users/jeil_oh/ncs/v1.5.0/mbedtls/library/nist_kw.c.obj
[139/200] Building C object modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedtls_base_vanilla.dir/C_/Users/jeil_oh/ncs/v1.5.0/mbedtls/library/md5.c.obj
[140/200] Building C object modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedtls_base_vanilla.dir/C_/Users/jeil_oh/ncs/v1.5.0/mbedtls/library/md4.c.obj
[141/200] Building C object modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedtls_base_vanilla.dir/C_/Users/jeil_oh/ncs/v1.5.0/mbedtls/library/bignum.c.obj
[142/200] Building C object modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedtls_base_vanilla.dir/C_/Users/jeil_oh/ncs/v1.5.0/mbedtls/library/padlock.c.obj
[143/200] Building C object modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedtls_base_vanilla.dir/C_/Users/jeil_oh/ncs/v1.5.0/mbedtls/library/pkcs12.c.obj
[144/200] Building C object modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedtls_base_vanilla.dir/C_/Users/jeil_oh/ncs/v1.5.0/mbedtls/library/pk_wrap.c.obj
[145/200] Building C object modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedtls_base_vanilla.dir/C_/Users/jeil_oh/ncs/v1.5.0/mbedtls/library/md.c.obj
[146/200] Building C object modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedtls_base_vanilla.dir/C_/Users/jeil_oh/ncs/v1.5.0/mbedtls/library/pk.c.obj
[147/200] Building C object modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedtls_base_vanilla.dir/C_/Users/jeil_oh/ncs/v1.5.0/mbedtls/library/pkcs5.c.obj
[148/200] Building C object modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedtls_base_vanilla.dir/C_/Users/jeil_oh/ncs/v1.5.0/mbedtls/library/pkwrite.c.obj
[149/200] Building C object modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedtls_base_vanilla.dir/C_/Users/jeil_oh/ncs/v1.5.0/mbedtls/library/pkparse.c.obj
[150/200] Building C object modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedtls_base_vanilla.dir/C_/Users/jeil_oh/ncs/v1.5.0/mbedtls/library/platform_util.c.obj
[151/200] Building C object modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedtls_base_vanilla.dir/C_/Users/jeil_oh/ncs/v1.5.0/mbedtls/library/ripemd160.c.obj
[152/200] Building C object modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedtls_base_vanilla.dir/C_/Users/jeil_oh/ncs/v1.5.0/mbedtls/library/oid.c.obj
[153/200] Building C object modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedtls_base_vanilla.dir/C_/Users/jeil_oh/ncs/v1.5.0/mbedtls/library/version.c.obj
[154/200] Building C object modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedtls_base_vanilla.dir/C_/Users/jeil_oh/ncs/v1.5.0/mbedtls/library/platform.c.obj
[155/200] Building C object modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedtls_base_vanilla.dir/C_/Users/jeil_oh/ncs/v1.5.0/mbedtls/library/timing.c.obj
[156/200] Building C object modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedtls_base_vanilla.dir/C_/Users/jeil_oh/ncs/v1.5.0/mbedtls/library/xtea.c.obj
[157/200] Building C object modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedtls_base_vanilla.dir/replacements/pem.c.obj
[158/200] Building C object modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedtls_base_vanilla.dir/C_/Users/jeil_oh/ncs/v1.5.0/mbedtls/library/version_features.c.obj
[159/200] Building C object modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedtls_base_vanilla.dir/replacements/memory_buffer_alloc.c.obj
[160/200] Building C object modules/hal_nordic/CMakeFiles/modules__hal_nordic.dir/C_/Users/jeil_oh/ncs/v1.5.0/modules/hal/nordic/nrfx/mdk/system_nrf9160.c.obj
[161/200] Building C object modules/hal_nordic/CMakeFiles/modules__hal_nordic.dir/nrfx/nrfx_glue.c.obj
[162/200] Building C object zephyr/kernel/CMakeFiles/kernel.dir/msg_q.c.obj
[163/200] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mutex.c.obj
[164/200] Building C object zephyr/kernel/CMakeFiles/kernel.dir/queue.c.obj
[165/200] Building C object modules/hal_nordic/CMakeFiles/modules__hal_nordic.dir/C_/Users/jeil_oh/ncs/v1.5.0/modules/hal/nordic/nrfx/drivers/src/nrfx_nvmc.c.obj
[166/200] Building C object zephyr/kernel/CMakeFiles/kernel.dir/pipes.c.obj
[167/200] Building C object modules/hal_nordic/CMakeFiles/modules__hal_nordic.dir/C_/Users/jeil_oh/ncs/v1.5.0/modules/hal/nordic/nrfx/drivers/src/nrfx_clock.c.obj
[168/200] Building C object zephyr/kernel/CMakeFiles/kernel.dir/sched.c.obj
[169/200] Linking C static library modules\nrfxlib\nrf_security\src\mbedtls\libmbedtls_base_vanilla.a
[170/200] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mem_slab.c.obj
[171/200] Building C object zephyr/kernel/CMakeFiles/kernel.dir/device.c.obj
[172/200] Building C object zephyr/kernel/CMakeFiles/kernel.dir/errno.c.obj
[173/200] Building C object modules/hal_nordic/CMakeFiles/modules__hal_nordic.dir/C_/Users/jeil_oh/ncs/v1.5.0/modules/hal/nordic/nrfx/drivers/src/nrfx_dppi.c.obj
[174/200] Building C object zephyr/kernel/CMakeFiles/kernel.dir/idle.c.obj
[175/200] Building C object zephyr/kernel/CMakeFiles/kernel.dir/kheap.c.obj
[176/200] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mailbox.c.obj
[177/200] Building C object zephyr/kernel/CMakeFiles/kernel.dir/init.c.obj
[178/200] Building C object zephyr/kernel/CMakeFiles/kernel.dir/sem.c.obj
[179/200] Building C object zephyr/kernel/CMakeFiles/kernel.dir/fatal.c.obj
[180/200] Building C object zephyr/kernel/CMakeFiles/kernel.dir/system_work_q.c.obj
[181/200] Building C object zephyr/kernel/CMakeFiles/kernel.dir/stack.c.obj
[182/200] Building C object zephyr/kernel/CMakeFiles/kernel.dir/thread.c.obj
[183/200] Building C object zephyr/kernel/CMakeFiles/kernel.dir/version.c.obj
[184/200] Building C object zephyr/kernel/CMakeFiles/kernel.dir/thread_abort.c.obj
[185/200] Linking C static library modules\hal_nordic\libmodules__hal_nordic.a
[186/200] Building C object zephyr/kernel/CMakeFiles/kernel.dir/banner.c.obj
[187/200] Building C object zephyr/kernel/CMakeFiles/kernel.dir/condvar.c.obj
[188/200] Building C object zephyr/kernel/CMakeFiles/kernel.dir/smp.c.obj
[189/200] Building C object zephyr/kernel/CMakeFiles/kernel.dir/work_q.c.obj
[190/200] Building C object zephyr/kernel/CMakeFiles/kernel.dir/xip.c.obj
[191/200] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mempool.c.obj
[192/200] Building C object zephyr/kernel/CMakeFiles/kernel.dir/timer.c.obj
[193/200] Building C object zephyr/kernel/CMakeFiles/kernel.dir/timeout.c.obj
[194/200] Linking C static library zephyr\kernel\libkernel.a
[195/200] Linking C executable zephyr\zephyr_prebuilt.elf
FLASH: 32256 B 48 KB 65.63%
SRAM: 8616 B 64 KB 13.15%
IDT_LIST: 56 B 2 KB 2.73%
[196/200] Generating linker_pass_final.cmd
[197/200] Generating isr_tables.c
[198/200] Building C object zephyr/CMakeFiles/zephyr_final.dir/misc/empty_file.c.obj
[199/200] Building C object zephyr/CMakeFiles/zephyr_final.dir/isr_tables.c.obj
[200/200] Linking C executable zephyr\zephyr.elf
[14/165] Generating include/generated/syscall_dispatch.c, include/generated/syscall_list.h
[15/165] Performing build step for 'mcuboot_subimage'
[0/1] Re-running CMake...
Including boilerplate (Zephyr base (cached)): C:/Users/jeil_oh/ncs/v1.5.0/zephyr/cmake/app/boilerplate.cmake
Loaded configuration 'C:/Users/jeil_oh/ncs/v1.5.0/nfed/samples/blinky/build/mcuboot/zephyr/.config'
No change to configuration in 'C:/Users/jeil_oh/ncs/v1.5.0/nfed/samples/blinky/build/mcuboot/zephyr/.config'
No change to Kconfig header in 'C:/Users/jeil_oh/ncs/v1.5.0/nfed/samples/blinky/build/mcuboot/zephyr/include/generated/autoconf.h'
-- Configuring done
-- Generating done
-- Configuring done
-- Generating done
-- Configuring done
-- Generating done
-- Configuring done
-- Generating done
jojo did you try and let it build all the way. What you’ve sent thus far looks ok. Zephyr has to build 3 different images and merge them together for all nRF9160 Feather projects. So you may see output that looks the same.
actually, I cut the recurring codes for convenience. How long does it usually take for the all process?
-- Configuring done
-- Generating done
-- Configuring done
-- Generating done
-- Configuring done
-- Generating done
[2/200] Building C object modules/nrfxlib/nrf_security/src/mbedtls/shared/CMakeFiles/mbedcrypto_shared.dir/C_/Users/jeil_oh/ncs/v1.5.0/zephyr/misc/empty_file.c.obj
[3/200] Building C object modules/nrfxlib/nrf_security/src/mbedtls/cc310/CMakeFiles/mbedcrypto_cc3xx_noglue.dir/C_/Users/jeil_oh/ncs/v1.5.0/zephyr/misc/empty_file.c.obj
[4/200] Building C object modules/nrfxlib/nrf_security/src/mbedtls/shared/CMakeFiles/mbedcrypto_shared.dir/C_/Users/jeil_oh/ncs/v1.5.0/mbedtls/library/sha512.c.obj
[5/200] Linking C static library modules\nrfxlib\nrf_security\src\mbedtls\libmbedtls_external.a
[6/200] Linking C static library modules\nrfxlib\nrf_security\src\mbedtls\cc310\libmbedcrypto_cc3xx_noglue.a
[8/200] Generating misc/generated/syscalls.json, misc/generated/struct_tags.json
[9/200] Generating libmbedcrypto_cc3xx.a
[10/200] Generating include/generated/driver-validation.h
[11/200] Generating include/generated/kobj-types-enum.h, include/generated/otype-to-str.h
[15/200] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/nmi_on_reset.S.obj
[16/200] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/isr_wrapper.S.obj
[17/200] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/swap_helper.S.obj
[18/200] Building C object zephyr/arch/common/CMakeFiles/arch__common.dir/sw_isr_common.c.obj
[19/200] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/nmi.c.obj
[20/200] Building C object zephyr/arch/common/CMakeFiles/isr_tables.dir/isr_tables.c.obj
[21/200] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/fatal.c.obj
[22/200] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/swap.c.obj
[23/200] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/irq_manage.c.obj
[24/200] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/prep_c.c.obj
[25/200] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/reset.S.obj
[26/200] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/vector_table.S.obj
[27/200] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/fault_s.S.obj
[28/200] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/cpu_idle.S.obj
[29/200] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/exc_exit.S.obj
[30/200] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/thread.c.obj
[31/200] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/irq_init.c.obj
[32/200] Linking C static library zephyr\arch\common\libisr_tables.a
[33/200] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/scb.c.obj
[34/200] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/fault.c.obj
[35/200] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/mpu/CMakeFiles/arch__arm__core__aarch32__cortex_m__mpu.dir/arm_core_mpu.c.obj
[36/200] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/tz/CMakeFiles/arch__arm__core__aarch32__cortex_m__tz.dir/arm_core_tz.c.obj
[38/200] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/time/gmtime.c.obj
[39/200] Linking C static library zephyr\arch\arch\arm\core\aarch32\libarch__arm__core__aarch32.a
[40/200] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdout/fprintf.c.obj
[41/200] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/mpu/CMakeFiles/arch__arm__core__aarch32__cortex_m__mpu.dir/arm_mpu.c.obj
[42/200] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/cmse/CMakeFiles/arch__arm__core__aarch32__cortex_m__cmse.dir/arm_core_cmse.c.obj
[43/200] Linking C static library zephyr\arch\common\libarch__common.a
[45/200] Linking C static library zephyr\arch\arch\arm\core\aarch32\cortex_m\tz\libarch__arm__core__aarch32__cortex_m__tz.a
[46/200] Linking C static library zephyr\arch\arch\arm\core\aarch32\cortex_m\libarch__arm__core__aarch32__cortex_m.a
[47/200] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/abort.c.obj
[48/200] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/strtoul.c.obj
[49/200] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/strtol.c.obj
[50/200] Linking C static library zephyr\arch\arch\arm\core\aarch32\cortex_m\mpu\libarch__arm__core__aarch32__cortex_m__mpu.a
[51/200] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/bsearch.c.obj
[52/200] Linking C static library zephyr\arch\arch\arm\core\aarch32\cortex_m\cmse\libarch__arm__core__aarch32__cortex_m__cmse.a
[53/200] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/strncasecmp.c.obj
[54/200] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/string.c.obj
[56/200] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/malloc.c.obj
[57/200] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/strstr.c.obj
[59/200] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdout/stdout_console.c.obj
[60/200] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/exit.c.obj
[63/200] Building C object CMakeFiles/app.dir/src/main.c.obj
[65/200] Building C object zephyr/boards/boards/arm/circuitdojo_feather_nrf9160/CMakeFiles/boards__arm__circuitdojo_feather_nrf9160.dir/board.c.obj
[66/200] Building C object modules/nrf/lib/fatal_error/CMakeFiles/..__nrf__lib__fatal_error.dir/fatal_error.c.obj
[67/200] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf.c.obj
[68/200] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc16_sw.c.obj
[69/200] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc32_sw.c.obj
[71/200] Linking C static library zephyr\soc\arm\common\cortex_m\libsoc__arm__common__cortex_m.a
[72/200] Linking C static library app\libapp.a
[74/200] Building C object zephyr/drivers/serial/CMakeFiles/drivers__serial.dir/uart_nrfx_uarte.c.obj
[75/200] Linking C static library modules\nrf\lib\fatal_error\lib..__nrf__lib__fatal_error.a
[77/200] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/dec.c.obj
[78/200] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc7_sw.c.obj
[79/200] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc8_sw.c.obj
[81/200] Linking C static library zephyr\drivers\serial\libdrivers__serial.a
[83/200] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/timeutil.c.obj
[84/200] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/printk.c.obj
[85/200] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/fdtable.c.obj
[86/200] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/sem.c.obj
[87/200] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/onoff.c.obj
[90/200] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/nrf91/power.c.obj
[91/200] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/work_q.c.obj
[92/200] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/heap.c.obj
[93/200] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/validate_base_addresses.c.obj
[94/200] Building C object zephyr/CMakeFiles/zephyr.dir/misc/generated/configs.c.obj
[95/200] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/nrf91/soc.c.obj
[96/200] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/heap-validate.c.obj
[97/200] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf_complete.c.obj
[98/200] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/power/reboot.c.obj
[99/200] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/validate_enabled_instances.c.obj
[100/200] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/logging/log_minimal.c.obj
[101/200] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/power/policy/policy_residency.c.obj
[102/200] Building C object zephyr/CMakeFiles/zephyr.dir/drivers/console/uart_console.c.obj
[103/200] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/power/power.c.obj
[104/200] Building C object zephyr/CMakeFiles/zephyr.dir/drivers/timer/sys_clock_init.c.obj
[105/200] Building C object zephyr/CMakeFiles/zephyr.dir/C_/Users/jeil_oh/ncs/v1.5.0/nrf/subsys/spm/secure_services.c.obj
[106/200] Generating linker.cmd
[107/200] Building C object zephyr/CMakeFiles/zephyr.dir/drivers/timer/nrf_rtc_timer.c.obj
[108/200] Building C object zephyr/CMakeFiles/zephyr.dir/C_/Users/jeil_oh/ncs/v1.5.0/nrf/subsys/spm/spm.c.obj
[109/200] Building C object modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedtls_base_vanilla.dir/C_/Users/jeil_oh/ncs/v1.5.0/mbedtls/library/gcm.c.obj
[110/200] Building C object modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedtls_base_vanilla.dir/C_/Users/jeil_oh/ncs/v1.5.0/mbedtls/library/error.c.obj
[112/200] Building C object zephyr/CMakeFiles/zephyr.dir/C_/Users/jeil_oh/ncs/v1.5.0/nrfxlib/crypto/nrf_cc310_platform/src/nrf_cc3xx_platform_mutex_zephyr.c.obj
[113/200] Building C object zephyr/CMakeFiles/zephyr.dir/C_/Users/jeil_oh/ncs/v1.5.0/nrfxlib/crypto/nrf_cc310_platform/src/nrf_cc3xx_platform_abort_zephyr.c.obj
[114/200] Building C object modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedtls_base_vanilla.dir/C_/Users/jeil_oh/ncs/v1.5.0/mbedtls/library/hmac_drbg.c.obj
[115/200] Building C object modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedtls_base_vanilla.dir/C_/Users/jeil_oh/ncs/v1.5.0/mbedtls/library/hkdf.c.obj
[116/200] Building C object modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedtls_base_vanilla.dir/C_/Users/jeil_oh/ncs/v1.5.0/mbedtls/library/havege.c.obj
[118/200] Building C object modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedtls_base_vanilla.dir/C_/Users/jeil_oh/ncs/v1.5.0/mbedtls/library/aria.c.obj
[119/200] Building C object modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedtls_base_vanilla.dir/C_/Users/jeil_oh/ncs/v1.5.0/mbedtls/library/aesni.c.obj
[120/200] Building C object modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedtls_base_vanilla.dir/C_/Users/jeil_oh/ncs/v1.5.0/mbedtls/library/arc4.c.obj
[121/200] Building C object modules/nrf/subsys/fw_info/CMakeFiles/..__nrf__subsys__fw_info.dir/fw_info.c.obj
[122/200] Building C object modules/nrf/drivers/hw_cc310/CMakeFiles/..__nrf__drivers__hw_cc310.dir/hw_cc310.c.obj
[123/200] Building C object modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedtls_base_vanilla.dir/C_/Users/jeil_oh/ncs/v1.5.0/mbedtls/library/base64.c.obj
[124/200] Building C object modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedtls_base_vanilla.dir/C_/Users/jeil_oh/ncs/v1.5.0/mbedtls/library/camellia.c.obj
[125/200] Building C object modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedtls_base_vanilla.dir/C_/Users/jeil_oh/ncs/v1.5.0/mbedtls/library/asn1parse.c.obj
[126/200] Linking C static library zephyr\libzephyr.a
[127/200] Building C object modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedtls_base_vanilla.dir/C_/Users/jeil_oh/ncs/v1.5.0/mbedtls/library/ctr_drbg.c.obj
[128/200] Building C object modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedtls_base_vanilla.dir/C_/Users/jeil_oh/ncs/v1.5.0/mbedtls/library/blowfish.c.obj
[129/200] Building C object modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedtls_base_vanilla.dir/C_/Users/jeil_oh/ncs/v1.5.0/mbedtls/library/asn1write.c.obj
[130/200] Building C object modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedtls_base_vanilla.dir/C_/Users/jeil_oh/ncs/v1.5.0/mbedtls/library/des.c.obj
[131/200] Linking C static library modules\nrf\subsys\fw_info\lib..__nrf__subsys__fw_info.a
[132/200] Linking C static library modules\nrf\drivers\hw_cc310\lib..__nrf__drivers__hw_cc310.a
[133/200] Building C object modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedtls_base_vanilla.dir/C_/Users/jeil_oh/ncs/v1.5.0/mbedtls/library/md4.c.obj
[134/200] Building C object modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedtls_base_vanilla.dir/C_/Users/jeil_oh/ncs/v1.5.0/mbedtls/library/cipher_wrap.c.obj
[135/200] Building C object modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedtls_base_vanilla.dir/C_/Users/jeil_oh/ncs/v1.5.0/mbedtls/library/entropy_poll.c.obj
[136/200] Building C object modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedtls_base_vanilla.dir/C_/Users/jeil_oh/ncs/v1.5.0/mbedtls/library/entropy.c.obj
[139/200] Building C object modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedtls_base_vanilla.dir/C_/Users/jeil_oh/ncs/v1.5.0/mbedtls/library/pkcs12.c.obj
[140/200] Building C object modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedtls_base_vanilla.dir/C_/Users/jeil_oh/ncs/v1.5.0/mbedtls/library/md5.c.obj
[141/200] Building C object modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedtls_base_vanilla.dir/C_/Users/jeil_oh/ncs/v1.5.0/mbedtls/library/cipher.c.obj
[143/200] Building C object modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedtls_base_vanilla.dir/C_/Users/jeil_oh/ncs/v1.5.0/mbedtls/library/pk_wrap.c.obj
[144/200] Building C object modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedtls_base_vanilla.dir/C_/Users/jeil_oh/ncs/v1.5.0/mbedtls/library/bignum.c.obj
[145/200] Building C object modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedtls_base_vanilla.dir/C_/Users/jeil_oh/ncs/v1.5.0/mbedtls/library/pkcs5.c.obj
[146/200] Building C object modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedtls_base_vanilla.dir/C_/Users/jeil_oh/ncs/v1.5.0/mbedtls/library/md.c.obj
[147/200] Building C object modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedtls_base_vanilla.dir/C_/Users/jeil_oh/ncs/v1.5.0/mbedtls/library/pk.c.obj
[149/200] Building C object modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedtls_base_vanilla.dir/C_/Users/jeil_oh/ncs/v1.5.0/mbedtls/library/platform_util.c.obj
[150/200] Building C object modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedtls_base_vanilla.dir/C_/Users/jeil_oh/ncs/v1.5.0/mbedtls/library/ripemd160.c.obj
[151/200] Building C object modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedtls_base_vanilla.dir/C_/Users/jeil_oh/ncs/v1.5.0/mbedtls/library/pkparse.c.obj
[152/200] Building C object modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedtls_base_vanilla.dir/C_/Users/jeil_oh/ncs/v1.5.0/mbedtls/library/version_features.c.obj
[153/200] Building C object modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedtls_base_vanilla.dir/C_/Users/jeil_oh/ncs/v1.5.0/mbedtls/library/oid.c.obj
[155/200] Building C object modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedtls_base_vanilla.dir/C_/Users/jeil_oh/ncs/v1.5.0/mbedtls/library/version.c.obj
[157/200] Building C object modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedtls_base_vanilla.dir/C_/Users/jeil_oh/ncs/v1.5.0/mbedtls/library/timing.c.obj
[158/200] Building C object modules/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedtls_base_vanilla.dir/replacements/pem.c.obj
[160/200] Building C object modules/hal_nordic/CMakeFiles/modules__hal_nordic.dir/nrfx/nrfx_glue.c.obj
[161/200] Building C object modules/hal_nordic/CMakeFiles/modules__hal_nordic.dir/C_/Users/jeil_oh/ncs/v1.5.0/modules/hal/nordic/nrfx/mdk/system_nrf9160.c.obj
[162/200] Building C object modules/hal_nordic/CMakeFiles/modules__hal_nordic.dir/C_/Users/jeil_oh/ncs/v1.5.0/modules/hal/nordic/nrfx/drivers/src/nrfx_nvmc.c.obj
[163/200] Building C object modules/hal_nordic/CMakeFiles/modules__hal_nordic.dir/C_/Users/jeil_oh/ncs/v1.5.0/modules/hal/nordic/nrfx/drivers/src/nrfx_clock.c.obj
[164/200] Building C object zephyr/kernel/CMakeFiles/kernel.dir/device.c.obj
[165/200] Building C object modules/hal_nordic/CMakeFiles/modules__hal_nordic.dir/C_/Users/jeil_oh/ncs/v1.5.0/modules/hal/nordic/nrfx/drivers/src/nrfx_dppi.c.obj
[166/200] Building C object zephyr/kernel/CMakeFiles/kernel.dir/errno.c.obj
[167/200] Building C object zephyr/kernel/CMakeFiles/kernel.dir/kheap.c.obj
[168/200] Building C object zephyr/kernel/CMakeFiles/kernel.dir/idle.c.obj
[169/200] Building C object zephyr/kernel/CMakeFiles/kernel.dir/init.c.obj
[170/200] Linking C static library modules\nrfxlib\nrf_security\src\mbedtls\libmbedtls_base_vanilla.a
[171/200] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mailbox.c.obj
[172/200] Building C object zephyr/kernel/CMakeFiles/kernel.dir/fatal.c.obj
[173/200] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mem_slab.c.obj
[174/200] Linking C static library modules\hal_nordic\libmodules__hal_nordic.a
[175/200] Building C object zephyr/kernel/CMakeFiles/kernel.dir/queue.c.obj
[176/200] Building C object zephyr/kernel/CMakeFiles/kernel.dir/pipes.c.obj
[177/200] Building C object zephyr/kernel/CMakeFiles/kernel.dir/msg_q.c.obj
[179/200] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mutex.c.obj
[180/200] Building C object zephyr/kernel/CMakeFiles/kernel.dir/version.c.obj
[181/200] Building C object zephyr/kernel/CMakeFiles/kernel.dir/sched.c.obj
[182/200] Building C object zephyr/kernel/CMakeFiles/kernel.dir/thread_abort.c.obj
[183/200] Building C object zephyr/kernel/CMakeFiles/kernel.dir/system_work_q.c.obj
[184/200] Building C object zephyr/kernel/CMakeFiles/kernel.dir/stack.c.obj
[185/200] Building C object zephyr/kernel/CMakeFiles/kernel.dir/thread.c.obj
[187/200] Building C object zephyr/kernel/CMakeFiles/kernel.dir/xip.c.obj
[190/200] Building C object zephyr/kernel/CMakeFiles/kernel.dir/timeout.c.obj
[191/200] Building C object zephyr/kernel/CMakeFiles/kernel.dir/condvar.c.obj
[193/200] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mempool.c.obj
-- Configuring done
-- Generating done
-- Configuring done
-- Generating done
-- Configuring done
-- Generating done
-- Configuring done
-- Generating done
-- Configuring done
-- Generating done
-- Configuring done
-- Generating done
-- Configuring done
-- Generating done
jojo how are you setting up your environment? I’ll need more information about all the steps you’re following to get here. There are no obvious errors or issues that I’m seeing in your output. I have seen this in the past but usually using -p
or deleting the build folder does the trick.
Have you modified your SDK/samples at all?
@jojo I got your email. Thanks for sharing more details.
It may make sense to try v1.5.1. I’ve updated the Windows instructions to use v1.5.1. Best to uninstall v1.5.0 completely and install v1.5.1.
Let me know how it goes!
Thanks for your help. I removed 1.5.0 and re installed 1.5.1 but still I am getting the same error (recurring codes `
[0/1] Re-running CMake... ` and `-- Found devicetree overlay: C:/Users/jeil_oh/ncs/v1.5.1/bootloader/mcuboot/boot/zephyr/dts.overlay` ).
`[0/1] Re-running CMake...
Including boilerplate (Zephyr base (cached)): C:/Users/jeil_oh/ncs/v1.5.1/zephyr/cmake/app/boilerplate.cmake
-- Application: C:/Users/jeil_oh/ncs/v1.5.1/bootloader/mcuboot/boot/zephyr
-- Using NCS Toolchain 1.5.1 for building. (C:/Users/jeil_oh/ncs/v1.5.1/toolchain/cmake)
-- Zephyr version: 2.4.99 (C:/Users/jeil_oh/ncs/v1.5.1/zephyr)
-- Cache files will be written to: C:/Users/jeil_oh/ncs/v1.5.1/zephyr/.cache
-- Found dtc: C:/Users/jeil_oh/ncs/v1.5.1/toolchain/opt/bin/dtc.exe (found suitable version "1.4.7", minimum required is "1.4.6")
-- Found toolchain: gnuarmemb (C:/Users/jeil_oh/ncs/v1.5.1/toolchain/opt)
-- Found BOARD.dts: C:/Users/jeil_oh/ncs/v1.5.1/zephyr/boards/arm/circuitdojo_feather_nrf9160/circuitdojo_feather_nrf9160.dts
-- Found devicetree overlay: C:/Users/jeil_oh/ncs/v1.5.1/nfed/samples/blinky/../../shared/conf/mcuboot/circuitdojo_feather_nrf9160ns.overlay
-- Generated zephyr.dts: C:/Users/jeil_oh/ncs/v1.5.1/nfed/samples/blinky/build/mcuboot/zephyr/zephyr.dts
-- Generated devicetree_unfixed.h: C:/Users/jeil_oh/ncs/v1.5.1/nfed/samples/blinky/build/mcuboot/zephyr/include/generated/devicetree_unfixed.h
-- Generated device_extern.h: C:/Users/jeil_oh/ncs/v1.5.1/nfed/samples/blinky/build/mcuboot/zephyr/include/generated/device_extern.h
Parsing C:/Users/jeil_oh/ncs/v1.5.1/bootloader/mcuboot/boot/zephyr/Kconfig
Loaded configuration 'C:/Users/jeil_oh/ncs/v1.5.1/nfed/samples/blinky/build/mcuboot/zephyr/.config'
No change to configuration in 'C:/Users/jeil_oh/ncs/v1.5.1/nfed/samples/blinky/build/mcuboot/zephyr/.config'
No change to Kconfig header in 'C:/Users/jeil_oh/ncs/v1.5.1/nfed/samples/blinky/build/mcuboot/zephyr/include/generated/autoconf.h'
MCUBoot bootloader key file: C:/Users/jeil_oh/ncs/v1.5.1/bootloader/mcuboot/root-ec-p256.pem
-- Configuring done
ninja: error: rebuilding 'build.ninja': interrupted by user
^C[152/165] Linking C executable zephyr\zephyr_prebuilt.elf
FLASH: 17448 B 441856 B 3.95%
SRAM: 4104 B 192 KB 2.09%
IDT_LIST: 72 B 2 KB 3.52%
[161/165] Generating ../../zephyr/dfu_application.zip
ninja: build stopped: interrupted by user.
jojo looks like the build nearly completed. Did you give it sufficient time? I noticed on your machine it was taking a while to building in the video you sent. Do you have an older machine? I would expect for it to take a while longer on an older machine.
Could you give an estimated time for compiling? I think I waited for about more than 15 mins. I believe my machine is not that old.
On a modern machine a clean build should be about 1-2 minutes depending on the example size. Have you tried re-building without the -p
flag after trying with? I recommend only using that flag when you want to blow away your build. (not necessary every time)
Also, since you’re on Windows, have you tried building in both Command prompt and Power Shell? I seem to recall having issues on one and not the other.
Hi, It has been a bit while, but I am still struggling with this. One thing that I noticed, from comparing with the example compile output from the blinky sample on the documentation,
I am getting this codes below
Instead of
Configuration saved to '/Users/jaredwolff/Git/nrf-connect/ncs/zephyr/samples/basic/blinky/build/mcuboot/zephyr/.config'
Kconfig header saved to '/Users/jaredwolff/Git/nrf-connect/ncs/zephyr/samples/basic/blinky/build/mcuboot/zephyr/include/generated/autoconf.h'
I think this makes ``[0/1] Re-running CMake…` keep replicating
jojo That output should be different.
Did you try my suggestion of trying to build using both shells?
Yes, For powershell, west function does not work.
`PS C:\Users\jeil_oh\ncs\v1.5.1\nfed\samples\blinky> west build -b circuitdojo_feather_nrf9160ns -p
west : The term ‘west’ is not recognized as the name of a cmdlet, function, script file, or operable program. Check
the spelling of the name, or if a path was included, verify that the path is correct and try again.
At line:1 char:1
~~~~ + CategoryInfo : ObjectNotFound: (west:String) [], CommandNotFoundException
+ FullyQualifiedErrorId : CommandNotFoundException`Also, while I was searching around to solve this issue, I found these similar problems,
https://github.com/zephyrproject-rtos/zephyr/issues/26112
https://github.com/zephyrproject-rtos/zephyr/issues/24909Do you think they are related to this?
jojo This is great info. Thanks for looking into it a bit more. I think I have found the issue on my end. Let me try it out first and then I’ll get it shared so you can get going!
@jojo got it! Turns out my being crafty trying to utilize the same mcuboot overlay was not working in Windows. (Worked fine in my environment thus I never caught it!)
Please run a west update
and try building again.
