mikcatta @jaredwolff Presumably that is the build directory in the C:\nfed\nrf9160-feather\samples\blinky directory?
Yes, C:\nfed\nrf9160-feather\samples\blinky\build delete the whole build directory if that’s where you’re running west build -b circuitdojo_feather_nrf9160ns
mikcatta hmm so this error happens when the cmake cache is mucked up for some reason. The solution for Mac is this. working on a Windows solution..
mikcatta try this:
Open up powershell.exe in Adminstrator mode and run:
choco uninstall cmake
choco install -y cmake --version 3.18.5
Then delete your build directory and try again.
Hi @jaredwolff
Tried that, and cmake didn’t seem to be added to the PATH, so had to add it manually and now it reports as:
C:\nfed\nrf9160-feather\samples\blinky>cmake -version
cmake version 3.18.5
But I still get the same error as before:-
CMake Error at C:/nfed/zephyr/cmake/extensions.cmake:1457 (message):
  Assertion failed: The toolchain is unable to build a dummy C file.  See
  CMakeError.log.
  C:/nfed/zephyr/CMakeLists.txt:42 (assert)
See also "C:/nfed/nrf9160-feather/samples/blinky/build/CMakeFiles/CMakeOutput.log".
See also "C:/nfed/nrf9160-feather/samples/blinky/build/CMakeFiles/CMakeError.log".
FATAL ERROR: command exited with status 1: 'c:\program files\cmake\bin\cmake.EXE' '-BC:\nfed\nrf9160-feather\samples\blinky\build' '-SC:\nfed\nrf9160-feather\samples\blinky' -GNinja -DBOARD=circuitdojo_feather_nrf9160ns
    mikcatta where are you running these commands? powershell.exe? You don’t have any other cmake installations before using choco correct?
    I will add, what are you using to do your edits? I’m starting to see that my setup is not working in standalone powershell.exe but in the shell provided by VSCode. (as that’s how I did my testing)
    @jaredwolff
    I am running the commands from the Windows cmd prompt, is that OK?
    I’ve done a search for cmake.exe and found the following:-
    `C:>dir /s cmake.exe
    Volume in drive C is OS
    Volume Serial Number is 52E2-0FD2
    Directory of C:\Program Files\CMake\bin
    18/11/2020 07:21 8,964,752 cmake.exe
    1 File(s) 8,964,752 bytes
    Directory of C:\Users\mike_\ncs\v1.3.2\toolchain\opt\bin
    14/11/2020 17:21 7,792,128 cmake.exe
    1 File(s) 7,792,128 bytes
    Directory of C:\Users\mike_\ncs\v1.4.0\toolchain\opt\bin
    15/11/2020 11:57 7,792,128 cmake.exe`
    But they don’t appear in the PATH…
    C:\>echo %PATH%
    C:\Python39\Scripts\;C:\Python39\;C:\Program Files (x86)\Common Files\Oracle\Java\javapath;C:\app\mike_\product\11.2.0\odac;C:\app\mike_\product\11.2.0\odac\bin;C:\app\mike_\product\11.2.0\client_64bit_odac\bin;C:\app\mike_\product\11.2.0\client_64bit_odac;C:\Program Files (x86)\Intel\iCLS Client\;C:\ProgramData\Oracle\Java\javapath;C:\Program Files\Intel\iCLS Client\;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\System32\WindowsPowerShell\v1.0\;C:\Program Files\TortoiseSVN\bin;C:\Program Files\Apache\maven\bin;C:\Program Files\Java\jdk1.8.0_161\bin;C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\DAL;C:\Program Files\Intel\Intel(R) Management Engine Components\DAL;C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\IPT;C:\Program Files\Intel\Intel(R) Management Engine Components\IPT;c:\Program Files (x86)\Microsoft SDKs\Windows\v7.0A\Bin;C:\instantclient_11_1;C:\WINDOWS\System32\OpenSSH\;C:\Program Files (x86)\NTP\bin;c:\Program Files (x86)\Microsoft SQL Server\100\Tools\Binn\VSShell\Common7\IDE\;c:\Program Files (x86)\Microsoft SQL Server\100\Tools\Binn\;c:\Program Files\Microsoft SQL Server\100\Tools\Binn\;c:\Program Files (x86)\Microsoft SQL Server\100\DTS\Binn\;c:\Program Files\Microsoft SQL Server\100\DTS\Binn\;C:\Program Files\nodejs\;C:\ProgramData\chocolatey\bin;C:\Program Files\Git\cmd;C:\nRFConnectSDK\bin;c:\program files\cmake\bin;C:\Program Files (x86)\GNU Tools Arm Embedded\9 2019-q4-major\bin;C:\Users\mike_\AppData\Local\Microsoft\WindowsApps;C:\ProgramData\mike_\atom\bin;C:\Users\mike_\AppData\Local\Microsoft\WindowsApps;C:\Users\mike_\AppData\Roaming\npm;C:\Users\mike_\AppData\Local\Programs\Microsoft VS Code\bin
    Directory of C:\nfed
    15/12/2020  19:48    <DIR>          .
    15/12/2020  19:48    <DIR>          ..
    15/12/2020  19:36    <DIR>          .west
    15/12/2020  19:45    <DIR>          bootloader
    15/12/2020  19:47    <DIR>          mbedtls
    15/12/2020  19:52    <DIR>          modules
    15/12/2020  19:37    <DIR>          nrf
    15/12/2020  19:36    <DIR>          nrf9160-feather
    15/12/2020  19:46    <DIR>          nrfxlib
    15/12/2020  19:46    <DIR>          test
    15/12/2020  19:52    <DIR>          tools
    15/12/2020  19:59    <DIR>          zephyr
      mikcatta hmm looks ok. So you’re still getting the “Cannot compile dummy file” error on both Linux and Windows?
      What’s the version of your compiler?
      Evening @jaredwolff
      I’ve got a bit further on Linux, but not quite to point of compiling !
      Both Win & Ubuntu report:
      - The C compiler identification is GNU 9.2.1
      -- The CXX compiler identification is GNU 9.2.1
      I believe I have a compile on Ubuntu !
                 FLASH:       12876 B     441856 B      2.91%
                  SRAM:        3904 B       128 KB      2.98%
              IDT_LIST:          56 B         2 KB      2.73%
      [158/158] Generating zephyr/merged_domains.hex
      Had to follow these instructions on the Nordic site for the Python dependencies, which are ever so slightly different to the instructions on your site. [https://developer.nordicsemi.com/nRF_Connect_SDK/doc/latest/nrf/gs_installing.html#installing-the-required-tools]
      pip3 install –user -r zephyr/scripts/requirements.txt
      pip3 install –user -r nrf/scripts/requirements.txt
      pip3 install –user -r bootloader/mcuboot/scripts/requirements.txt
      I am using CMake 3.18.5 on Ubuntu, but I am not sure that was the issue.
      Hi @jaredwolff Just to clarify….
      I have created a ~/.zephyrrc file which contains
      export PATH=$PATH:/home/mike/cmake-3.18.5-Linux-x86_64/bin
      export ZEPHYR_TOOLCHAIN_VARIANT=gnuarmemb
      export GNUARMEMB_TOOLCHAIN_PATH="~/gnuarmemb"
      I installed cmake-3.18.5 from source, so it installed it locally. Again not sure, that was the issue. The GNUARMEMB was installed into the directory ~/gnuarmemb
      On first compile, I had to add the “-p” command, so ran west build -b circuitdojo_feather_nrf9160ns -p
      Some of these steps may not be necessary, but it seems to compile a hex file now at least on Ubuntu. Next step will be to see if I can flash it from the VM or maybe in needs to be transferred to Windows for programming the board, but that’s tomorrow little game.
      Got it. I’m looking into utilizing the nRF Desktop SDK Manager. Since you have those already installed, it would make the most sense to use them. Stay tuned..
      HI @jaredwolff
      Apologises, I thought I’d have a go at compiling one of the main apps for the Feather at https://docs.jaredwolff.com/nrf9160-agps-sample.html
      From the /home/mike/nfed/nrf/samples/nrf9160/nrf_cloud_agps, I’ve added the additional lines to the prj.conf, but when I try and compile it says:-
      **/home/mike/nfed/nrf/samples/nrf9160/nrf_cloud_agps/prj.conf:61: warning: attempt to assign the value '"feather-"' to the undefined symbol NRF_CLOUD_CLIENT_ID_PREFIX**
      Parsing /home/mike/nfed/nrf/samples/nrf9160/nrf_cloud_agps/Kconfig
      Loaded configuration '/home/mike/nfed/zephyr/boards/arm/circuitdojo_feather_nrf9160/circuitdojo_feather_nrf9160ns_defconfig'
      Merged configuration '/home/mike/nfed/nrf/samples/nrf9160/nrf_cloud_agps/prj.conf'
      CMake Error at /home/mike/nfed/zephyr/cmake/kconfig.cmake:217 (message):
        /home/mike/nfed/zephyr/cmake/app/boilerplate.cmake:506 (include)
        /home/mike/nfed/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:24 (include)
        /home/mike/nfed/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:35 (include_boilerplate)
        CMakeLists.txt:9 (find_package)
      FATAL ERROR: command exited with status 1: /home/mike/cmake-3.18.5-Linux-x86_64/bin/cmake -B/home/mike/nfed/nrf/samples/nrf9160/nrf_cloud_agps/build -S/home/mike/nfed/nrf/samples/nrf9160/nrf_cloud_agps -GNinja -DBOARD=circuitdojo_feather_nrf9160ns
      Without that line, it compiles just fine. What I am doing wrong here please?
        mikcatta this example only works on newer versions of the nRF Connect SDK. What version are you using?
